Misfires at idle
22 replies to this topic
  • 508 posts
I'm trying to diagnose some misfires I have at idle and reaching out for any tips people may have. My tuner/builder is trying to help me but haven't been able to take my car to him yet.
Data logs at WOT are rock solid and spot on. Even at 50% throttle everything looks great.
Cold Idles are rock solid as well.
Once engine warms up to full operating temps is when the misfires begin. Misfires are worse in hot weather and slightly better in cooler (less than 80 degrees) weather but still present.
AFR Bank 1 is 110% to 118% when misfires are present and sometimes pegged at 120%+ . while AFR Bank 2 is usually within 5% of 100.
"Multiple/Random cylinder misfires" and "Cyl 5 Misfire" codes sometimes accompany these misfires.
The moment I rev my engine above 2000 or so rpm misfires dissapear. And the moment I start driving and apply anything more than 10% throttle misfires disappear as well.
I can provide datalogs as I have many for idle misfiring.
Edited by socalaviator, 13 October 2018 - 02:59 PM.
  • 508 posts
Fuel system : Fore Triple with Walbro 430s (the big ones) hardwired with the Ecutek module. Fore post fuel filter mounted in custom location.
Stock rails, stock FPR and stock everything else fuel related.
1700cc injectors
Pump gas or E?
  • 508 posts
Pump gas or E?
E85 (E80 to be exact)
The tune probably just needs adjustment as ID1700 don’t idle well haha.
  • 508 posts
Doug.  That was his first remark to me as well.  lol.
It's not a big deal really but would be nice if it didn't misfire as much.
Other thought is that there might be a tiny air leak in Bank 1 somewhere?
Less likely. Who’s tuning it?
  • 508 posts
Ronnie at RD Engineering.  He's been busy with builds but should be able to look at the logs this week.
I'm trying to troubleshoot in the meantime.
There’s likely nothing to troubleshoot. Set the target to 12.0 AFR at idle and a min idle RPM of 950 and see if it stops.
  • socalaviator likes this
  • 508 posts
Gotcha. Idle RPM is definitely lower than this now and I think Target AFR is 12.7 at the moment.
I'm pretty sure you're right
  • 508 posts
A tiny bit more fuel was added and rpm raised 50rpm and it made the biggest difference in the world.
Target AFR remained at 12.55 as before.
The thing we still need to troubleshoot is Bank 1 is demanding 8%-10% more fuel in short-term fuel trim than Bank 2.
Cicio
Cicio
  • 1,125 posts
That's just the stock FPR talking
~N.Cicio
Email: cicio@cicioperformance.com
240Z TwinTurbo
240Z TwinTurbo
  • 273 posts
  • Joined 06-February 14
Curious as to how the stock FPR would affect bank balance?
DIY700 - 700hp on a Budget
Cicio
Cicio
  • 1,125 posts
I should say factory rails, it’s not just the regulator.
~N.Cicio
  • 508 posts
Cicio. Thanks for chiming in. Can you elaborate more?
Once fuel was added and rpm raised 50rpm it helped a ton. No more misfires codes but short-term fuel imbalance between bank1 and bank2 is around 8-10% difference (Bank 1 demanding more fuel)
Turning AC to ON also helps when there are misfires.
How do the stock fuel rails and FPR play into this?
Btw, all WOT runs are perfect across all measurements. Injector duties in the 80s
  • 508 posts
Yeah now that the misfires are negligible I'm trying to figure out the reason for the short-term trim imbalance at idle. If rpms increased to about 2000rpm imbalance dissapears. Also when car is driven (under load) imbalance dissapears rather quickly and all is normal
240Z TwinTurbo
240Z TwinTurbo
  • 273 posts
Have you performed a bank balance?
  • 508 posts
Not since my last POS service but that was way before my build.
Is this something I can do at home with Ecutek?
240Z TwinTurbo
240Z TwinTurbo
  • 273 posts
same question...how do factory rails/FPR affect bank balance?
Edited by 240Z TwinTurbo, 26 October 2018 - 10:34 AM.
240Z TwinTurbo
240Z TwinTurbo
  • 273 posts
I believe ECUTek has that feature so yes, you should be able to perform it.  Every time I pulled the intake manifold or TB's I had STFT issues and had to perform a bank balance, which resolved it.
