Block Heater install
Best Answer JohnnyTSi , 23 March 2020 - 07:58 PM
Followup for the next unfortunate soul that wants to take this project on! It IS possible to install a Block Heater from the top. I had to remove both upper and lower intake manifolds to have enough room to get the job done. Even with the manifold out of the way I couldn't get my fat hands down far enough to even touch the mounting hole.
With the cable attached I was able to use a coat hanger bent into a "U" on the end to coax the element into the hole!
Once the end is in the hole it was about 3331/3 wiggles using the cable and a long screwdriver to get it coaxed all the way into the hole.
Next challenge was to get the clip to engage, I used one of my long pry-bars that has an angled end to pop the clip on.by prying against the end of the connector.
Good Luck,
John-
Go to the full post »
21 replies to this topic
JohnnyTSi
JohnnyTSi
  • 43 posts
  • Joined 16-March 19
  • LocationEverett, WA
Has anyone here installed a block heater in their r35? I have a heater element and cord inbound and after looking at how tight the engine/firewall is I'm wondering how hard the install is? or if it is even possible without dropping the engine?
Thanks,
John-
  • Enshiu and thehelix112 like this
Beautiful Blue FBO 2013 R35 GTR
655/638tq Daily Driven street thrasher!
Cobb 3" Intakes
SBD Race Intercooler with TiAL BOVs
Cobb catted Down Pipes
Cobb mid pipe modded with a Borla resonator
MAP Muffled 3.5" cat back
ASNU 330 pumps
id1300x2 injectors
Visconti Flex Fuel kit
Omni 4bar Map sensor kit
Cobb Fuel Pressure sensor kit
Torque Solution Maf Block-off Plates
  • 9,795 posts
-since I live in Fl . I can’t be of any help, and to be honest I don’t think I’ve er even seen a thread on this subject
JohnnyTSi
JohnnyTSi
  • 43 posts
I did a bit of searching and discovered very little info - Hence why I started this thread!
Thanks,
John-
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
JohnnyTSi
JohnnyTSi
  • 43 posts
The most information I found was in this thread on the 'other' board:
https://www.gtrlife....adian-brothers/
part numbers needed:
  • heater - 11001-1NC0B
  • cord - 24076-1LA1A
and I think this is where the heater element installs:
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
  • 4,425 posts
That looks awful. But I hope I'm wrong. Let us know how it goes!
JohnnyTSi
JohnnyTSi
  • 43 posts
I agree - wish I had thought to check the last time I had the intake manifold off
John-
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
  • 505 posts
Running engines in extreme cold temps is typically "hard" on many components. Why do you need to start/drive it in such harsh temperature conditions?
JohnnyTSi
JohnnyTSi
  • 43 posts
well - that was helpfull!
John-
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
  • 505 posts
John-
Maybe not to you but possibly to your car/motor? Lol
Coming from an aviation background our mechanics used to say "if you need to buy a block heater get ready to buy a new engine"
  • 5,135 posts
So John, socalaviator is kind of right about this.  I realize the responses sound kurt and off the cuff, but they are correct.  If you plan on operating this beast in the Washington area during your extreme winters, especially highly tuned, even with a block heater there WILL be consequences.  So, I think what he's getting at is if you can have a beater car that you don't care as much about during the winters that might be a better choice.
If, on the other hand, you're going to run a block heater when the outside temp is 50 deg F at startup for safer startups for a nice spring or fall drive, that's another thing.  And, living in Washington, you have more familiarity with block heaters than many of us do down in the lower 50.
So, everybody dial down just a little bit and let us know what the real situation is....
  • Tim and Enshiu like this
  • 505 posts
I was genuinely curious about the need to operate the GTR in such harsh temperatures. Having a secondary vehicle of lesser value is a good recommendation.
  • Tim and Ian201 like this
JohnnyTSi
JohnnyTSi
  • 43 posts
1. I bought this car to drive! frankly I've never understood why someone buys a car to turn it into a garage queen! I drive my cars like I stole it every day! and frankly the though of driving a shitbox makes me gag!
2. I leave for work at 5am
3. I currently have a garage that is full of projects so the gt-r is relegated to the driveway! (yeah I know heresy)
4. I live in the Pacific Northwest, and while it isn't socal, it rarely dips into the teens, not exactly what I consider harsh weather!
5. I'm an old wild child that has been around the world a few times and during those adventures been blown up, shot up, fallen off my skis, and been knocked off my motorcycle(s)! I have had more broken bones than anyone has a right to have had! and because of that when I'm cold I hurt! Having a block heater switch on at 4am will help both the car and me feel better!
so - now that you know my life's history! and why I want to install a block heater, I still don't have an answer to my original question.
John-
Edited by JohnnyTSi, 26 November 2019 - 12:20 AM.
  • Tim, Enshiu, shawnhayes and 1 other like this
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
  • 9,795 posts
John-
Best response ever..Kudos my friend....I honestly wish I could help you with this...I know about hurting when it’s cold
  • 5,135 posts
John-
Okay.  I suggest installing the OEM block heater, AND a dipstick heater, AND if you can find one of the old stick on oil pan heaters I'd strongly suggest them all.
  • 505 posts
John-
LOL!
Just forget the block heater and drive it like you stole it!
Besides, you might hurt your back installing it. (J/k)
  • Enshiu and Ian201 like this
  • 359 posts
I just warm it up before drive (idle like 15min)
JohnnyTSi
JohnnyTSi
  • 43 posts
I have installed the 12v solutions remote start kit and do start it a few mins before I leave! It is well known that letting a cold engine idle really isn't good for it so I'd like to get the block heater installed.
John-
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
JohnnyTSi
JohnnyTSi
  • 43 posts
There is no way to get this installed from the top - there just isn't enough room to get my hand snaked through the wiring and the coolant 'Y' pipe. I have a ported intake manifold that I need to install, I should be able to get it in with the upper and lower manifolds off.
Here is a better view of how it installs in the block:
  • Tim, 7racer and shawnhayes like this
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
  • 5,135 posts
John-
This is absolutely true down to some really stupid cold temperature.  I don't know how low that temp is though.  I think it's something like -50 C.  Below that, start and drive can be harmful without block heater or start and idle for a while.  Still hard on wear and carbon buildup though.
  • 5,135 posts
Let us know how it goes.
