OEM paper or HKS drop in green air filters
- - - - - filtration and performance
3 replies to this topic
gtrguyinaz
gtrguyinaz
  • 65 posts
  • Joined 26-April 17
Whats the difference between OEM paper and HKS drop in greens
Performance difference is ??????????? maybe 5/10 HP    ??
  • 7,335 posts
I think someone looked at that...
I think in general the aftermarket filters flow more, the problem isnt that though.
Its just some let more particles thru.
gtrguyinaz
gtrguyinaz
  • 65 posts
I have in the past run K and N and the oil did find its way into the throttle body. All Hp builds use after market so is 1 better than another ??
I have been told by many that paper OEM is fine unless you have a build and need the flow. HKS is less expensive than paper and a friend in LA just dropped them in.
I still like the topic a few weeks ago about modifying a stock air box with a 3 or 4 inch inlet tube.
Keep the paper until you go with a larger build. If your stock or just a tune, not worth it. Fbo you will probably want to go with something like gotboost cause he's using green filters which are better than most filters.
