Dodson Engine and Transmission Mounts @Cicio Performance
- - - - - cicio performance dodson motorsport engine transmission mount
1 reply to this topic
Andrew@Cicio
Andrew@Cicio
  • 44 posts
  • Joined 07-April 20
There are lots of situations where we are very bad at bringing to the market the products that we use in our daily builds!  We use a product and prove that it works for us then just forget to offer it ala-carte to the masses.
This is one of those products.  The Dodson Motorsport engine/trans mounts are in our opinion the VERY BEST option on the market for the street GT-R.  They are much more supportive than the factory mount, limit engine torquing with higher HP GT-Rs, however unlike the solid mounts these polyurethane dampened mounts actually won’t vibrate your teeth out.  This mount is the perfect compromise between the stock vs. full solid billet mount.
If you have any questions please let us know!
Features include:
  • Manufactured from high grade billet 6061 Aluminium alloy that increases the strength of the mounts
  • Mounts are upgraded from rubber to polyurethane
  • Maintains drive shaft alignment between the transmission and the front wheel drive differential especially under high torque
  • Maintains prop shaft alignment between the engine and the transmission especially under high torque
  • Reduced vibration from solid mount systems
  • Lighter and smoother than OEM
  • Direct OEM replacement so modification to the engine mount locations is not required
Pricing Starting at:
Engine - $925.95
Transmission - $724.95
Find out more here:
https://cicioperformance.com/product/dodson-r35-polyurethane-engine-mounts/
https://cicioperformance.com/product/dodson-r35-trans-mounts/
-Andrew
Andrew Pasik
Sales | Cicio Performance
Phone: 678.297.7770 ext 106
http://www.cicioperformance.com
Cicio
Cicio
  • 1,131 posts
I have these in stock and happy to offer you guys a forum member deal so hit Andrew up and let him know you are a member if you are interested!
Thanks guys!
~N.Cicio
Email: cicio@cicioperformance.com
Also tagged with one or more of these keywords: cicio performance, dodson motorsport, engine, transmission, mount
