17" slick vs 15" slick
35 replies to this topic
stuntr1
stuntr1
  • 29 posts
  • Joined 05-March 17
Hello fellas , in your opinion and experice, when does small brake kit and 15" slicks become an advantage over 17" setup? Most popular being 17" with Hoosier and 15" with MT slick. Please share your experiences
stuntr1
stuntr1
  • 29 posts
No one has any conclusive comparisons between the 2?
Dan_585
Dan_585
  • 1,625 posts
  • Joined 30-August 15
15"= Big boy power 17"=sub 1400whp
Edit: Not from experience just from all the cars i've seen.
Edited by Dan_585, 09 April 2018 - 12:31 PM.
stuntr1
stuntr1
  • 29 posts
Thanks for your reply . Is there a  disadvantage of being sub 1400whp and using the 15" setup
  • 5,058 posts
Depends on combined tire and wheel weight.  All being equal?  No.  15" drag slick with same outer diameter will generally outperform a 17" drag slick.  But you HAVE TO TEST IT.  Each car is different and it depends.  But it's next to impossible to find a 15" and 17" setup that will have the same weight and performance.
  • 1,605 posts
15” also requires a much more aggressive burnout than the 17”.
  • 9,203 posts
I wiould say 15 is faster than 17 but much harder on drilvline pieces
Autobacs
Autobacs
  • 30 posts
  • Joined 14-December 13
Would it not be the opposite? i.e. more tire to absorb the drivetrain shock of launching?
  • Mattson likes this
Jason@BoulderNissan
Jason@BoulderNissan
  • 156 posts
  • Joined 23-December 12
I run the 15 inch slick. The T1 package with the smaller brakes. It is an awesome set up. I consistently pull 1.2-1.3 60 foot times. I also do not do any burnout at all.
  • Tim, Tony1, choerizo and 1 other like this
Jason@BoulderNissan
Jason@BoulderNissan
  • 156 posts
  • Tim, Tony1, Scuba_Steve and 3 others like this
  • 9,203 posts
yes to certain degree,there’s more tire sidewall to absorb the shock,but coming of launch control and dead hooking somthing is gonna give over time.
  • 9,203 posts
That’s nice to know Jason.
stuntr1
stuntr1
  • 29 posts
thats insane!!! no burnout?!!
Jason@BoulderNissan
Jason@BoulderNissan
  • 156 posts
Thanks. I will try and post up a video. It's not attaching for some reason
Zilla
Zilla
  • 35 posts
  • Joined 15-November 15
Why no burnout at all?
Jason@BoulderNissan
Jason@BoulderNissan
  • 156 posts
I have the Syvecs controller. It is a bit of a process to put it in rwd and back to awd after the burnout. I did a few runs with doing a burnout prior and then did runs not doing a burnout and the car ran the same numbers. So I figured between the wear on the car and the "sequence"/time needed to do the burnout really wasn't any benefit to me.
Jason@BoulderNissan
Jason@BoulderNissan
  • 156 posts
Scuba Steve is another local. He runs a 17 inch slick and I believe he only does burnouts occasionally. I will have to text him and see if I'm remembering correctly and what difference in times, if any, he sees.
  • mikelmarion likes this
Jason@BoulderNissan
Jason@BoulderNissan
  • 156 posts
Just texted Steve and he also does not do a burnout. Both of our personal bests have been with no burnouts.
Jason@BoulderNissan
Jason@BoulderNissan
  • 156 posts
My best 60 foot is a 1.289 with no burnout
Scuba_Steve
Scuba_Steve
  • 118 posts
  • Joined 21-March 13
  • LocationColorado Springs, CO
I started the video here to show that I drive from the staging lanes,around the water and stage. 1.270 60ft on M&H 28x10.5-17 rears, M&H 28x10.5-18 fronts. Kaps AWD controller with Visconti's base map, Jack's Transmissions spec ETS.
  • choerizo and mikelmarion like this
