Idle LTFT, STFT and MAP question
5 replies to this topic
v3n0m
v3n0m
  • 83 posts
I’m trying to learn a bit more about how to tube my car and I’m a bit confused with what I’m seeing at idle.
At idle, I’m seeing LTFT of around +15% but STFT around -15%. Meaning it’s net zero trim, right? Why would LTFT not adjust back down to 0 if STFT’s are compensating?
Also what manifold pressure is typical for idle? Is checking that measurement a good way to spot check for a vacuum leak? Or is the MAP value a computer value?
v3n0m
v3n0m
  • 83 posts
Also how long does it take for the ECU to compute new LTFT values? Is there any way to reset the learned values?
  • 2,796 posts
Depends on model year how fast it learns and unlearns. Stock idle vacuum is about -9-10psi
colo_evo
colo_evo
  • 120 posts
  • Joined 20-September 16
Hard reset will clear ltft
v3n0m
v3n0m
  • 83 posts
Thanks for that. What impacts idle vacuum? I’m sitting at around -10.8 psi, with id1000, 3” intake and exhaust.
Would a vacuum leak impact idle MAP?
  • 2,796 posts
That’s normal.
