Wisefab front and rear suspension tested by Lyfe motorsports
76 replies to this topic
#61
mikelmarion
mikelmarion
  • 179 posts
  • Joined 31-March 17
#62
  • 7,156 posts
got the rear kit in today.  Pretty fast!
Like Elf said, plant of adjustment.
here are some pics.  Only problem I see for me is I have the SPL high clearance traction links that I can't reuse...and might be an issue with wheel clearance.
http://www.splparts....s-r35-gt-r.html
  • Tim, ian.r, thehelix112 and 1 other like this
#63
  • 1,732 posts
SWEEEEET!!!!!
  • 7racer and mikelmarion like this
#64
  • 7,156 posts
SWEEEEET!!!!!
I didnt see any instructions on how to set this up or setting guidelines.  Hope I can figure it out!
hey Elf, what are those shims for on that first picture I posted?  That whole bracket slide in and out depending on if you add or remove shims from what I can tell
  • mikelmarion likes this
#65
  • 1,398 posts
No instructions? Should ask them what size wheels will clear
#66
  • 7,156 posts
I sent them a PM on FB
#67
  • 1,732 posts
Fast way to change camber. No need to remove the control arm, just loosen those two hex screws and then add/remove shims to set camber where you want it.
#68
  • 7,156 posts
got a pm from Wisefab that they do have a manual and will get it to me.
about the max rear tire size...no answer yet.
Finspeed did mention that he has seen 345 on the rears
#69
  • 1,398 posts
But 345 on a 20 or on an 18?
#70
  • 7,156 posts
for me this would be 19s for the track set up.
isnt Ehyman run 345 on 18s? square
#71
  • 1,398 posts
Want to make sure 17s and 18s will clear for drag days and TI!!!
  • Tim and mikelmarion like this
#72
mikelmarion
mikelmarion
  • 179 posts
on a x12 or x13?  do they think a x14 or x15 would fit?
#73
  • 7,156 posts
lol IDK! let me see what I can find out.
Whats the widest slick the big boys are running?
#74
mikelmarion
mikelmarion
  • 179 posts
most run a 14 inch double beadlock or a 15x15 . then, there is that new 18inch wide drag radial i posted.  Not sure what that would fit under.
I just know the gtr would look really mean with a x14 or x15 in the rear under stock fedors
#75
  • 7,156 posts
got the install instructions from Wisefab if anyone is interested!
Attached File  A_M_451.pdf   930.87KB   6 downloads
#76
  • 7,156 posts
about clearance, this is what Wisefab said but I think we have more clearance in the rear no?
Doesn't Ehyman already run 345 in the rear on 18s?
Your wheel size was 19x13 et45? How did you fit it with stock stuff, it would hit coilover allready. If you really want to use 13 wide in the rear, then you should go for et35 or use spacer to do so, cause even if wheel clears everything, the tire will still hit it. Tire would probably still hit the shock too, allthough we have moved the shock mount 25mm towards inside for bigger wheel use. We have also moved the traction arm mount on the knuckle more towards inside to give more clearance, probably more then that arm with stock knuckle.
#77
mikelmarion
mikelmarion
  • 179 posts
Not sure. Hopefully some people chime in.
