Ignite Fuel Special @ Cicio Performance
ignite racing fuel cicio performance
No replies to this topic
Andrew@Cicio
Andrew@Cicio
  • 48 posts
  • Joined 07-April 20
Ignite Racing Fuel produces some of the best performing race fuels on the market and we are very proud to use them in our builds to make strong, safe, and consistent power!
We have tested and used lots of fuel here through the years and literally over hundreds of builds.  When switching cars from E98 or race gas we always find that the knock counts and engine noise gets significantly quieter on Ignite.
We aren’t really big on just promoting products because we make margin on it unless it works!  Especially something as sensitive and important as the fuel that goes in our clients 1000+ HP cars.  This stuff however really works, we have seen it with our own eyes.
Unlike other companies that just blend chemicals without knowledge of the fuel, Ignite is involved from the very beginning. Ignite is proud to be farmer owned and operated. In fact, the pictures above were taken during their harvest season! They plant and harvest corn every year, which is then taken to the local ethanol plant (started by the owner of Ignite) to be converted to fuel grade ethanol. Then finally brought to their shop where they blend the fuel with high quality denaturants to create the fuel you know and love!
Do you know where your fuel comes from?
At Cicio Performance, we primarily use Ignite Red 114 (E90)
Ignite Red 114 (E90): The Ignite Red 114 is an E90 blend designed for applications of 500+hp. This fuel is perfect for both forced induction and high compression applications. With superior burn speed and energy value, Ignite 114 will reduce engine temperatures while delivering more power and torque outperforming similarly rated gasoline based fuels.
$60 for 5 gallon pail / $600 for 55 gallon drum!
Although this is what we primarily use, we still have the ability to get other Ignite Fuels such as:
Ignite Orange (E85)
Ignite Yellow (E98)
Let us know if you have any questions!!
-Andrew
Andrew Pasik
Sales | Cicio Performance
Phone: 678.297.7770 ext 106
http://www.cicioperformance.com
Also tagged with one or more of these keywords: ignite racing fuel, cicio performance
