Water under the trunk lid: where is it supposed to go?
6 replies to this topic
Fritzbaum
Fritzbaum
  • 5 posts
  • Joined 02-March 19
  • LocationLuxembourg
Hi guys.
It has been raining heavily for a few days here and while loading my trunk, I noticed stagnant water on the right hand side, between the edge of the fender and the trunk lid seal (see picture). The left hand side is dry, so I assume there must be a drain somewhere, which is clogged on one side. Price question: where is this drain located and where does it end so I can try to unclog it, maybe blow it out with a compressor?
Best greetings and have a nice sunday,
Fritz
2015 EUDM GT-R Premium Edition
1985 Rover SD1 Vitesse
1998 Suzuki Bandit 600
1997 Yamaha Virago 535
  • 9,345 posts
Dude I live in Florida where it rains a lot and I’ve never had that problem
  • 435 posts
The drain is clogged. Usually by debris like rotting leaves and dirt. I'm not sure where that drain goes or the best way to clean it but removing the rear bumper is where I would start.
Make sure to always clean that area every time you wash your car and avoid parking car under trees unless you have a good cover.
  • 1,478 posts
Yep drain is clogged. Both corners have a small drain that dumps that water under the bumper cover.
Depending on the year (CBA), check your front tool kit as that is a common problem as well. Water drains from the cowl into the firewall and ends up collected in the tool kit.
AMS has a simple fix.
https://www.amsperfo...sh-shield.html/
5ive
5ive
  • 40 posts
  • Joined 29-March 16
  • LocationGermany Hannover
normally i just close me eyes and blow the s**t out of it lower right and left. If you open the trunk and see some leaves or anything clean asap so it does not clog.
greetings,
Robert
gtrguyinaz
gtrguyinaz
  • 103 posts
  • Joined 26-April 17
A can of compressed air and the fine tube attached may clean out your drain .......I blow mine out once in a while after washing.......
Fritzbaum
Fritzbaum
  • 5 posts
I did some cleaning between the bumper and the body. Seems like the water flows more freely now. Thankfully, there's no water at the front end like droptopp suggested. Tool kit is dry as well.
