downpipes+ypipe+? stock exhaust or aftermarked
6 replies to this topic
Vanilla
Vanilla
  • 28 posts
  • Joined 01-November 18
Hello, I have a question I couldn't yet find the answer to:
if I was running efr's 6758 with up to 700 lb ft how much would I gain or loose by using either stock exhaust or aftermarked exhaust (lets say 4")
...connected to 3" catless dp's and twin 200 cell cats silenced y-pipe.
my main concern is noise which I have to keep down due to regulations here. So if I was to change the exhaust I would only do it for power ;)
(Only quiet 4" exhaust on the marked seems to be the Litchfield one!?)
  • 7,740 posts
in the US there are A LOT of 4" options.  How much HP are you putting down?
  • 465 posts
You can use an exhaust cut-out with your stock exhaust. That way you can remain very quiet but open the exhaust cut-out when you plan to go full power.
Vanilla
Vanilla
  • 28 posts
yes I've seen the cut out option, would be nice to have. but I would be in big trouble using this as police do check under the car here when you get stopped. they know all the tricks.
so cut-out or valved system is not an option. only a quiet 4". and I'm wondering if its worth the $3000 premium over the stock exhaust regarding power gains?
  • 465 posts
Hmmm...tough call. Even the quietest 4" exhausts aren't what I would consider quiet.
How about HKS resonated midpipe and HKS Legamax exhaust?. That is a full 90mm system and very very quiet.
I think a 90mm system is sufficient for 6758 EFR turbos.
5ive
5ive
  • 46 posts
  • Joined 29-March 16
  • LocationGermany Hannover
you wont lose any power if you use big cats i have 6758 with 100 cpsi 130mm cats. Now i found 100 cpsi 150mm cats, with 200cpsi u need to go big like 150mm cats. With 100 cpsi and good tune there is no smell. Which country are u from ?
greetings,
Robert
5ive
5ive
  • 46 posts
i Sent you pm i can give you all information u need for germany.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
