New issue (feels like throttle closing or fuel cut) - Logs added in post #6
8 replies to this topic
ASHRAF
ASHRAF
  • 150 posts
  • LocationAl Khobar, KSA
Hello everyone
Just a background, The car is a
Simply built 3.8L Alpha 12
Alpha brushless dual pump system
ID1300x injectors
stock intake manifold and throttle bodies
The issue I have been facing is:
random fuel cut (or what seemed like it to me) at high RPM's, the car would cut off at 6k, 6250. 7k or never! Basically random
This has been going on for sometime now, and I was told it very well could be the Alpha fuel system acting up. Not sure how true is this, but I was told by a very reputable shop that the system is not great when using with more than 1 fuel type/map?
Temps got hot here, and I don't want to floor the car to test it because I don't want any serious damage just to figure this issue out
The second issue, which started recently, and the one I'm really worried about:
I would drive the car around for an hour or so (hot weather), then all the sudden, while cruising at 60-70mph, I feel the car falls on its face almost like I lift off the throttle.
If I give it a bit more gas, it feels like its slowing down even more and dying
If I lift off and give it a bit of throttle it starts accelerating normally
Tried to push it hard once or twice while this was happening and it seems to do just fine!
Temps are reasonable, cooling system is doing its job, and fuel pressure is good and not falling down
I am mostly curious if anyone had the 2nd issue happen to them, and what was the cause/cure!
I really want to work the last few kinks out of the car before we put it on a dyno and get it fine tuned
Kind Regards,
AJ
Edited by ASHRAF, 24 June 2018 - 01:33 PM.
2013 Nissan GT-R Premium #0265 - Alpha 12 - Delivered 03/27/2012
Pearl White/Black
Manley Pistons | Manley Rods | Manley Upgraded Wrist Pins | ARP main and head studs | GSC Billet 264 Cams, Double Springs and TI Retainers | T1R Harmonic Dampener | T1R CNC Engine Oil Pan
Alpha 12 Turbo Kit | Alpha Race Intercooler with Alpha Piping and Tial Q BOVs  | Alpha Coolant Expansion Tank | Alpha Air Oil Separator | Alpha Omega Dual Brushless Fuel Pump System | ID 1300cc Injectors
BoostLogic Quadzilla 4" Titanium Exhaust |  ShepTrans 1K | T1R Transmission Brace
GCC Navigation Unit Swap (legertas) | Start Button Cover (jays2000) | Escort Passport 9500ci with Laser Jammers
20" Advan GT's | Toyo Proxes R888's | KW V3 Coilovers
Revozport DN CF Trunk (With TBL) | Revozport CF Hood | Revozport CF Front Lip | Rexpeed CF Side Skirts | Rexpeed CF GTR Fender Badge Cover | Rexpeed CF Key Fob Covers
logs?  Does the car have a fuel pressure sensor?
ASHRAF
ASHRAF
  • 150 posts
I will post them today, waiting for my buddy to send me the logs as my AP is in a different country right now  :D
Yes the car does have a fuel pressure sensor, and the fuel did not go down so it doesn't seem like it's the culprit
My bad, I will post the logs as soon as I get them
-AJ
Pearl White/Black
  • 1,969 posts
I’m on the dual brushless pumps and have not had any issues but I am on 6 ID 2000s.
Sorry if stupid question, but did you upgrade the fuel lines ?
Injector setup issue ?
ASHRAF
ASHRAF
  • 150 posts
I have heard a lot of people complaining about the brushless system. The comment is it is a great system, but tricky to calibrate and can cause issues, especially if the car is tuned with multiple fuels
All the lines in the car are updated, I have the Alpha rail, line, and regulator kit (we then switched the regulator to what T1R uses in their system, thinking the one I had was problematic). The lines to and from the tank are also upgraded to braided lines and AN fittings
The car is still a 6 injector car, and running a 1300cc ID set
Not sure what can cause such an issue, but I think the consistent fuel pressure rules out a fuel cut, no?
I will post the log hopefully soon and maybe that would give a better idea. Just wanted to know if anyone faced the same issue
The approach I'm taking, is air, spark, fuel
What can go wrong and cause these symptoms (so I can check)
-AJ
Pearl White/Black
ASHRAF
ASHRAF
  • 150 posts
Here are the last set of logs that I and the shop did trying and replicating the issue
Not sure exactly which logs show the issue, but the last bunch are mostly when the issue was happening, some were replicating it while cruising, and some were pushing the car a bit harder where it does not act up
It seems that it only happens after driving the car in hot weather, and sitting in traffic
So it seems like (something) heats up, and starts acting up
We have a feeling, if fueling isn't causing this issue, that it may be throttle(s) related?
What should we look for, test or replace?
Anyone that had and resolved this issue, please enlighten me!
Pearl White/Black
franzcars
franzcars
  • 41 posts
  • Joined 16-March 13
I believe the pumps are putting out wayyy too much pressure/flow for the regulator to keep up. At idle/cruise you're at about 3-4 bar of fuel pressure, at 7psi of boost you are at 7bar, which is close to the max pressure the injectors can handle
2013 Premium Deep Blue Pearl with 285/35 PSS's front, 18"NT05R's rear, SIR USM's, HKS Upgraded Actuators, TiTek 90mm Downpipes, AAM Resonated Midpipe, GotBoost intakes, GotBoost SD kit, Visconti Flex Fuel, Bosch 2200's, Fore tripple pump with with twin 485's DIY hardwired, Ecutek Etune by Bill@SprayItRacing
Appearance: TSW Nurburing rear, Diode Dynamics Tail as Turn with quad backup lights, always on front DRLs, Diode Dynamics LED City, Trunk, Map and License Plate lights
530AWHP with a Cobb OTS stage 1 only
555AWHP with MP/tune from Linney
Best ET 10.52@128 with midpipe/tune/NT05R's
Gone but never forgotten, Memorial Day 2017
New GTR
2009 SS Jack's Built ETS 3582R. From Motown to The Lou, and we're proud
evo911
evo911
  • 2 posts
  • Joined 11-August 14
My car does exactly the same thing 15’ nismo FBO seems to only do it after Decelerating and making a left or right turn , at this point I’m in 2nd and the car yanks like power on off on off on off then goes to normal again. It can be at any rpm but most common under 4K rpm. On hot days it will do it cruising song the highway too in 6th. None of it makes sense logs show nothing and it’s random, more common shortly after into the power then going to cruise or deceling to make a turn. Any ideas? COBB tuner, basic tank pump, upgraded injectors basically everything an FBO car would have excluding turbo swap, still using nismo turbos. Been fighting this for a couple years! Problem began after a trip to the tail of the dragon.
archan
archan
  • 50 posts
  • Joined 13-May 19
Could it be related to the clutch?
Perhaps do a clutch relearn?
Thinking the transmission is not hitting the touchpoint cleanly or something.
