1000+ WHP crank case VTA, 10 AN fittings, air oil separator
30 replies to this topic
Formidable
Formidable
  • 446 posts
  • Joined 24-December 15
The 1000+ WHP crank case air oil separator vent to atmosphere market for the GTR is seriously lacking. The ones on the market either have the wrong filter, ugly design, not enough clearance, or not enough volume. I commissioned Gabe @rampage_fab to design a large catch can with 10 AN fittings, baffles, and stainless filling that will drain to the oil dipstick. His prototype is pictured here. Fasteners are grade 5 titanium from @titanium_works1. All in the details. Outstanding work from Gabe as usual. This is a great option for those with 1000+ WHP builds.
Im sure Gabe will post the can on his site soon.
https://www.rampagefab.com
Edited by Formidable, 03 December 2018 - 08:59 PM.
  • celsius, 7racer, mstaudt2003 and 1 other like this
celsius
celsius
  • 332 posts
  • Joined 31-December 12
Looks great! Gabe sure is a fabrication guru!
  • Formidable likes this
J5isalive
J5isalive
  • 401 posts
Looks similar to TopSpeed Motorsports with less ports...
  • ghostrider likes this
Formidable
Formidable
  • 446 posts
I had the TSM can. Don’t be mistaken. This rampage fab can is larger, precisely cut to fit the timing cover to sit deeper with more volume and clearance, has more baffles/internal chambers, with an appropriate filter and cover, and two instead of one mounting bracket, (TSM provides a single bolt hole to mount their can). There are three side 10 AN ports inserted lower to route lines out of the way and one 6 AN port at the bottom for the drain... AND... If it isn’t obvious enough, Gabe’s workmanship and welds are spectacular. Additional pics below.
With that said, if anyone wants my TSM can please send me a PM!
Edited by Formidable, 10 December 2018 - 11:04 AM.
  • 9,227 posts
Yeas Gabe does do nice work!, to bad he works with Riggs! I’m sure there will be a SBD version here soon
  • 7racer, Doug@WGP and Formidable like this
Dv8
Dv8
  • 118 posts
  • Joined 14-March 13
id be pissed if i bought a rampage part then it got branded SBD in any variation.
how it compare to the BL catch can? how big is big enough?
~Dv8
Edited by Dv8, 04 December 2018 - 04:19 PM.
  • Tim and Formidable like this
 4/28/18 8.81 @163MPH
Changes Coming| NHRA Licenced GTR 8.5
Formidable
Formidable
  • 446 posts
Volume is a known issue. A few cars running smaller cans have blown oil all over the track, one of which caught fire at a recent event.
Boost logic is a GREAT can for big power. Three things this Rampage can offers for your consideration.
1. This can is bigger.
2. I don’t know how many baffles boost logic puts in their can. More baffles help with collecting oil, which means less oil in the engine bay. I have seen the interior of this can. There are SEVERAL baffles stuffed with stainless mesh.
3. Style. This can has all side ports. BL has one front mounted which makes it difficult to hide the line. The other style point is the cover. Not a huge fan of the BL cover. Gabe mentioned that the covers for this can will be offered in both aluminum and titanium.
~Dv8
  • Tim and Dv8 like this
  • 386 posts
Where did the oil blow out from?
Dv8
Dv8
  • 118 posts
But how big of a can is really needed?
How much pressure gets past the rings ON A HEALTHY MOTOR SEEING 35+psi at 9krpm? Is it really that much??
Y does T1/AMS still use a sealed method on the high hp cars? I know the intake pulls vacuum on the can. Still seem less safe that a full VTA.
~Dv8
Dv8
Dv8
  • 118 posts
Also, where’s the drain back tube is Rampages setup?
Formidable
Formidable
  • 446 posts
Not sure on the exact details regarding the blow outs. Just heard second hand and immediately scratched off the list. No thanks.
The bigger builds don’t use sealed systems. T1 sells an adjunct to their AOS that is a VTA that attaches to the front bumper beam.
The return is a 6AN port lined to a modified dipstick with a 6AN side port located at the distal end.
  • Dv8 and CasualObserver like this
gc1000
gc1000
  • 20 posts
  • Joined 12-September 18
Removing all TSM items from your car?  This can looks nice.  The welds and fabrication look top notch.  I guess I would just like something to look more different than whats out there already.  This does look very similar to TSM and BL.  Most prob wouldn't notice any difference.
Also, does the left mounting bracket look a bit crooked.  Maybe it's just because it's the prototype.
The square corners make the overall feel a bit too "shoebox" for me.
In this day and age, shouldn't all this stuff be finely ball milled billet aluminum, or at least "formed" aluminum sheet with  nice shapes?  Box and Pan stuff seems kinda 'old world' these days.....
Formidable
Formidable
  • 446 posts
The TSM can has a foam filter. The can had oil on top of the cover when it was removed. It had one bolt holding it to the timing cover and the can never sat level in the engine bay. It always sat crooked to one side due to the tension of the lines. It didn’t clear my titanium radiator pipe. Metal on metal contact with that pipe and the timing cover due to vibration, (one bracket and a few rubber lines makes for an impressive rattle), and oil visibly on top of the can was reason enough for me to remove it. Did it do it’s job? Yes. Could be it be done better? Absolutely.
Agree. I really liked my old T1 CNC machined AOS. The AMS can is also machined and beautiful. Both of these are unfortunately sealed systems that require VTA adjuncts on big builds... which make them entirely useless paper weights. No one seems to want to invest in designing a proper can. So this is what we are left with.
  • gc1000 likes this
Dv8
Dv8
  • 118 posts
So Rampage includes the modified dipstick tube like T1 etc?
~Dv8
gc1000
gc1000
  • 20 posts
I could make whatever you wanted, just saying.  I'll machine your name into it if you want.
  • Tim, 7racer, elf_cruiser and 1 other like this
wspy
wspy
  • 255 posts
  • Joined 04-January 13
  • LocationJamaica WI
Now there's an idea  :ponder:
Formidable
Formidable
  • 446 posts
Yes, Gabe is working on providing a modified dipstick with this can.
~Dv8
Yme
Yme
  • 47 posts
  • Joined 31-October 16
Gabe does great work.  I have his FMIC and intercooler piping.
gc1000
gc1000
  • 20 posts
Beautiful!
Cicio@TSM
Cicio@TSM
  • 1,043 posts
This is a beautiful piece but with all due respect I think saying it is superior to our can in every way is very presumptuous.
We took 3 years designing out can, I have all kinds of data from half mile crank case pressure on setups as high as 1800hp.   We tested, redid, tested, redid, tested some more and 90% of the tech this can you had built utilizes came directly from ours.
Again, no biggie, great looking piece.  It looks nicer than our older cans like you have and you are correct ours doesn't fit with a titanium radiator hose.
Like I said on Facebook I'm not calling anyone out for copying or wining about it, but until it's tested and there is data provided I don't think it is right that "better than the TSM one in every way" is just thrown around.
Aside form all that I will say again that it looks great!
  • ghostrider and socalaviator like this
~Cicio
***TOP THREE TSM 1/4 MILE***
-7.37 & 198
-7.47@194
-7.59@189
***TOP THREE TSM 1/2 MILE***
-225.9 MPH
-221.3 MPH
-219.5 MPH
-FL2K 2015 Overall 1st Place
-TSM ELITE Plus Stock Frames @ 7.98@169
cicio@topspeedmotorsports.com
TopSpeedMotorsports.com
**AWD Dyno Tuning
**Parts, Sales, Service
