Cicio Performance Drag Wheel Special!!!!
cicio performance wheel drag wheel billet specialties
2 replies to this topic
Andrew@Cicio
Andrew@Cicio
  • 11 posts
  • Joined 07-April 20
Cicio Performance Drag Wheel Special!!!!!
Choosing the right wheel & tire combo for drag racing is essential to running a great time and the Cicio Performance Drag Wheel Package  is perfect for that.
 Our exclusive wheel design is built right here in the USA by Billet Specialties which undergo a very stringent process to ensure you get the best quality wheel possible.
  • Utilizing proprietary 6061-t6 forged billet aluminum centers allows them to manufacture the highest quality and strongest wheels possible.
  • All B-Forged near-net raw forgings start off with the lathe operation. This process prepares the forging for machining the design into the center.
  • Utilizing the latest CNC machinery and tooling along with over 30 years of experience, each forging begins with the turning operation in one of their CNC lathes.  The resulting wheel centers are then transferred to the milling department where they are precision machined to exact specifications.
  • All finishing is performed in-house at Billet Specialties. Powder coat finishes start with careful surface preparation followed by thorough cleaning to remove any contamination. The powder application in their clean environment and precise cure times in the oven, result in one of the finest finishes available in the industry.
  • Before the assembly begins, each wheel component is meticulously inspected. Once assembled, both the lateral and radial run-out is checked to ensure a vibration free wheel. Final fastener torque is completed and the sealant is applied to the thoroughly cleaned surface.
Features and Specs:
  • Price is per set of 2 wheels
  • Cicio Performance exclusive design built in the USA by Billet Specialties
  • Clears factory rear brakes (17” and 18” Wheels only)
  • Forged 6061-T6 aluminum
  • Welded 2 piece design
  • Lowers rotational mass by saving almost 20lbs per side from the factory wheel/tire
  • 40+ finish options available
  • Polished and Custom Finishes available for $250
  • Standard polished lips with optional color matched lips available
  • All tire packages include mounting and balancing
Retail Pricing Starting at:
15” Beadlock - $1695
17” Non- Beadlock - $1895
17” Beadlock - $2895
18” Front - $1995
18” Rear - $2495
Use code "cicio5" for an additional Discount!!!
Tire Packages Available as well!!!!
Link to Wheels:
https://cicioperform...gtr/wheels-gtr/
Let us know if you have any questions!!
  • Tim and droptopp like this
Andrew Pasik
Sales | Cicio Performance
Phone: 678.297.7770 ext 106
http://www.cicioperformance.com
  • 9,834 posts
Those wheels are fire
  • droptopp and Andrew@Cicio like this
Guido
Guido
  • 289 posts
  • Joined 05-January 13
Wow, those wheels look great!!  Go fast and look good doing it!
  • Andrew@Cicio likes this
