P0011 Camshaft Position issue
- - - - - p0011 camshaft position ecutek camshaft timing timing over advanced
No replies to this topic
majj35
majj35
  • 74 posts
  • Joined 05-February 16
  • LocationJeddah, KSA
Firstly, Can this be a tune related fix... or definitely mechanical??
I recently moved from Cobb to Ecutek and never had that code appear before until now with Ecutek. No CEL on dash, only P0011 comes up when i check the "DTC Tool" on my ECUconnect app. (also refreshed oils/fluids)
A couple of times, when the car is cold, it would stall on the first startup. Otherwise, no limp or stutters while driving.
I had an engine rebuild last year (AMS short block 3.8, A9 turbos, Camshaft GSC, and more...)
The shop is certain that the engine needs a "refresh" cleanup on the factory parts (seals, o rings etc..) - but before doing that and paying an arm/leg for engine labor. I want to know if there's any troubleshooting to do by tune or by inspecting parts without taking the engine out. Thanks
-2014 Black Edition
2014 GT-R Black Edition
Built 3.8L Race; Alpha 9
Engine: AMS Race 3.8L | A9+ Turbos | GSC Power-Division S1 Cams | Alpha Street FMIC | Sakura 3" Intakes | HKS M45HL | HKS SSQV4
Trans: Dodson Superstock 8 Plate Clutch Kit | Dodson Extreme Duty 1st Gear & Input Shaft
Fuel: Visconti FlexFuel v2 | Asnu 1100cc Injectors | Twin Walbro 525lph Pumps MC Performance Fuel Lines
Exhaust: Alpha 90mm Catless Downpipes | HKS Resonated Midpipe | HKS Legamax Titanium Exhaust
Exterior: N-Tune CF Splitter | Rexpeed Z Skirts | Difflow Fins RevoZport DN Trunk JCR GT Wing | '15 Lights
Interior: DCT Custom Steering wheel | Shiftkoncepts Paddles | Rexpeed Carbon Steering Cover | COBB ApV3-006
Wheels: Advan RS-D 20x9.5/10.5 | ProjectKics Leggdura CL53 lugs | Eibach spacers 15mm/20mm | Pzero 285/295
750whp+/xxxwtq (95 Ron estim.) - MC/Kanoo Performance (e-tune)
860whp+/xxxwtq (C16 estim.) - MC/Kanoo Performance (e-tune)
if_Instagram_1298747.pnggwynethbluepearl
YouTubeMajj Garage
1968 Camaro SS | LSx/ProTouring (Here)
Build Blog & Reviews (Here)
Also tagged with one or more of these keywords: p0011, camshaft position, ecutek, camshaft timing, timing over advanced
