No fuel?
22 replies to this topic
Jnin
Jnin
  • 17 posts
  • Joined 26-February 18
Hi there
I am trying to troubleshoot an issue with my car.
It doesn’t start. It cranks but doesn’t catch.
I ve noticed that the Cobb has a fuel pressure monitor in the gauges.
Should this show something when the start button is on the “on” position?
Also during cranking the pressure remains to 0. Checked the fuse
in the cabin but not the one in the engine bay yet. No error code on the Cobb. If it was a fuse issue wouldn’t come up with an error code?
My car is a 2012 GTR
Any help will be much appreciated
  • 5,058 posts
No error code if the fuse is blown in my experience.
UNFORTUNATELY, there is no "low fuel pressure" warning on any ECU I have worked with that I have SEEN.  They may have one, but I've never seen it.
Check the power at the fuel pump, my $0.02
  • 2,736 posts
What mods are in it
Jnin
Jnin
  • 17 posts
I have intake, full exhaust, NGK one step colder plugs, id1000 injectors, custom tune of course.
Last mod was spark plugs but did it a couple months ago.
Before that I did the pumps AEM 320lph the e85 compatible ones. But that was 4 months ago.
Any other ideas?
Edited by Jnin, 15 April 2018 - 08:28 PM.
  • Tim and Enshiu like this
  • 316 posts
Have you checked your fuel pump computer?
Jnin
Jnin
  • 17 posts
Where is that located? And how can I check it?
Edited by Jnin, 15 April 2018 - 09:14 PM.
Jnin
Jnin
  • 17 posts
So I just got home and gave it a go
Car started straight away
Is it possible to be the colder spark plugs?
Because last night when I tried to start it it was a bit cold. (I am in Sydney Australia) and now is around 25 degrees Celsius...
Will that be the issue?
Car hasn’t been tuned with the racing spark plugs
  • 316 posts
There you go ...... 8 is already very cold plugs for a gtr (bolt ons is 8 ok) 9 and 10 is more for 1k hp.
The computer is located on the driver side rear passenger side trim
Edited by Enshiu, 17 April 2018 - 04:45 PM.
Jnin
Jnin
  • 17 posts
Thanks mate
I started it yesterday morning which was a bit cold and it started straight away.
I tried today just now and it didn’t start...
It’s driving me crazy...
Should I get the stock plugs?
I will check if it delivers fuel tomorrow. Can I do that from the fuel lines in the engine bay? Also How can I check if that it has spark?
Can I do it with the Cobb?
Also I forgot to mention that the first time it happened when was I bleeding the brakes.
Car was raised on the rear right wheel where the pumps are.
I had a quarter of fuel left and the brake pedal was a bit tight, but second time I tried it started straight away so I thought it was because it was raised.
Edited by Jnin, 18 April 2018 - 05:01 AM.
  • 316 posts
stock plugs is wayyy enough for bolt ons.
It could be you jacked the car up and the fuel is transferred to the left side of the tank so not enough fuel to start.
Edited by Enshiu, 18 April 2018 - 04:18 PM.
Jnin
Jnin
  • 17 posts
Yes but since then I filled it up and was still doing the same thing. I also checked the main pump fuse. Everything ok there too. This morning started first go...
Pumps are working fine. A bit noisy when I take the seat off but they work. Enshiu I checked what you told me and it’s fine. On the road is very very smooth and powerful as it always was...it drives me crazy. I will check the plugs later today...
Jnin
Jnin
  • 17 posts
Another thing is that when I try to start it up and doesn’t I don’t smell fuel at all. If it was spark plugs then the exhaust should smell of petrol correct?
  • 316 posts
Have you checked your fuel pump relay and obd codes? Any videos of non start?
check your fuel pressure regulator
round partson the fuel rail.
Edited by Enshiu, 19 April 2018 - 05:40 PM.
Jnin
Jnin
  • 17 posts
I haven’t checked the relay.
It’s in the boot I think? No codes. I have accessport and doesn’t throw anything.
I will also get a video when it happens again.
Jnin
Jnin
  • 17 posts
Ok it appears that the exhaust guy did a dodgy job when he was installing my IPE exhaust. He got the 12v cable and he put it with the main fuel pump fuse...
I took it out, fixed it and put it back on. Since then my GTR starts first go...
Does anyone know a safe place that I can connect that cable and not in the fuse box? I guess it needs to be connected to a source that gives power when the engine starts?
  • 5,058 posts
Depends on how much load.  Best place if load is low is the 12V power outlet.  You can also do that at the fuse box though - not much on that circuit.
Jnin
Jnin
  • 17 posts
Thanks mate. I want to avoid the fuse box and putting it with another circuit like the dodgy job that the exhaust guy did :-).
  • 5,058 posts
There's two 12v outlets as you know.  One in console and one in dash.  You may be able to tap off that.
  • 316 posts
Or make a relay circuit signal wire on 12V+ when on.
Wtf has the exhaust guy to do with the 12V?
Electronic valve?
Edited by Enshiu, 24 April 2018 - 07:45 PM.
Jnin
Jnin
  • 17 posts
Electronic valve?
Yes IPE exhaust has the electronic valve.
How can I do that relay circuit signal? Any diagrams or what will I need?
