Broke something in the Trans. Got this code.
31 replies to this topic
  • 450 posts
Top of 2nd gear around 6k. revs shot up fast after break. Then heard grinding sound and trans won't shift out of 2nd gear. 2nd gear barely moves and makes grinding sound now. Got Trans code P2841-00 "Shift Fork D position circuit/range performance"
Is this what happens when you break a gear? It's a Shep 2.5 Trans build.
  • 2,801 posts
Or a fork.
  • 450 posts
Or a fork.
Happy New Year Doug and thanks again for your reply.
Yup. Fork or gear.  Just curious if this error code was common for either scenario.
Why do the Forks break on higher power builds?
  • 2,801 posts
How much torque does your car make?
  • 450 posts
850 ish on 2 bar map.  It was gradually fed in to help save the gears. I usually drove around with the 750 torque map.  I knew that 850 was playing with fire even though the torque curve was fed in gradually.
I think the addition of sticky tires and boost by gear increased in 2nd gear did her in ;(
Edited by socalaviator, 31 December 2018 - 05:50 PM.
  • 2,801 posts
You can flex the gear shaft above 800tq which can break the forks or mess up the gears. Pull the pan off and whatever falls out will tell you pretty quick ha.
  • droptopp and socalaviator like this
  • 450 posts
Haha. Yup. We will see soon enough!
Geno88
Geno88
  • 70 posts
  • Joined 21-June 18
sorry to hear that!
  • socalaviator likes this
  • 5,083 posts
fe9d3320ef07b1110874a9c73c9feef032020a9b
I'm sorry dude. You have my sympathy. I was there.  THREE  TIMES.
I feel your pain.
  • 450 posts
I feel your pain.
Ah geez!! 3 times?!
On aftermarket gears or OEM gears?
  • 5,083 posts
Ah geez!! 3 times?!
OEM.  Seals and pressure sensors every time.
I had Forged Performance build it with Dodson Parts until it was faultless.  The second and third times were version 1 sensors from Dodson.  The later ones were flawless.  it seemed.
  • 450 posts
I see. My weakest link in my build is the OEM gears 2-6 and that's exactly what may have broken. Otherwise the Shep 2.5 Trans is flawless as well.
  • 1,670 posts
Sorry to hear. Hopefully a fork vs gear.
Jared@SFS
Jared@SFS
  • 383 posts
  • LocationAlpharetta Georgia
Sounds like a 2nd gear break, once you are in gear its not super common for the shift fork to break, it happens, but most likely the stock gear finally checked out.
Had a customer on a stock block refuse to change driving habits and went through 3 sets of stock gears before finally upgrading the trans to handle his driving(It might have been the only promax/Dodson HD straight cut behind a stock block).
  • Tim, 7racer, thehelix112 and 1 other like this
  • 450 posts
My wallet hopes the same but part of me is like fuck it. The trans needs to be opened anyways so I might as well fork out the money and replace gears 2-6 so I don't become like one of Jared's customers. haha I'd really like to not have to do this again. At 850 torque and a set of gears I think I may be pretty bulletproof
haha wow. He got really fed up after the 3rd break huh? Straight cut gears.
Shep quoted me a good price for some PPG 2-6 installed. Im already running the PPG 1st gear and shaft.
  • 450 posts
Do you guys think there will be any collateral damage inside my trans from a broken gear and/or broken fork? What are the chances?
Jared@SFS
Jared@SFS
  • 383 posts
Fork, almost never, a 2nd gear break would potentially only destroy things you would be replacing anyway. You might have a damaged oil pipe, but if Shep's parts shelves are like mine, he's got plenty of them from the parts transmissions over the years. Gear speed sensor may have been damaged. If you've managed to damage the shift control body, go buy a lotto ticket.
Also since I didn't mention it, if you make a lot of power, and are on stock gears, avoid high RPM engine braking, at the end of a pull, upshift and get the revs down and then lift. The sudden transition of loaded high power to engine braking causes a basal failure of the gear, and you spit teeth off. Also a lot of down shifts to get the rev match and engine braking can do it(Why stock power road course guys can break gears). That's what my customer loved, the rev match roar.
  • Tim, 7racer, droptopp and 1 other like this
  • 9,456 posts
Good info Jared!
  • 450 posts
Wow. Never knew. Great info for a lot of us. Thanks!
  • 1,670 posts
Rev match roar - lol - expensive like ;)
