No power to fuel pumps
4 replies to this topic
cpthurm09
cpthurm09
  • 6 posts
  • Joined 29-April 17
I opened the car up on the highway and after wards (about 20miles later) stopped at a rest area and when I came back the car started and quickly died. The car cranks fine but does not start.
The fuel pump is hard wired. I did a continuity check on the lines and there is no power to getting to the fuel pump. I hooked the fuel pump up to a 12v source and it worked. All the fuses checked out good and I replaced the relays for the fuel pump and still a no go. There are two wires running from the main harness that I have not checked (a green and brown running off the main harness down the floor panel). I think they run to the ECU.
I am out of ideas what it could be. If the Hobbs switches go bad would it cause it not to start? Could the ECU or the fuel control module be bad?
240Z TwinTurbo
240Z TwinTurbo
  • 273 posts
  • Joined 06-February 14
in addition to the relays are they fused?
DIY700 - 700hp on a Budget
cpthurm09
cpthurm09
  • 6 posts
Yes, they are also fused. I just picked up a fuel pump controller. Hopefully that will fix the issue.
240Z TwinTurbo
240Z TwinTurbo
  • 273 posts
You just need to start tracing power from the source to the pump at all points in between.  Also, make sure you have a good ground.
  • Are you getting power from the battery to the fuse
  • Are you getting power on the backside of the fuse
  • Are you getting power to the relay
  • Are you getting power to the backside of the relay when activated
I chased a similar problem on my EVO a few years back and it ended up being a short in the damn fuse holder.  This should be a relatively easy process to diagnose if you have access.
Edited by 240Z TwinTurbo, 06 July 2018 - 07:47 AM.
cpthurm09
cpthurm09
  • 6 posts
I'll retrace it out again. The car is down in Charleston and I will not be able to get to it until the next weekend. I'll let you know how it turns out.
