Max Power on ID1700x
21 replies to this topic
stuntr1
stuntr1
  • 29 posts
  • Joined 05-March 17
As stated in the title , what max hp are a single set of  1700s capable of on stock lines and Fore Tripple pumps hardwired or course and e85. Thanks in advance for your response..
J5isalive
J5isalive
  • 390 posts
probably a tiny bit over 1300whp.
stuntr1
stuntr1
  • 29 posts
Wow, thats quite a bit of power. Maybe I have a failing component in my system. Im using an aeromotive FPR. Can this be a restriction in my fuel system?
J5isalive
J5isalive
  • 390 posts
what kind of dyno are you on?
I made 1295whp on a Dynojet using ID1700s.
Regardless i know you will need to turn the pressure up a bit to hit those numbers but i am sure you know that.
Good luck!
stuntr1
stuntr1
  • 29 posts
Good luck!
Do you have all 3 of them, hardwired. I didnt hardwire my primary pump
Edited by stuntr1, 11 March 2018 - 09:05 PM.
ALKOUT
ALKOUT
  • 25 posts
  • Joined 09-August 17
I doubt you can hit the 1300 whp on stock lines with E85
Edited by ALKOUT, 12 March 2018 - 03:39 AM.
stuntr1
stuntr1
  • 29 posts
I've seen quite a bit of TSM elite plus cars tuned on 1700s making upwards of 1250whp .
  • Mattson likes this
Cicio@TSM
Cicio@TSM
  • 928 posts
You can make WAY over 1300hp on stock lines.
Depending on the fuel pump setup and FPR you can make 1350-1400 maxed out on a single set of 1700s.
But a good number to go off of is 1300whp.
Injectors are only one part of the equation tho.. pumps and differential pressure play a huge role.
  • stuntr1 likes this
~Cicio
-FL2K 2015 Overall 1st Place
-TSM Shop Car (ETS Pro1900) @ 7.594 & 189.51
-Fastest Customer @ 7.70@180
-Fastest Stock Frame Turbo GT-R In the World @ 8.14@170
-Standing Half Mile Stock Frame Turbo Record @ 206.4 TSM ELITE
-Standing Half Mile 218MPH
cicio@topspeedmotorsports.com
TopSpeedMotorsports.com
**AWD Dyno Tuning
**Parts, Sales, Service
stuntr1
stuntr1
  • 29 posts
:blink: 1400whp? in this case all 3 would be hardwired?  What regulator do you recommend?
Cicio@TSM
Cicio@TSM
  • 928 posts
We use the Fore Innovations.. it works really well.
~Cicio
**AWD Dyno Tuning
Blade30
Blade30
  • 163 posts
  • Joined 19-July 14
Very interesting info
I always thoughts it all depends on the injectors size no matter what pump and FPR you are using
What about max power on ( 6 injectors ) ID2000?
Cicio@TSM
Cicio@TSM
  • 928 posts
Everything comes into play.. but pumps and injectors are the biggest.  and ID1700 setup on a twin pump won't make much more than 1100... on a triple it has no issue supporting 1300.
We have made 1450 on 2000s but the rest of the fuel system was setup for it.
~Cicio
**AWD Dyno Tuning
stuntr1
stuntr1
  • 29 posts
Yes I plan to swap out my FPR . Actually spoke to a guy from fore who explained the short comings of my current fpr.
J5isalive
J5isalive
  • 390 posts
:console:
Stuart@T1
Stuart@T1
  • 805 posts
  • Joined 29-July 13
There is a ton of information that has to be factored in here. Boost and fuel pressure are huge factors that have to be taken into account. We have an extremely accurate fuel flow calculator here that will shed some light on these things:
http://injectordynam...ector-selector/
With that being said the stock lines are not a restriction for 1,300whp. We have made over 1,500whp on E98 and stock lines.
  • Maniphanh likes this
stuntr1
stuntr1
  • 29 posts
thanks for the flow calculator Stuart. Btw I hardwired my primary pump and gained almost 15% duty cycle  at 35psi  :)
  • 1,091 posts
If you don’t hardwire, you could burn the car to the ground when the wires start to melt.
That’s another big plus ;)
  • 1,526 posts
Could you elaborate on this one?
  • 1,091 posts
I've heard of multiple cases with installing bigger pumps on stock wiring and the extra current draw burns through the stock wiring.
boosted-m
boosted-m
  • 147 posts
  • LocationNY NJ PA
Were you originally using the Fore fuel pump controller?
'12 GTR built
1050whp & 800tq on E85 -
Engine/Trans: WGP built 10:1 CR block | Headgames pocket port heads with Tomei 272/272
| ETS GTX3076R turbo kit | Driven Innov Race FMIC, 3" IC piping & CAI's | Shep ONE-k trans | Fore Innov Walbro Triple Pump Hanger, Rails, FPR | ID1700cc | 60mm WG welded to 90mm midpipe | EcuTek w/ GotBoost Flex Fuel Cable, DIY FPR sensor | and more!!
Suspension: KW Sleeve Kit
| SPL Front Upper Control Arms & Rear Camber Links |
