Aragosta PnP Coilovers with 4 Cup lift
17 replies to this topic
jdmrb1
jdmrb1
  • 395 posts
  • Joined 22-February 15
  • LocationYokohama Japan
Finally received my Aragosta Coilovers with list. They are PnP with the OEM suspension controller
allowing continued use of the 3 way dash switch. Based on the Type-S Coilovers with Hana Springs rates are 16/10k. Can be custom order and also have a 3 way external tank version for more cash. Lift uses 2 tanks with a small air compressor to save your lip from driveways. Has a trick little remote control too. Will install shortly just got my tanks back from chrome plating. IMG_4430.jpg
jdmrb1
jdmrb1
  • 395 posts
  • 1,806 posts
beautiful! interested in the review after you get it installed.
  • 4,624 posts
Nice!
jdmrb1
jdmrb1
  • 395 posts
First one in so far! Added adjustable upper control arms while I was at it. IMG_5233.jpg
  • 4,624 posts
Looks good dude!
  • jdmrb1 likes this
jdmrb1
jdmrb1
  • 395 posts
Camber without hitting the alignment rack yet or any tweaks to ride height!e28672bc78dbd6d75f316faec26c3202.jpg
jdmrb1
jdmrb1
  • 395 posts
Test fit my rear 12” wheels with 345 tires to see how they fit as I intend on going 325 square. Not bad at all! IMG_5508.jpg
jdmrb1
jdmrb1
  • 395 posts
Coilovers handle fantastic teamed with the adj upper control arms and the 16/10 spring rates they ride and turn in much faster with better feel. R mode is perfect although comfort seems too soft. More testing to follow.
  • Johnnypbmx likes this
Frackz
Frackz
  • 4 posts
  • Joined 18-January 22
Hi there,
Do you have pics of your tank install and location as well?  How did you route the airlines, drill any new holes etc?
Edited by Frackz, 05 February 2022 - 01:05 PM.
Johnnypbmx
Johnnypbmx
  • 125 posts
  • Joined 25-February 14
Awesome to see the process. Thanks for sharing. I may switch to these p-n-p without the cups.
What brand adj arms did you go with?
Edited by Johnnypbmx, 05 February 2022 - 01:23 PM.
jdmrb1
jdmrb1
  • 395 posts
Hi there,
Still in progress test fitting up a few adjustments the tricky parts is the tank pressure switch, pretty long. If that wasn’t there would be real easy! 82e97e502a559dbc2bfaf775b7044cf0.jpg
Frackz
Frackz
  • 4 posts
looking awesome!
Frackz
Frackz
  • 4 posts
any updates \ reviews with drive and modes?
jdmrb1
jdmrb1
  • 395 posts
Hi there,
Ran front air lines with 0 gauge power cable along the passenger side of interior and throw firewall to shocks. Found preexisting holes in fender walls to run left and right lines. Here’s the system diagram. c230c3fe7c370777375b18b3e432e3ea.jpg
Rear lines run under my amp rack through rubber grommet for gearbox ECU cables. Will post pics of all the runs soon. Sorry delay but winter here in Japan still. I did drive it with new Coilovers installed without lift hooked up and it’s a night and day improvement!
jdmrb1
jdmrb1
  • 395 posts
Since the yen is down against dollar going to take advantage and order up my Advan GT Beyond 20x12 Square setup to go with Cup 2 325 tires.
jdmrb1
jdmrb1
  • 395 posts
Air tubing run from tanks wiring all set up!
jdmrb1
jdmrb1
  • 395 posts
Power distro all finished up just need to all the plastic coverings to walls. 57971bec25ebdbec04426de5197ecef7.jpg
