Quick Track Prep
45 replies to this topic
GT-R2D2
GT-R2D2
  • 30 posts
  • Joined 04-March 15
lol uh oh......
btw who else was running in your group?
Well you know I probably ought to be prepared in case this situation ever happens again.  Seems like the responsible thing to do...
Really not a whole lot to note in my group.  A couple of pretty stout BMW F8x's, a well sorted E36 that wore out my bumper through the twisty parts, fbo gtr that I was never in the same place at the same time as.  The standout was a gorgeous Aston Martin that blew my doors off a couple of times.  Other than that really not that much.  I was only in intermediate since I'm still very new to tracking but the advanced wasn't quite what I was expecting either.  The first time I was there in October for the edge addicts event it was like a freaking car show.
  • Tim, 7racer and thehelix112 like this
GT-R2D2
GT-R2D2
  • 30 posts
Would a square setup of 285/35/20 Nitto NT01s on the oem wheels be a decent setup?  Different widths of the wheels cause any issues?  Better than the 285/345 MP4S setup would think?
Have a little footage of a car behind me at COTA - the body roll is serious with this one.
VDC off - is it really a warranty issue?  Is it just if something happens during the time it was off?  Really enjoy running with the nannies turned off in my M3 - wondering if this is something to even consider in the GTR at this point (due to warranty).
Thanks!
gtrguyinaz
gtrguyinaz
  • 98 posts
  • Joined 26-April 17
Nice clean lap........ I am thinking mid / upper 2:30s  for time. A driving coach would make big improvements ...... He showed me the quick line and shaved 10 seconds off my time.
  • 5,080 posts
Thanks!
That setup of NT01's - yes great setup.  No problems with different width wheels.  I think they are better than the MP4S
The body roll of the GT-R varies year to year.  The 2009's were pretty good, but understeer was terrible.  Sway's help a lot.
VDC off is a problem for launches in the pre-2012 cars ONLY.  The warranty issues were for "VDC Stall Start" - (launch).  They were launched over and over and over killing the transmissions.  LC2 made it not so violent, and for 2012 ups, there is a very advanced launch control logic and a forced cool down after a certain number of launches.
  • Tim, thehelix112 and GT-R2D2 like this
GT-R2D2
GT-R2D2
  • 30 posts
If I add sway bars would there be any advantage of going with a 285/35 & 315/30 NT01 stagger on the oem wheels  (27.87" x 27.48" OD) vs the 285/35 square setup.  Can use the sways to work out any understeer the stagger might introduce?  And then have the benefit of the larger tire in the rear?
Or am I looking at this wrong?
  • 5,080 posts
The advantage of larger rear tires is to add lateral grip.  Makes the car more stable in a straight line, and is MOST useful in a drag mode.
Sways work by REDUCING grip by tying the wheels together one side vs. the other.
NO advantage to FIXING better grip with bigger sway bars other than reducing tire wear (this DOES work, honestly).  I did a 285 square setup with Forged Performance bars (the biggest that can be purchased to my knowledge) and it made the car very balanced with very good tire wear (except for the rear inside on very abrasive tracks).
Whatever you do, you make DAMN sure you roll out the tires to make sure they have the same outer diameter with very little difference.  Measurements on Tire Rack are not good enough.  Many a FWD unit destroyed from this mistake on a GT-R.  I do not know about the NT01's in those sizes if they are close enough.  Can't tell without a roll out according to my sources.
GT-R2D2
GT-R2D2
  • 30 posts
Thanks Shawn - that makes sense & is what I was trying to figure out.  285 square it is, have them on the way now.  Thanks!
GT-R2D2
GT-R2D2
  • 30 posts
I’m back... so 285 square NT01s were a big improvement. Also had a pretty open track so felt comfortable switching off vdc - so much better. The GT-R is not going to take the place of my TT3 build that is getting ready to start on my M3 but definitely going to get its share of track time moving forward.
So here’s the plan:
FBO w/E85
DSC controller
SPL bits for that camber
BBK (likely Essex / AP Racing f & r)
Trans cooler (likely HKS)
Dedicated wheels & tires setup
I’m kind of stuck on the wheels and tires right now. Definitely want to run square and would like to to keep the same offset front & rear if possible. Really like the NT01s - would like to stick with them for a bit too. Think 325/30/19s will fit the front? 315s would have to be in 20”. Any recs here? If custom I know there’s forgeline, finspeed, anyone else to look at?
Need to figure out something to hold me in the seat better as well. Stocks seats suck at the track on an 18.
  • 4,221 posts
Hey man, sounds like a solid plan.  Lots of discussion here about front tyre sizes.  I think you can squeeze a 315 under the front with stock fenders and upright but it won't be on the ideal rim width.
Re harness, here is the DIY I made a while back: http://www.gtrherita...ge-6#entry74728
Enjoy!
  • GT-R2D2 likes this
GT-R2D2
GT-R2D2
  • 30 posts
Enjoy!
That is absolutely perfect - thanks! Actually tried to contact Schroth a couple of weeks ago to see if they had something like what you posted but didn’t get too far. Ordering that exact setup right now - much appreciated!
Yeah I definitely need to keep digging on wheels/tires.
I know the front and rears need to be real close outside diameters - being square that won’t be an issue. But how about what that OD needs to be? Is there a range that the tire OD’s need to fall in? For instance something like they need to be between 26.34 and 27.85 or something like that?
  • 7,670 posts
not really...some of the guys run slicks with smaller diameter.  I road in incarus's car with smaller diameter tires and it gives the car a bit of quickness..  Just as long as they are the same F&R
GT-R2D2
GT-R2D2
  • 30 posts
Ok great - just wanted to verify before jumping off with certain tires in mind.
So I'm thinking of going with 19x11s - use the correct offset for the front at all four corners with spacers at the rear to get back closer to stock track width.  Go with the Nitto NT01s in 305/30/19 for now - and if want to move into slicks later something like the Hoosier R7 in either 295 or if can get the 315 to fit.  This sound reasonble?  Any issues with spacers on the track?
  • 4,221 posts
Sounds like a good plan. I think that's very close to what elf does too.
Send us pics as it evolves!
  • 7,670 posts
also, I have to remember how, but you can get in the MFD and change the MPH offset to take into account different tire sizes to have a more accurate MPH reading.
have to find that thread...
  • 5,080 posts
You make damn sure your spacers are the pass through kind, with extended studs, and not the crap kind with studs mounted into them.
This.....
2PCS-15mm-5x112-66-5-Wheel-Spacers-suit-
Not this....
Edited by shawnhayes, 01 January 2019 - 06:03 PM.
  • thehelix112 and GT-R2D2 like this
  • 756 posts
If use spacers, use the longer (ARP) studs to allow pass through of the studs. You should replace the OEM studs anyway, as I have seen many fail on track.
19x11 ET 25 wheels will fit square. Elf_cruiser runs/ran these - not certain of tire widths he ran on these, though.
  • 1,961 posts
Sorry, just saw this! Yes, I ran 19x11’s for years with 205 and 325 Toyo R888’s. Hoosier now makes the R7 for 19’s which would be even better.
Honestly though, I changed to 18” wheels about 2 years ago and couldn’t be happier. Tons of tire choices, and they’re lighter. Currently I’m running 18x11 Forgestar CF5’s and they hold up pretty well to track abuse. My wife bent one awhile back when she went off track and hit the backside of a curb at speed. It was a hard hit, and probably would have probably bent a full forged wheel too - or broken it.
Cheers, and good luck with the GTR Mods!
  • 7racer, thehelix112 and GT-R2D2 like this
  • 4,221 posts
205 r888s? 295?
  • 1,961 posts
Typo, haha! 305’s
GT-R2D2
GT-R2D2
  • 30 posts
Much appreciated everyone!
Studs/spacers - appreciate the heads up - planned on swapping out to the ARP coarse thread studs that were recommended in another thread here. Will not skimp on spacers if I do end up needing them as well.
Wheels - been going back and forth quite a bit on the bbk and wheel fitment with the manufacturers the last few days & looks like 18” will work like elf cruiser said. Was recommended ET25 as well. So planning on 18x11 with Nitto NT01 in 305/35/18. Shouldn’t have to run a spacer in the rear and should be okay in the front with this offset, right?
