Hardwire install question
5 replies to this topic
valond922
valond922
  • 38 posts
  • Joined 24-March 17
So I started installing visconti hardwire kit late tonight. Got to the end of the install and have two questions. On step six I for the life of me can't figure out where the secondary pump relay and bracket  is to plug in the trunk harness.
And two, when plugging in the harness to the fuel hat it says that:
"Connect the secondary harness Grey (5-WAY) connector to the fuel basket.
Connect the secondary harness Black (5-WAY) connector to the cars Grey (5-WAY) connector.
Connect the secondary harness Brown (2-WAY) connector to the fuel basket.
Factory Grey (2-WAY) Connector does NOT plug into anything"
Now on the kit the secondary harness brown connector has a second 2 way connector on it. Does this connector attach to the factory grey connector and the instructions on visconti's site are for a previous version?
Brett
P.S. I feel like a dumbass asking these questions.  Thanks
  • 2,736 posts
The “trunk” harness relay is in the trunk. Passenger side behind the the trim near the taillights.
The brown connector connects to the pump hat at the secondary pump connection. The secondary pump connector on the oem harness is unused.
  • celsius and 7racer like this
valond922
valond922
  • 38 posts
So the files are "in" the computer? Lol I'm not sure if I misread that part or the instructions are just unclear on that part.
Lastly, is the black plug attached to the brown plug on the secondary harness for a third pump? (As seen in the third picture. If so, does that mean I could use this kit for a triple pump set up like the fore?
Brett
valond922
valond922
  • 38 posts
Doug, one more question if you will. After the install I began having secondary pump issues. It seems as if my pump isn't coming on.  I'm going to check the relays as the install seems more or less straight foreword otherwise (except the trunk relay...lol). Any other suggestions?
Brett
  • 2,736 posts
Occasionally the contacts on the oem relay in the trunk will suck. I’d start there.
valond922
valond922
  • 38 posts
Thanks, I'll take a look at that one.
Brett
