MFD+Audio/HVAC controls no longer working
40 replies to this topic
  • 1,803 posts
I'm a 2010 GT-R still with original MFD/control unit. Today the MFD decided to stop functioning and just displayed a solid black screen. No GT-R boot logo or any dials. Also none of the buttons seem to do anything either. Stereo/HVAC don't actually do anything nor do the respective steering wheel controls.
I checked a few usual suspects like fuses in the footwell but didn't see anything blown. Also did the battery disconnect for about half an hour and tried to "power cycle" the system.
Any other ideas? (besides just upgrading to legertas' updated units)
  • 5,191 posts
The CBA MFD was a piece of shit.  It's been chronically plagued with multiple problems like yours.  Its one of the reasons that I upgraded to legertas later year MFD.  It's been great, and I highly recommend it.
I hope you can sort it.  We started having failures of these units as early as 2011 on the early delivered 2009 model years.
  • Tim, VR_power and cmurder1019 like this
  • 2,153 posts
  • LocationNew York
How long was the extended warranty good for ? I don’t really remember but it is from the in service date as well.
OP, you can always ask the dealer to “good faith” as it’s a known and common issue.
Mine was replaced under extended warranty.
Edited by droptopp, 12 October 2017 - 11:33 AM.
  • 756 posts
I have an extra working CBA faceplate/control panel that you can try. It only takes about 10 min to give it a shot.
  • 7racer and choerizo like this
Yikes! Good luck man. It seems odd that they would all die at the same time since they are all separate systems. Did you check the fuses underhood as well?
I think there was a post that once the hard drive goes the whole system bites the dust.
  • Tim and elf_cruiser like this
That would make sense. Come on Choe, aren’t you an IT guy? No boot device means the OS won’t load, hahaha!
  • 7racer and droptopp like this
legertas
legertas
  • 112 posts
  • Joined 13-October 14
  • LocationLithuania
Might died you AV unit main board  . ( logo start , if HDD does not work only  )  . I had many clients with same problem. Unfortunately AV unit can't be repairable
  • Tim, forty-two, 7racer and 2 others like this
16509003 1822982454610305 6579302092427434087 N
 Nissan GTR R35 CBA entertainment and navi upgrade to OEM DBA "HD" MFD
CBA clusters conversion to DBA NISMO
LBP 3693
Album: legertas
18 images
0 comments
Crissy
Crissy
  • 245 posts
  • Joined 18-August 15
I did the Legertas update and therefore I have the original unit taking up space in the room where all the other parts go to take up space.  It worked fine before I replaced it but it did not sync with my phone so that is why I started my search for an answer and ended up here.
If you want to replace yours with the same you had let me know.
  • Tim, 7racer and choerizo like this
  • 1,803 posts
Will definitely give it a shot, if anything to troubleshoot what the root cause is. The CD drive still accepts/ejects discs but nothing plays.
Not yet. I can see the MFD backlight power on so I feel it's at least getting power... guessing it's like what legertas said and the AV mainboard is fried. POS.
Thanks Crissy! I may hit you up once I figure out what needs to be swapped out if I don't go the upgraded route :)
  • 1,803 posts
Current status:
We tried forty-two's replacement panel and no such luck. I'm thinking it's the bottom unit w/the hdd that is the issue.
Sorry man, total PITA for sure. Good luck!
good luck! I don't know how you're going to fix that?  Do you have a replacement to try (bottom unit)
  • 1,803 posts
I might look to source one locally or pick up Crissy's if I don't decide to upgrade to DBA.
  • 7racer and Crissy like this
  • 1,803 posts
For documentation purposes, checked the 15A audio fuse under the hood and it was fine.
Display goes from off to backlight after a few seconds when I turn on the car so it seems to be getting power.
  • 1,803 posts
Also found this thread: http://www.gtrlife.c...gnose-av-issue/
Going to check the BAT/ACC lines to see if they are getting power in a bit.
legertas
legertas
  • 112 posts
  • LocationLithuania
I was left in life som
I was left here my comments :)  and you should rear other thread http://www.gtrlife.c...0910-av-units/  . For 99% you AV unit is died :(
LBP 3693
Album: legertas
18 images
0 comments
  • 1,803 posts
Also would it be any cheaper if I sourced my own AV unit from a DBA?
I think the connectors are different no? I don't think you can just swap. And its a lot more expensive when I was looking for replacements
  • 5,191 posts
The connectors are very different.  Legertas unit with cables is the only way.  And I strongly encourage this replacement.
