Instructions are here: https://www.verus-en...install-manuals and attached.
A bit about the kit. It is pretty much perfect. Comes with extra bolt, washer and nut in every size in case you lose one, the quality of the carbon is very high. Dry carbon, perfect weave, light and strong.
Basic steps are you drill holes in the diffuser using the precise template that comes with the kit:
trim the plastic rear wheel well lower flats:
trim the edges if necessary (dba or higher):
bolt the centre strakes on:
then bolt the diffuser back in with the two outside strakes on:
Took 2hrs max, and I'd had 2 beers before I started so...
Enjoy,
Edited by thehelix112, 18 July 2020 - 09:56 PM.
