Boost Logic Drag Brake Package for R35 GTR
boostlogic boost logic blgtr ap racing brembo lightweight drag brake kit
1 reply to this topic
Joe@BL
Joe@BL
  • 18 posts
In building a drag oriented GTR we wrapped our heads around designing
a brake kit that can work with the R35 GTR to get rid of the factory
brembo brakes for something that would put the car on a diet and allow
15” wheels for better sidewall tire options. Our kit is designed
specifically for drag racing and will require a parachute. The weigh
savings are tremendous, especially to note the losses are unspring
weight.
OEM BREMBO
FRONT CALIPER – 11.4lbs
REAR CALIPER – 10.2lbs
FRONT ROTOR w/ Pads – 25lbs
REAR ROTOR w/ Pads – 26.2lbs
TOTAL – 145.6lbs
Boost Logic
Front Caliper w/ Pads and Bracket – 4.8LBS
Front Rotor – 10lbs
Rear Rotor – 6.2lbs
Rear Caliper w/ Pads and Bracket – 4.8LBS
TOTAL – 51.6LBS
Reducing the car weight by 94lbs total with 83.2lbs being rotational mass.
Reading
up on rotational weight vs static weight is pretty interesting, here is
a link to a spreadsheet that can calculate some figures for you!
http://www.the-welte.../rotational.xls
These
smaller Rotors & Calipers have also allowed us to run a 15" Wheel
in the rear with the correct offset to get us the biggest tire possible
planted to the ground. *CURRENTLY BEING TESTED*
Due to the spindle in the front being so large we are not able to run a 15" so we recommend a 17" or 18" wheel.
Rear Brake Dust Shields have to be slight modified but everything else is a 100% bolt on!
Front Kit - $1999 MSRP
Rear Kit - $1999 MSRP
  • sports likes this
sports
sports
  • 457 posts
  • Joined 26-December 12
Nice kit, those oem rotors/caliper are heavy ! WHAT size is the new replacement rotors?
Also tagged with one or more of these keywords: boostlogic, boost logic, blgtr, ap racing, brembo, lightweight, drag, brake kit
