EcuteK Phase 6 released
22 replies to this topic
Ben
Ben
  • 117 posts
  • Joined 15-March 13
More cool software updates from Ecutek
22788871_10159708795615195_8302018668653
http://mailchi.mp/gt...ensors-and-more
  • ian.r, 7racer and thehelix112 like this
  • 4,057 posts
Wow that's a lot of stuff! Super cool.
Can it do my request to flip to a different map by pressing a steering wheel button ("mark" maybe
) and then flip back when the brake is depressed? The idea is a push to pass feature.
  • 7racer and VR_power like this
VR_power
VR_power
  • 968 posts
  • Joined 05-January 15
Scramble boost feature like the JDM Spec-V R35. We already have the scramble boost light in our gauge cluster if you look carefully. Let’s see someone finally put it to use.
Maybe 20-25 seconds of a couple additional psi.
(Correction) US CBA don’t have the overboost light but DBA May have it if you guys want to check. Euro and JDM clusters already have it. Also years ago Visconti had told me that the functionality of the overboost button can be activated by your tuner if they choose. I’m not sure if he said it required ta jdm ecu but I think not if you have Ecutek.
The overboost function on a Spec-V is activated by pressing the cruise control button up for a couple seconds while the cruise control is off. Overboost lasts for 80 seconds on oem setting.
Edited by VR_power, 28 October 2017 - 10:59 PM.
  • 7racer, thehelix112 and Steve Theodore like this
Scuba_Steve
Scuba_Steve
  • 116 posts
  • Joined 21-March 13
  • LocationColorado Springs, CO
Overboost is useless if you're already running all the boost 😀
  • ATL_GT-R, celsius, Doug@WGP and 2 others like this
  • 4,057 posts
That'd be the point though, to run a lowered boost map for the twisty parts of a road course, with reasonably conservative boost by gear and tuned for a dead flat curve, and then be able to open it up down a straight.
  • VR_power likes this
  • 7,453 posts
I use to think that to but with COBB and ECUTEk Yiu can really control boost by gear. So most of the twisty stuff it’s in a lower gear and you can tune it for less boost. and then opposite for the straight.
My tuner plans to do extensive track tuning. I’ll ask him if it’s beneficial to do.
On my COBB I did have a scramble boost button that would give me couple more psi that I could hit later on a drag to keep the wheels from spinning. So same thing. But with the power newer turbos make it never seemed necessary on the track.
  • Tim, thehelix112 and mikelmarion like this
  • 1,850 posts
Going back a few years Ecutek allows you to adjust boost on-the-fly with the cruise control toggle. Not changing maps, just changing boost. I have used that at the track exactly how you described - I was forced to run a lower boost in order to pass a sound meter - then turn it back up on the next straight! It’s only one more thing to remember each lap - in addition to the hundreds of shifting, braking, throttle, and steering points!
  • 4,057 posts
Is that complicated to use? The reason I want the functionality the way I described is precisely because of what you said. There is always lots going on and I don't want another 3 things to remember... ;-)
VR_power
VR_power
  • 968 posts
I’d be interested seeing it used as a nitrous or methanol injection indicator, when the system is activated the overboost light would come on. This way you have your pump gas tune and drive around that way most times, but when needed you active the overboost (meth inj) and get a 30+ second jump in peak boost that you run on the base map. Same idea can be used for nitrous.
Edited by VR_power, 30 October 2017 - 01:29 AM.
  • 4,057 posts
Just checked and there is the overboost light on the dash in my '14 BE. Cool.
  • Tim, 7racer and elf_cruiser like this
  • 7,453 posts
Where at??
  • 4,057 posts
Top far right. Super hard to see, I had to shine a flashlight at it for a minute
VR_power
VR_power
  • 968 posts
Where at??
Look at the pics I posted above, US CBA don’t have it but everyone else should have it there I believe
  • 1,850 posts
Not at all. You know the cruise ctrl accel/decel toggle? That’s it - toggle up for more boost and down for less boost. Only works when cruise ctrl is OFF.
  • 4,057 posts
Honestly thats not idiotproof enough for me. I want it to drop to safe map soon as I touch the brakes ideally...
Steve Theodore
Steve Theodore
  • 442 posts
  • Joined 23-November 14
  • LocationNorth Bend, WA
Even I'm getting in on the ECUTEK Phase 6 fun, thanks to a nice Black Friday sale from Linney I couldn't pass up.  :)
Steve Theodore
2014 Nissan GT-R
- Kline Inconel grade 625 full exhaust, ForgeLine GA1R Open-Lug Cap wheels
2010 Porsche 911 GT3 RS
- SharkWerks exhaust bypass, lots of OEM goodness
1993.5 Toyota Supra TT hardtop
- TwinsTurbo build, BW EFR 7163 twins, 1175 whp
  • 7,453 posts
good seeing you Steve!
  • Steve Theodore likes this
  • 4,057 posts
Cool. Let us know how it goes!
Steve Theodore
Steve Theodore
  • 442 posts
Same here old buddy...please check out my reply on your Kline exhaust thread as I imagine you might enjoy it!  :)
Will do, and thanks.  Don't hope for too much as I'm still on stock downpipes, intakes, and injectors...so it's a very small power mod.  But, I sure love this car, and will mark 3 years with it next month.
Steve Theodore
2014 Nissan GT-R
  • 4,057 posts
Nice. I just crossed my 3rd year anniversary last month. Still a freaking beast of a machine. :-)
  • 7racer, elf_cruiser and Steve Theodore like this
