TSM 3,8 & ETS Pro1700 Project 1300+ WHP
76 replies to this topic
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
Guys!
I started dreaming about that project long time ago.
Cicio was always helpful. I called him anytime. He always kindly answered my stupid questions :) I have changed the concept many times. Cicio showed exceptional patience to me. Talking to him is pure pleasure. Feeling that he knows what he is talking about. He has huge experience. At the same time a good sense of humor.
When Cicio did send me photos of my baby engine, my eyes were wet;)
I'm very exited about outcome. Will update with progress.
Cicio was very kind and shared his experience and knowledge with me. I appreciate that a lot.
I placed order on 5th July.
Engine and tranny were ready on 16th September.
Two crates are on the way to Poland :)
Parts used:
TSM 3.8L Billet Crank Short Block; Nissan GT-R-TSM Spec Machine Work
-TSM Spec Oiling Modifications
-TSM Spec CP Custom Pistons
-TSM Spec Carrillo Connecting Rods -SM Spec SB Billet Crank
-Nissan Bearings (Not stock sizing) -ARP Main Studs
VR38DETT Short Block Core Charge GTR Crank Woodruf Key
ARP 625+ Head Stud Kit: Nissan GT-R VR38DETT TSM Custom Spec Headgasket - TSM 3.8 Liter SB w / Block Modification (Left Side) WOH
TSM Custom Spec Headgasket - TSM 3.8 Liter SB w / Block Modification (Right Side) WOH
GTR Engine Gasket Kit; Early
Nissan OEM Three Bond Gasket Maker
GTR Timing Chain Tensioner A - Main Chain
GTR Timing Chain Tensioner B - RH Cam
GTR Timing Chain Tensioner C - LH Cam
GTR Oil Pump Chain Tensioner
GTR Primary Timing Chain
GTR Secondary Chain (2 required)
GTR Oil Pump Chain
GT1R VR38 V2 Billet Pro Harmonic Damper; Billet Steel Construction; SFI 18.1 Certified.
GT1R CNC Engine Oil Pan and oil pickup adapter. O-ring for pickup adapter is brown -120 size (qty 2). Includes RHP 814-06-2 drain plug. 1.48 quarts additional capacity.
TSM Products Large Volume Oil Filter Upgrade Kit - R35 GT-R
-Includes 2x WIX Racing 51060R Filter
TSM GT-R Level 1 Street Ported Cylinder Heads
-TSM Valve Job
-TSM Level 1 Street Porting
-TSM Precision Assembly
-GSC Beehive Spring & Retainer Kit
-GSC Intake & Exhaust Valves
-GSC Bronze Valve Guides
VR38DETT Heads Core Charge (Includes both cylinder heads, spark plug tubes, and buckets)
GSC S2 274/274 Duration Camshafts; Nissan GT-R (upgraded valve springs required)
HKS Iridium Spark Plug R35 GT-R - One Heat Range Colder
ETS Nissan GTR R35 PRO Series Turbo Kit - PRO1700 w / 3.8L Modifications & PRO Series Y Pipe
Nissan Exhaust Nut (all new hardware for exh manifolds)
TSM Air Pump Delete Block Off Plates - Nissan GT-R TSM GT-R Oil Catch Can
AEM Boost Control Solenoid Kit
Omni Power 4 Bar Speed ​​Density Coversion Harness Nissan GT-R
Boost Logic 3.5 "Titanium Intakes for R35 GTR without MAF Flange
ETS Nissan R35 GT-R Race Intercooler Kit - Add BOV Pipes (TiAL) - Stock Int Manifold, Stock TBs
Tial Q BOV in Silver 11LB Spring
Injector Dynamics 1725cc injector set for R35 GT-R TSM Fuel Rail Kit With Regulator; Nissan GT-R Gotboost Flex Fuel kit for R35 Nissan GT-R
Fore Innovations GT-R Triple Fuel Pump Module - 3x Walbro 274 Pumps, OE Line Adapter Fittings
FC3 Dual / Triple Pump Staged Controller with 4 AWG Wiring Kit
DODSON GEARSET UPGRADE
Dodson Pro Max clutch / Alloy version (Sheptrans spec) Dodson Heavy Duty clutch back spring retaining clips Dodson Piston shaft seals
Dodson FWD retainer
Dodson Mechanical lock # 1
Dodson Mechanical lock # 2
Dodson Selector Piston Shims x 4
Dodson O-ring and seal upgrade kit
Dodson Oil pump shaft upgrade with blueprint Dodson Reusable transmission filter
6 neodymium magnets
Dodson High temp rear differential oil seal
ShepTrans FWD ball retainer
ShepTrans Billet front thrust plate
ShepTrans FWD clutch Fluid
OEM Fwd output seal
Dodson 2,4,6 Thrust bearing circlip
Dodson 1,3,5 Thrust bearing circlip
Oem Nissan transmission pan gasket
Transmission and Rear differential Fill plug gasket (2) Rear differential drain plug washer x1
Oem Nissan Rear differential side seals
GT1R rear diff brace
Arp Rear diff bolt upgrade
Dodson Surge / Baffle kit
Dodson Billet Drag Pan Kit
Dodson Rear Reduction Gears (Drop Gears)
GT-R transmission core charge (will be refunded)
DSS Nissan GT-R 33 Spline Pro-Level Rear Axles with DSS Rear Axle Stub Shafts
ARP Extended Studs GTR, WRX, STI
Muteki SR48 Lug Nuts - 12x1.25 48mm Black (Open Ended)
Amsoil Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid - 2.5 Gallon
TSM GT-R Transmission Catch Can
Cobb Tuning AccessPORT for 2015+ Nissan GT-R w / TCM Flashing
Edited by Peter GT-R, 27 October 2018 - 02:55 PM.
  • 7racer, Formidable and KennethdEw like this
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
I was very bored while waiting for the engine and transmission.
That's why I changed the interior of my beloved car. Now there is no plastic in it. The reigns of alcantara, leather and carbon.
I have decided to go with RECARO Sportster CS, these are much lighter that OE (30 lbs). We managed to put OE air bags into new seats, I do not loose safety! New seats are more comfortable during driving. Unpleasant getting in and out of the car
The friend of mine is RECARO importer in Poland - I have paid $ 800 for pair of seats :)
  • Tim, 7racer and Formidable like this
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
And here are some pics after wrapping :)
  • 4,424 posts
Doesn't look terrible at all. Congrats
Formidable
Formidable
  • 516 posts
  • Joined 24-December 15
Build looks good! 👍
  • 1,911 posts
Looking good - google translate into Polish :
piękny skarb
celsius
celsius
  • 481 posts
  • Joined 31-December 12
Congratulations Peter! You made the right choice going with TSM & ETS!
1426 AWHP
8.75 @ 163MPH Tx2k19
190MPH Roll Race @ Tx2k19
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
My wife is not so sure ;)
Build looks good!
Thank you Sir!
piękny skarb
I love it. That is my baby baby...
It looks like that was best choice possible. You can't go wrong with Cicio and his crew. Thanx to all who helped me to make right choice while I was kitesurfing in Cape Hatteras :) I must say I love USA. I spend about two months kitesurfing in USA per year. Now heart of my baby was born in USA :)
Thanx to Cicio, I decided to buy front lightweight tubular subframe. Cicio is kind of the man who advice best to customer. Advises the client even if he would not earn. He is a real motoring enthusiast. AK MOTORSPORT owner is the friend of mine, we used to race in 2004 when I won polish 1/4 mile Championship. I was surprised Cicio suggested company from Poland :)
Edited by Peter GT-R, 28 October 2018 - 01:19 AM.
  • Tim, celsius, 7racer and 2 others like this
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
Finally I have mounted carbon brake discs on all 4 boots. :)
These are from Porsche Turbo :)
Formidable
Formidable
  • 516 posts
Nice 👍
One of the best all around mods for the GTR that improves acceleration, braking, steering and handling.
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
After talking to Cicio, I have decided to go with 12 injectors intake manifold & MOTEC :)
  • Tim, celsius, 7racer and 1 other like this
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
I must say Cicio and Mike are incredible! I talked to Cicio last Sunday, informed that I will be in USA this week. They organised all stuff to be ready so I can bring it on the way back to Poland. That is awesome service guys!
Cicio
Cicio
  • 1,121 posts
Happy you are happy!  :-D
  • Tim, celsius and thehelix112 like this
~N.Cicio
***TOP THREE 1/4 MILE***
-7.37@198
-7.39@200
-7.59@189
***TOP THREE 1/2 MILE***
-225.9 MPH
-221.3 MPH
-219.5 MPH
-ELITE PrimeR Stock Frames @ 7.62@180
cicio@cicioperformance.com
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
Week ago I talked to Cicio on the phone about MoTeC, 12 injectors intake manifold. I'm back in my house in Warsaw with all parts on my table. Thank you for great service Cicio & the Crew!
Attached also pics of new Recaro seats custom brackets made by NOWAK-Performance while I was in USA - top quality, light weight, super low mounting like I wanted.
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
Engine is out. ETS Race FMIC is in :)
Sheptrans tranny is in :)
We are waiting for new DSS axles because we received ones for 2009-2015 and we need for 2016-2018
Also we are waiting for right intake titanium pipe because we have received two pipes for driver side
So we have little delay
In the meantime engine covers are getting powder coated :)
  • celsius, 7racer and thehelix112 like this
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
After Christmas brake we are back and new parts are in the car.
We have received DSS for model 2016-2018 and right titanium pipe from TSM - thanx for fast action Mike!
  • Tim, 7racer, thehelix112 and 1 other like this
  • 9,782 posts
Dude you have made a lot of progress.Your car is turning out unreal,and I still can’t get over the price of those seats. :) :)
Peter GT-R
Peter GT-R
  • 65 posts
  • Joined 26-June 18
Thanx Bro!
We have snow on the streets now so I don't miss my baby :)
celsius
celsius
  • 481 posts
Looking good Peter! Which intake airfilter model is that?
1426 AWHP
Formidable
Formidable
  • 516 posts
Build is coming along great! When do we get to see the dyno?
Celsius - those are the boost logic filters provided with their 3.5” intakes
  • Tim and celsius like this
