Clutch relearn after trans oil change?
17 replies to this topic
GT-ARR
GT-ARR
  • 17 posts
  • Joined 10-May 19
As above. When you do an oil change of the trans, do you have to make it relearn? Buying a Cobb AP just to do that is very expensive
  • 1,675 posts
GTRTech at the shop can do that for you. If you have a good relationship with your local dealer can possibly do it on the side.
Other benefits to have a Cobb than just a relearn especially if your a CBA/DBA.
Piece of advice don’t cheap out on maintenance - you won’t like the bill when that happens especially if it’s trans related.
Bill@SiR
Bill@SiR
  • 476 posts
  • LocationMiami FL
Or $250 for an EcuTek bluetooth and can do it yourself from the comfort of your IOS/Android device!
GT-ARR
GT-ARR
  • 17 posts
  • Joined 10-May 19
Thank you for the response. The fluid change is done from a reputable tuner shop.
I don’t know anything about ECUtek. Can it also change touch points and capacity settings? Sounds like great value if it can do it all. Also will I run into warranty issues using ecutek?
bigc
bigc
  • 9 posts
  • Joined 31-December 18
  • LocationLos Angeles
^ Yes, it can do both.
I can't comment on the warranty, but stealerships can generally tell if the car has been tuned.
2017 Nissan GT-R, FBO+E85, Pearl White on Rakuda
2013 Infiniti G37 IPL Convertible, Moonlight White Pearl, "Lucy Jr." - sold
2005 Infiniti G35TT Coupe, Ivory Pearl, "Lucy" - sold
Bill@SiR
Bill@SiR
  • 476 posts
  • LocationMiami FL
Yes read and clear codes, change touch/capacity settings, module learning like ABS.  Zero warranty issues if you do not tune it.
GT-ARR
GT-ARR
  • 17 posts
  • Joined 10-May 19
That’s great. Thank you for the feedback. Long story short, I don’t trust the dealers to do things right. One dealer has 2 techs that don’t know what can be adjusted (even though the owners manual says adjust before track) and the other dealer’s tech only adjusted One clutch pack and he put the capacity at 7!!!
GT-ARR
GT-ARR
  • 17 posts
  • Joined 10-May 19
So apparently a shop said that ECUTEK does leave some codes in the car so if let’s say my transmission fails, Nissan can trace it back to me adjusting the transmission.
  • 1,675 posts
Anytime your ECU is flashed or even replaced it’s logged. No way around it. Whether or not Japan in this case voids your power train warranty is a case by case base and data is typically only sent if it’s a major catastrophic failure (engine, trans). Never heard of anyone denied warranty for anything else.
I had MFD, Bellhousing, headlight warranties as a fully built A9.
  • 521 posts
You don’t need to flash your car to use ecutek maintenance tools. It’s literally acting like dealer’s consult tool. Best $250 you can spend on your GTR, hands down.
  • droptopp and Ian201 like this
  • 1,675 posts
^^ what he said
Hijack : @ Haul is your plate Haul S ? If so I was pulling out of Dunkin with Cicio’s donuts on Tuesday when you were pulling in lol.
  • haul s likes this
  • 521 posts
Haha! Yep, that’s me! TSM is practically in my back yard. Love those t-mobile Tuesday iced lattes.
Edited by haul s, 27 June 2019 - 08:46 PM.
Bill@SiR
Bill@SiR
  • 476 posts
  • LocationMiami FL
Go to a new shop
Using the Clutch Learning and Touchpoint tools is the same as a consult tool, just like going to the dealer.  So if going to the dealer voids your warranty then you have a more serious problem.
  • Ian201 likes this
GT-ARR
GT-ARR
  • 17 posts
  • Joined 10-May 19
Thank you guys! In the process of buying and ECUTEK. I am new to GTR ownership and like tracking my cars often.
GT-ARR
GT-ARR
  • 17 posts
  • Joined 10-May 19
I read somewhere that you have to buy the software separately with the $250 usd Bluetooth dongle. Is that right?
Bill@SiR
Bill@SiR
  • 476 posts
  • LocationMiami FL
All you need is a bluetooth and an iOS or Android device.  If you want to flash/tune the car then you need a software dongle.  But if you just want the diagnostic features then bluetooth and a phone/tablet.
GT-ARR
GT-ARR
  • 17 posts
  • Joined 10-May 19
Thanks Bill!
  • 1,675 posts
Glad this worked out for you.
