Toyo R888R Tires
16 replies to this topic
krue92
krue92
  • 7 posts
  • Joined 15-March 13
I got my 2010 GTR with 25k miles about a year ago and it had the Toyo R888 tires on it with 315/30/20 and 285/35/20 on Forgeline 20x11 and 20x10 wheels.  It needed tires so I got the new R888R's in the same size and now I start seeing posts about that being the wrong size and that I should of done a 325 instead of a 315 due to different rolling diameter that could cause ets issues.  This makes me nervous, but I haven't seen any AWD lights or noticed any issues.  I probably have only 1000 miles on them and I am just running FBO E85.  Do you think this is cause for concern and I need to switch them out or should I just keep on eye on it and make sure next time to get the 325 size.  I have read some people have no issues with the 315, but other have, so just wanted a few more opinions.
  • 4,584 posts
If you're super concerned you should do a rollout test (https://help.summitr...s-tire-rollout?) with them to see what the actual difference is.  I think the tolerance is ~1.5%?
sam2avila
sam2avila
  • 125 posts
  • Joined 08-March 15
For peace of mind, I went 285 square on wheel specs similar to yours. Also on R888R.
  • 4,584 posts
I also went square. 305 on 10.5 all around
  • sam2avila likes this
5ive
5ive
  • 57 posts
  • Joined 29-March 16
  • LocationGermany Hannover
285/315 toyo r888r killed my awd clutch with stock wheel sizes front 9,5 and rear 10,5, check the rollout diameter or just height of the tyre.
sam2avila
sam2avila
  • 125 posts
Hey man, sorry but I forgot, how you pull this off ?
krue92
krue92
  • 7 posts
I'm taking it to my tuner next week to check the wheel speed before I do anything.
  • thehelix112 and sam2avila like this
  • 4,584 posts
All good. I am running oem rear wheels all around, with the front stock lower control arm adjusted inboard and spl upper control arms set at -3.5 deg camber.
sam2avila
sam2avila
  • 125 posts
Got it, thanks Dave.
Sam
krue92
krue92
  • 7 posts
I went to my tuner yesterday and wheel speeds from front to back were identical most of the time. Sometimes when excelerating hard they would maybe be 1km off from front to back. I am not sure what I am going to do now. Might order the 325's for a piece of mind.
  • 4,584 posts
I don't think that means it's not wrong, it just means that the ets isn't strong enough to make the fronts slip. You could just be wearing out the ets.
krue92
krue92
  • 7 posts
Well I have only had them on for 1k miles and I normally don't drive that aggressive. I would hope I haven't really done any damage as of it. AWD system definitely still works great. I have no slippage signs as of yet.
krue92
krue92
  • 7 posts
Ordered the 325's today.  Anybody need some 315's?  :clap:
Edited by krue92, 21 October 2020 - 02:07 PM.
  • 531 posts
Over 15k miles using 325 rear and 285 front with no issues.
My FWD clutches were “refreshed” when I had my Billet gears 2-6 installed last year. Shep mentioned my FWD clutches showed very little And normal wear. Nothing looked like the 325/285 combo Was doing any damage.
krue92
krue92
  • 7 posts
Good to hear! Thanks for the update
  • 2,118 posts
  • LocationNew York
I just ordered a set 19/20” set for the NSX. Should help with wheel spin drastically on launch.
  • 531 posts
Who has the best tire prices online for R888R these days?  Need a new set ASAP
