Turning off fake engine and exhaust sound in newer models
9 replies to this topic
d-pak
d-pak
  • 101 posts
  • Joined 24-October 13
I was kinda beating myself up for not doing this earlier on my Q50 which has sport exhausts and has the Bose ANC/ASC feature (Active Noise Cancellation, Active Sport Cabin). It made a huge difference in terms of reducing cabin drone and actually hearing what the exhaust truly sound like after 3 years of listening to fake noise garbage. The overall music audio was better too since the low-frequency was not being drowned out.
The principle is simple. There is a firmware with the pre-recorded engine and exhaust sounds loaded into the bose system for various RPM. When in ANC mode (comfort, etc) it uses the 2 mics in the cabin to essentially cancel the engine and exhaust sounds ...kind of how noise canceling headphone work. In the ASC mode (when in sport) it pumps fake amplified noises into the cabin when accelerating. The challenge is that if you change the mid-pipe or exhaust or modify the engine and the harmonics are off, then i's just pumping low frequency garbage into the cabin.
Since I don't have a later model GT-R, I had to get help from NickTO to obatin the ESM so I could share this, since it doesnt seem to have been discussed here prior or I just missed it.
Steps:
1. Turn ignition ON
2. Turn audio system off
3. While holding "MENU" button turn volume knob 40 at least 40-clicks in any direction.
4. Select "Confirmation/Adjustment" mode
5. Scroll to the "ANC/ASC" setting and select it
6. You have to do a "Connection Diagnosis" first, before settings can be changed. It will show you the name of the firmware I talked about above. go back to ANC/ASC menu.
7. If you want to hear the annoying sound pumped in click on the  "Active Test". It's so low frequency that my phone couldn't even record it.
8. Click on "Setting" and turn each one off. - ANC and ASC
I am not sure the GT-R will allow for each one to be turned off independently, the Q50 did. I noticed good results from ASC off. No more fake sound. The idea is that ANC cancels out normal road engine noise, but with different tires, tune etc, I actually ended up turning ANC off too and my overall music audio sounded better. I could also hear the engine rev.which I like.
9. Back out of the setting and the system will reboot, takes 1+ minute for whatever reason.
I'd be curious to hear about the results from GT-R owners people trying this out, even those with stock might actually find this better. I think this was introduced in US16 models onward? Getting rid of fake drone was the best.
Edited by d-pak, 15 May 2018 - 09:33 AM.
  • Tim, Enshiu, forty-two and 1 other like this
DIY Guides Related to my GT-R Projects --> http://gtrtech.blogspot.com
Crissy
Crissy
  • 219 posts
  • Joined 18-August 15
Steps:
1. Turn ignition ON
I have a ‘17 Q60, I suppose I should look into this. I feel silly not knowing anything about this.
  • Tim and Enshiu like this
gutdoc
gutdoc
  • 20 posts
  • Joined 04-May 17
Good reason to buy the “pure”?
No full leather interior though
Falcon900
Falcon900
  • 29 posts
  • Joined 25-May 18
What model year GTR's have this fake engine noise?
2016 Premium Cobb Stage 3; Cobb Downpipes, Cobb Y-Pipe, NISMO Ti Exhaust, Cobb 3" Intakes, ID1050X Injectors.
  • 9,288 posts
Same question???
MCGTRNISMO
MCGTRNISMO
  • 382 posts
  • Joined 24-October 14
Same question???
2017+
  its less of like a fake engine sound than an added tone if that makes sense.  I say that because it doesnt sound like anything the engine or exhaust would naturally produce . Its like an overlaid  hum or drone on top of the natural  more muted sounds we are used to the car making.   the sound itself in person isnt bad actually and I would say it gives the kinda bland sounding GTR a little personality except for the fact that its not something the actual engine is producing  which defeats the whole point. you can make a GTR very loud and aggressive with the full catless set ups as we all know  and you can have the built cars that sound like motor boats  but the VR38 itself pretty much doesnt have much flavor or a distinct note to it to it so I think that is what they were trying to achieve.
you can hear  the "fake" sound over an over here pretty well its that hum on top of what you are used to the car sounding like
Edited by MCGTRNISMO, 05 June 2018 - 11:14 PM.
  • 1,391 posts
Lol I did this in my wife’s X5M as it’s a tune option with dash on/off and she asked for it back on. Hhahhaha annoys me but whatever
Edited by droptopp, 06 June 2018 - 01:24 PM.
  • 1,391 posts
We all got a friend that does this :
https://youtu.be/A5w86IiXe9s
  • gtrfeh likes this
  • 9,288 posts
F that! I’ve seriously thought about taking my stereo out because the engine sounds so good! Especially at about 8500rpm
Falcon900
Falcon900
  • 29 posts
  • Joined 25-May 18
I have a 16' so I don't have this issue, but I am wondering how the car sounds if you put catless downpipes on a 17'? Does the cabin nose sound worse with this fake noise added in?
