New Toyo Proxes RR tire sizes
17 replies to this topic
  • 1,798 posts
I haven't looked at tires in about a year and it seems Toyo released some new sizes late last year. They now have the semi-slick RR compound tire in 20" sizes! This may be a good Hoosier alternative (and NASA approved). Anyone tried these yet? I may be willing to give it a go...
https://www.toyotire...oduct/proxes-rr
40 treadwear!!
Edited by choerizo, 27 August 2020 - 04:13 PM.
  • droptopp, sam2avila and jhammergtr like this
  • 2,118 posts
  • LocationNew York
Damn 40 treadwear will be nice for the street ;)
  • 1,662 posts
A lot of the big power vipers run this tire and swear by it
  • 5,189 posts
285/35R20's all around
They are better than R888's
They are better than Pilot 4s's
I was VERY VERY pleased by both durability and performance.
  • thehelix112, choerizo, droptopp and 1 other like this
  • 1,798 posts
awesome feedback as usual. seems like the closest thing to a full on slick you can get. i'll be getting a set prior to the next track day.
  • 5,189 posts
You will NOT be disappointed.
Track tire - BEST 20' track tire I've ever had for one weekend so far.  I have one-two further weekends coming up, and we'll see how long they last.
  • 2,118 posts
  • LocationNew York
Anyone use these on the street ?
  • 1,798 posts
what starting psi and target psi/temps are you getting?
  • 5,189 posts
Accidentally when I had to.  Very very good.  I don't predict good wear or wet traction, but in the dry on the street (dinnertime from track), they were awesome.
  • 5,189 posts
I screwed this up at first.  I was targeting for 40psi at the end of hot 40 minute session.  I started at 32 to get there.  Later found out that I should have been targeting 35, so I reckon I should have started at 28.
Nonetheless, at five pounds over target, they were AWESOME.
  • thehelix112, choerizo and droptopp like this
  • 1,798 posts
Is it even worth considering 285/325 for track duty? or will the understeer offset any added grip benefits i would get from the wider tire?
sam2avila
sam2avila
  • 125 posts
  • Joined 08-March 15
Looks like I found my next set of tires!
jhammergtr
jhammergtr
  • 9 posts
  • Joined 17-October 17
I normally run 18" Nitto NT01 with 1700lb max load . The RR in 285/18 have 1433 lbs max load rating. Would that be too low for our GTRs?
fyi Toyo Tires recommends the following general set-up guidelines for the Proxes RR:
Operating Temperature: 160°F to 220°F
Hot Inflation Pressures: 32 to 38 (psi)
Camber: -1° to -3°
Caster: As much positive as possible
  • 5,189 posts
You never know until you try.
  • Tim, choerizo, droptopp and 1 other like this
Johnnypbmx
Johnnypbmx
  • 123 posts
  • Joined 25-February 14
Will this be in spec fo not cause premature clutch wear? I really wanna get back on r888s but as far as i know their sizes are not in spec to keep the computers happy :-/
  • 5,189 posts
Run a square setup.  Period.  Only way to be sure without doing a full runout.
  • thehelix112 and Johnnypbmx like this
  • 4,584 posts
This.
You can make the rear oem sized wheels work on the front with spl upper control arms and adjusting the stock lower control arms in.
  • Johnnypbmx likes this
Johnnypbmx
Johnnypbmx
  • 123 posts
I have bbs lm gtr fitment- was thinking of trying to get 10.5” barrels up front to run square...would have to be custom though.
