Broke something in the Trans. Got this code.
31 replies to this topic
  • 507 posts
When I had this issue I got the "T/M system malfunction" message as well as "engine system malfunction" message and "service engine soon" light.
Is this normal? The engine messages worried me but maybe they show up in conjunction with trans error codes and malfunctions?
Jared@SFS
Jared@SFS
  • 383 posts
  • LocationAlpharetta Georgia
Most likely the ECU code is just the "hey something is wrong with your transmission". One of the reasons most modern cars will light up the entire dash for a single fault, it's every system reporting a code that there is a problem with another system.
  • paparazzi, 7racer and socalaviator like this
  • 507 posts
Thanks Jared. I figured it was something along those lines as I can't imagine anything went wrong with the engine. Engines sounds good, idles well and no ECM DTC codes pop up in Ecutek in regards to the engine.
  • 507 posts
I rolled my car down my sloped driveway in neutral this morning and heard some noises from trans/rear area. Sounded like grinding noise. Could this still be a gear or shift fork?
Jared@SFS
Jared@SFS
  • 383 posts
Less likely a fork, more likely either a FWD transfer gear, FWD output shaft, or still a broken gear and it's got bits dropped just right that the output shaft is churning away on the teeth.
  • 507 posts
Thanks Jared
We'll find out soon enough but I thought that was interesting. Very light noise.
Now that I think back, I remember a customer of the shop showed up one day and had a broken gear. I think I heard similar noises.
  • 507 posts
UPDATE: It was 3rd gear that broke. This gear definitely saw the most abuse since my build.
PPG 2-6 and drop gears being installed by Shep as we speak.
Will the PPG gearset be able to handle rolling launch at around 1100whp and 900 torque? Or is it better to never use it?
  • 1,969 posts
You’ll be fine. Just remember it puts stress on the trans and turbos.
  • socalaviator likes this
  • 507 posts
Thanks for chiming in. I was aware of the extra stress but not sure of there was any "recommended limit" to it's use. I really want to just use it against one guy haha
  • 1,969 posts
Yeah no worries - lol it’s addictive so be careful. Same G’s as launching the car from a dead stop lol.
Have fun and of course video it ;)
Jared@SFS
Jared@SFS
  • 383 posts
Its fine to do rolling launch, the gears aren't as beat as the clutch, turbos and exhaust valves with rolling launch. Just don't hold it more than 5 seconds before launching. Check with your tuner as well, if its very aggressively setup you won't want to stay on it for more than 3 seconds.
The harsh transition from loaded to unloaded is what really beats the gears, and since the gear is technically loaded on rolling boost, you aren't hitting the "weak" point of the gears.
  • 7racer and socalaviator like this
  • 507 posts
Thanks for the tips. And as you mentioned previously, I will also be upshifting to the next gear before letting off to reduce the gear stress. Now I understand why the road course guys break even aftermarket gear sets.
  • Jared@SFS likes this
