Block Heater install
Best Answer JohnnyTSi , 23 March 2020 - 07:58 PM
Followup for the next unfortunate soul that wants to take this project on! It IS possible to install a Block Heater from the top. I had to remove both upper and lower intake manifolds to have enough room to get the job done. Even with the manifold out of the way I couldn't get my fat hands down far enough to even touch the mounting hole.
With the cable attached I was able to use a coat hanger bent into a "U" on the end to coax the element into the hole!
Once the end is in the hole it was about 3331/3 wiggles using the cable and a long screwdriver to get it coaxed all the way into the hole.
Next challenge was to get the clip to engage, I used one of my long pry-bars that has an angled end to pop the clip on.by prying against the end of the connector.
Good Luck,
John-
Go to the full post »
21 replies to this topic
JohnnyTSi
JohnnyTSi
  • 43 posts
  • Joined 16-March 19
  • LocationEverett, WA
✓  Best Answer
Good Luck,
John-
Beautiful Blue FBO 2013 R35 GTR
655/638tq Daily Driven street thrasher!
Cobb 3" Intakes
SBD Race Intercooler with TiAL BOVs
Cobb catted Down Pipes
Cobb mid pipe modded with a Borla resonator
MAP Muffled 3.5" cat back
ASNU 330 pumps
id1300x2 injectors
Visconti Flex Fuel kit
Omni 4bar Map sensor kit
Cobb Fuel Pressure sensor kit
Torque Solution Maf Block-off Plates
  • 4,425 posts
I am glad I live in California.
Nicely done though!
