Easter diagnostics- wheel noise
Johnnypbmx
Johnnypbmx
  • 67 posts
  • Joined 25-February 14
Last week i heard a noise from front passenger wheel So i limed it home. Was a grinding noise that was every half turn of the wheel going in a straight line or turning. I figured it was a bad wheel bearing so I replaced the hub/ bolt/ axle nut. Noise was still there but not as bad. Brake shield not rubbing and i couldnt hear when car is jacked up and wheel is spun. I tightened the lugs to 100ft lbs and tried the copper lubricant where wheel meets brake. Replaced the brake rings and pads 3-4 months ago and everything was fine until now.
Any ideas or advice? If not easy fix ill be driving it to jotech this week. Luckily i live 10 mins from them- life savers
Thanks in advance
Johnnypbmx
Johnnypbmx
  • 67 posts
I cant get the file to play so if its a broken link please let me
Know ill try to repost!
  • 316 posts
Are your wheelnuts the real product?
Edited by Enshiu, 02 April 2018 - 07:25 AM.
Johnnypbmx
Johnnypbmx
  • 67 posts
I had titanium lugs on, switched back to project kics and torqued to 100ftlbs
  • 316 posts
Try the stock ones?
Johnnypbmx
Johnnypbmx
  • 67 posts
I need open ended due to arp studs :-/
  • 316 posts
Try to redo your brake caliper? loose all bolts and pins and put some copper grease on it and retorque?
  • 5,058 posts
COULD be the infamous GT-R wheel hub noise.
COULD be the wheel bearing.  But you said you replaced?  (Hub/bolt/axle-nut?)
How many miles on this beast?
Johnnypbmx
Johnnypbmx
  • 67 posts
30k. Lowered on coilovers. Replaced the hub/axle nut/4 bolts holding the hub. It was originally a grinding noise that would be present about wvwry half rotation. Now its better after changing wheel hub (new unit) its more of a clunking thats heard in the video. Any thing i can try or check? Its a cba so only one spring clip on front calipers- may order two more to throw on as i was planning to anyways- possibly pad movement?
  • Enshiu and shawnhayes like this
  • 5,058 posts
Maybe pad clunking.  Install the extra clip and see.  It helps sometimes.  Sometimes it doesn't.
Johnnypbmx
Johnnypbmx
  • 67 posts
Thanks shawn- ill keep you posted
Johnnypbmx
Johnnypbmx
  • 67 posts
Put new brake retaining clip on and decided to clean inside of my wheels before remounting...noticed a loose bolt...then 6-7 more that were hand tight. Online gound BBS LM is 15-20lbs but just tightened them up with a wrench and socket.
Drove car at all speeds...next to a fence for echo at different speeds...had gf coast in parking lot as i walked listening. Nothing- no more noise so im assuming its the wheel hardware needs replacing. I had my wheels powdercoated then painted to match the car and original hardware was re-used so im going to order new BBS bolts.
  • Enshiu and 7racer like this
