Today I was driving my car and it was running great and pulling hard, but then all of a sudden when getting into boost it was bogging down or maybe misfiring. It is an FBO car running E85 with 26k miles on it. I don't think the plugs have ever been changed. Didn't throw any cel lights and runs fine at idle and when driving unless in boost. Anything else I should look at before changing the plugs? Thanks!
Car bogging down or misfiring when getting into boost
Posted 02 October 2021 - 12:24 PM
Posted 03 October 2021 - 12:02 PM
I just hammer on it in first gear and go through the gears its smooth as ever. If I hammer on it in a lower gear with the rpms low thats when it seems to stutter or bog down. Got the service engine soon light once and it said misfire cylinder 2 when I pulled the code.
Posted 03 October 2021 - 12:19 PM
So a P0302 my bet is that it is a plug
Edited by Ian201, 03 October 2021 - 12:20 PM.
Posted 03 October 2021 - 02:46 PM
Posted 03 October 2021 - 11:30 PM
There is always a small chance that it can be a coil. If you want you could always switch coils on cyl 4 and cyl 2 and see if the misfire moves, it`s one way of checking. As you`re removing them anyway no more work involved.
Posted 04 October 2021 - 12:47 PM
Posted 04 October 2021 - 01:01 PM
Posted 04 October 2021 - 01:12 PM
Yeah i understand that but it`s the only way of isolating the coil if it is indeed the problem. My guess is still the plug but obviously i can`t be 100% sure.
It`s an hours work to remove and install the manifold so it`s not that bad, that`s if you do it yourself and you have a garage where you can work you don`t even have to replace the gasket so no cost involved.
If your plugs were changed more than about 2-3 years ago and you run corn i still say plug.
Posted 04 October 2021 - 01:22 PM
- Ian201 likes this
Posted 21 October 2021 - 04:46 PM
- Tim and Ian201 like this
Posted 21 October 2021 - 11:35 PM
Good to hear it`s up and running again.
After every second year you need to change the plugs with normal driving/mileage.
Edited by Ian201, 21 October 2021 - 11:40 PM.
- Tim likes this
Posted 22 October 2021 - 09:39 PM
