DIY Pressure side De-Fueler less than $30
Posted 03 October 2019 - 07:05 PM
- Tim, 7racer, thehelix112 and 2 others like this
Beautiful Blue FBO 2013 R35 GTR
655/638tq Daily Driven street thrasher!
Cobb 3" Intakes
SBD Race Intercooler with TiAL BOVs
Cobb catted Down Pipes
Cobb mid pipe modded with a Borla resonator
MAP Muffled 3.5" cat back
ASNU 330 pumps
id1300x2 injectors
Visconti Flex Fuel kit
Omni 4bar Map sensor kit
Cobb Fuel Pressure sensor kit
Torque Solution Maf Block-off Plates
Posted 05 October 2019 - 08:12 AM
Posted 12 October 2019 - 08:39 AM
- Tim likes this
Posted 25 October 2019 - 04:13 PM
CAUTION - The fuel tank can be under pressure when the car is warm, make sure to open the fuel tank cap and equalize pressure before disconnecting the fuel lines.
- Tim, 7racer and Ian201 like this
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
Posted 25 November 2019 - 10:13 PM
I only need to do this once for a car show that requires less than 1/4 tank of gas...
Thanks!
2010 GT-R - Matte Gray, AP/Carbotech, BSE trans cooler, BSE tune on ECUTek, H&R sways, AMSOIL, NASA-AZ TT2 and occasional DD
Posted 26 November 2019 - 12:02 AM
Dumb question but I’ll need to do this for the first time ever. Will the pumps run indefinitely with the ignition on but engine not running?
Thanks!
1. Open the gas cap to release any pressure in the tank, if the fuel is warm from driving, the tank builds up pressure when you stop and will spray gas all over when you disconnect the fuel line.
2. install the tool into the fuel feed line on the car (the big one)
3. close the valve completely
3. start the car
4. slowly open the valve until a steady stream flows out the discharge hose. Be careful not to open it to far or the car will starve for fuel and stall
5. monitor the fuel can so you don't over fill the can and spill fuel on the ground
6. when the car's tank is nearly empty you will hear a gurgling, sucking sound coming out of the fuel line, this is the primary pump picking up air
7. turn the car off, your tank is very close to completely empty.
OF NOTE is that the pumps are cooled by fuel flowing around/through them, you could run the car until it stalls, but that may cause the pumps to get hot. I've seen it done like this several times without issues. I don't let my car run completely out to the stall point though.
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
Posted 26 November 2019 - 12:33 AM
3. start the car
Ahhh, this setup allows the engine to run while siphoning off just enough gas. Got it - thanks!
Posted 26 November 2019 - 06:06 AM
Posted 28 November 2019 - 02:25 PM
Another simpler option is to disconnect the sending sensor harness under the back seats
Huh! Maybe I'm doing it wrong? How does this help empty the fuel tank (including the saddle tank?)
John-
Cobb 3" Intakes
ASNU 330 pumps
id1300x2 injectors
Posted 28 November 2019 - 04:14 PM
3. start the car
So I tried this yesterday except I used the return side. No parts or tools necessary, just unhook it and put a funnel with a hose attached to catch the running gas. It was painfully slow. After 45 mins I had only gotten about 4 gallons out. We wound up driving around some highways at high boost and that burned it off much quicker. If I had used the pressure side would it have come out faster?
Cheers!
Posted 28 November 2019 - 09:25 PM
Cheers!
Even if you ran the car “dry” from the return line, you would still end up with a half-full gas tank, since without return fuel flow the siphon system would not transfer fuel from driver’s half of the gas tank.
- elf_cruiser likes this
Posted 29 November 2019 - 01:05 AM
Copy that, but if starting with a half tank then you’d end up with a quarter tank, yeah?? No wonder it was so slow...
