Help with Airbag Code
17 replies to this topic
LuvSpeed
LuvSpeed
  • 35 posts
  • Joined 15-May 16
  • LocationColorado
Hello all,
I hope that somebody can help me.  I had my radio stop working and my nav start acting weird on my 2009 GTR.  I purchased and recently installed the upgraded nav system from legertas.  Everything seems to be working with the system after the install.  However, I am getting a passenger airbag code that I can not clear.  I have tried to clear the code by using the ignition switch method as described in online videos.  I also have tried to clear the code using my COBB tuner.  The code is b1023.  Passenger airbag off indicator circuit is opened or shortened.
Legertas has been very responsive to my questions.  He stated that the airbag control unit is between that rear seats and the sensor is located in the passenger seat.
Any ideas on where to start?  I'm not good with electrical stuff. One question that I have:  Could it be related to any of the connections I made behind the dash?  I'm willing to take things back apart, but would like to know what to look at.  There is a passenger airbag light by the SD card slot
I appreciate any help.
'18 Huracan Performante,  '09 GTR,  '14 Viper TA#3,  '16 Viper TA 2.0,  '17 Audi RS3,  '18 Jeep Grand Cherokee Trackhawk,   '16 Ford F-450
Doing the radio install should have any effect for n the airbags.
Do you have aftermarket seats?
LuvSpeed
LuvSpeed
  • 35 posts
  • Joined 15-May 16
  • LocationColorado
I do not have aftermarket seats. I did not remove the seats during the install either.  The instructions given by Legertas show how to clear the airbag code, so I think this thing must happen during the radio install.
hmm it just doesn't make sense.  Could you look under the seat, its a white connector, just make sure its plugged in
this is the POS to defeat it, but the thread should give you a location of where to look
http://www.gtrherita...360#entry127804
LuvSpeed
LuvSpeed
  • 35 posts
  • Joined 15-May 16
  • LocationColorado
just looked at the seat connections.  will order the pos.  thx for your help .
  • 5,201 posts
Very likely that if this happened during the install, you pulled one of the wires.  What did you do with the faceplate on the old nav?  I believe it has a connection to the SRS system some way.
  • 5,201 posts
brand_rr-carbon-fiber-gt-r-shift-knob-bl
See that little light in the faceplate?  Hooks to the SRS system.  Check THAT connector.
don't order the POS!!!  I think Shawn has the right idea
nice knob Shawn! lol
  • shawnhayes and droptopp like this
  • 5,201 posts
Not my knob my friend.  Too lazy to go to the garage, I just pulled an online image.  But I know the SRS light in the little faceplate hooks to the SRS system, and certainly could be affected by a legertas install.
LuvSpeed
LuvSpeed
  • 35 posts
  • Joined 15-May 16
  • LocationColorado
Ok thanks for the input. Will check that connection. Won’t have time until this weekend. Will give an update.
legertas
legertas
  • 112 posts
  • Joined 13-October 14
  • LocationLithuania
OEM way to check to AIRBAG codes without any equipment .
16509003 1822982454610305 6579302092427434087 N
 Nissan GTR R35 CBA entertainment and navi upgrade to OEM DBA "HD" MFD
CBA clusters conversion to DBA NISMO
LBP 3693
Album: legertas
18 images
0 comments
LuvSpeed
LuvSpeed
  • 35 posts
  • Joined 15-May 16
  • LocationColorado
Took everything back apart. Checked all the wires from the electrical circuit behind the light in the face plate. Indeed there was a small little connector that I did not attach. This took care of the problem. If anybody else has this problem, recheck all the electrical connections coming from the airbag light by the S.D. card slot!
  • 5,201 posts
YAY!
Glad I helped somebody today.
  • 7racer and LuvSpeed like this
RonaldJiz
RonaldJiz
  • 3 posts
  • Joined 04-March 18
I had this and it worked for a while then it kept giving me abs and traction control lights and a Brake light switch code so i removed it..would love to reinstall but hated that issue.
doctorspeed1
doctorspeed1
  • 55 posts
I'm getting 5 in diagnostic mode which implicates "Occupant Classification System control unit" as the problem. I've reset it but it comes back after a few days. Can anyone tell me if this is the seat occupant sensor that went bad or if there's a separate control unit box. It's a '12 BE with stock seats never removed. Connections are good.
Looking in the manual it looks like a separate module from the sensor. Has anyone replaced this? Or has the fault usually been the sensor in the seat
Edited by doctorspeed1, 05 October 2019 - 01:10 PM.
HarrisRacing
HarrisRacing
  • 2 posts
  • Joined 20-August 19
Did you get this fixed?
I had the same code pop up from time to time, but was able to clear it each time. I guess this is telling me my passenger seat "mat" pressure sensor could be going bad. From what I see in the factory service manual, the seat sensor is a "mat" in the seat but the occupant control unit is in the seat as well (SRC-7 in manual). It looks like the mat has different pressure ranges and the control unit is comparing them to service conditions (ie - is a child seat in the seat, or full adult etc) - (SRC-6 in manual). I do believe I only get this error when I have passengers (which is rare). My car is a 2010 with 21k miles. Seats are like new if that matters (especially passenger seat).
https://www.nicoclub...TR/2014/SRC.pdf
Edited by HarrisRacing, 17 June 2021 - 06:00 AM.
doctorspeed1
doctorspeed1
  • 55 posts
I used this
https://airbag360.co...ypass-576-p.asp
