O2 Defouler
21 replies to this topic
JasperGTR
JasperGTR
  • 370 posts
  • Joined 18-September 13
  • LocationFayetteville, NC
I've been advised to install defoulers to pass NC emissions testing.  I received a screen shot of what to install, but I can't click on any link to take me to the proper part to purchase.
What is this, and can someone help me purchase the correct one for my car?
Ian201
Ian201
  • 110 posts
  • Joined 28-September 14
  • LocationStenungsund Sweden
Look up Big Daddies Garage on the internet and you`ll find what your after, complete with installation instructions. You`ll need two for the rear O2 sensors.
  • mstaudt2003 likes this
JasperGTR
JasperGTR
  • 370 posts
Found this (looks just the picture of the piece that was recommended to me):
Ian201
Ian201
  • 110 posts
img894150134.gifThis is how the O2 sensor should look on the site. B I G
D A D D I E S
G A R A G E
O2 SIMULATOR CEL FIX
Designed For High Performance Modified Catless Exhausts...
Turbo and Non-Turbo Engines...
1.6 thru 6.3 Litre...
Precision CNC Machined , Premium High Quality T 304 Stainless Steel
Removes Check Engine Light... No Cel EVER !!!
1
2
3
4
5
6
7
8
9
10
11
12
The Very Best O2 Simulator made, Our Mini Cat Cel Fix works on the same principle as your larger OEM Catalytic Converter. The Noxious Exhaust gases are Oxidated and Converted by passing thru our custom Three Way Honeycomb Element coated with Platinum. Rhodium and Palladium. These gases react within the honeycomb element and are converted into carbon dioxide and water while also converting nitogen oxides back into nitrogen and oxygen which is eactly what the oxygen sensor is expecting.  With a modified exhaust system...click for more info and ordering...click for more info and ordering.
FREE SHIPPING TO 50 STATES & U.S. TERRITORIES
Edited by Ian201, 22 August 2017 - 07:59 AM.
  • JasperGTR and mstaudt2003 like this
JasperGTR
JasperGTR
  • 370 posts
Thanks!
Seems like a weird fix.  Some kind of voodoo going on in that little thing.
  • Ian201 likes this
Ian201
Ian201
  • 110 posts
Thanks!
Plenty of people in the US (GTR) running the sensors no reported problems i have two straight sensors on my dps.  :)
  • JasperGTR likes this
JasperGTR
JasperGTR
  • 370 posts
The one for $14.95?  (x2)
Ian201
Ian201
  • 110 posts
I can`t quite remember Tim1137 on the forum fixed them for me and shipped them to Sweden. He did it privately so it was great of him. Mine are the Big Daddie 02s They seem to be the most popular and best quality.
Edited by Ian201, 22 August 2017 - 08:53 AM.
  • 1,982 posts
Hmmm. Is this a solution when running catless DP's and getting a CEL every so often?
Tim1137
Tim1137
  • 226 posts
  • Joined 04-January 16
  • LocationSomerset MA
You want to get either the big daddy one with the mini-cat in it, or an angled spacer with the restrictors like pictured above. The big daddy mini-cat one just grab online, but if you want an angled spacer w/ restrictors I have some.
JasperGTR
JasperGTR
  • 370 posts
Yes.  That is my intention.
But the Accessport can be configured with a program to prevent that...
Edited by JasperGTR, 23 August 2017 - 10:00 AM.
240Z TwinTurbo
240Z TwinTurbo
  • 269 posts
  • Joined 06-February 14
I live in NC and you can purchase the "mini cat cell fix" from big daddies garage as others have mentioned.  It should not throw a code and you don't need to turn off any DTC's within Cobb...just install and you are set.
http://www.bigdaddie... Daddies Garage
DIY700 - 700hp on a Budget
  • 7,716 posts
elf, aren't you running Ecutek?  Can't you shut the CEL off?
  • 1,982 posts
Yes, I'm on ecutek and I also have stock downpipes :)
We're having the issue on my wife's car which is Cobb tuned and has catless downpipes. Previous owner had their shop add little extension tubes about 3-4" long so the second O2 sensor isn't directly in the airflow through the downpipe, it's a little bit delayed - however that hasn't totally solved the issue.
I only looked at her exhaust once right when we got the car but it seemed to be very difficult, maybe even impossible to reach the second set of O2 sensors without removing the downpipes. I'll check it out again next time her car is at my shop.
JasperGTR
JasperGTR
  • 370 posts
I'm trying to install these today.
Trying to find out the order of assembly (Not sure where copper washer or circlip go)...
Ian201
Ian201
  • 110 posts
Hi, Looking at the O2 sensor i think i can just see a groove on the inside of the external threaded end. It`s an internal circlip that`s shown on the photo. Obviously to retain the insert of choice. I can only refer to the big daddie O2 sensor regarding the washer mine has to be placed between the sensor and the o2 defouler on the hexagonal end.
Make sure you double check that the circlip is seated properly in the groove.
Looking at the photo again i would guess that the copper washer would also be used on the end with the external thread. Let`s see if anyone can confirm that.
Edited by Ian201, 31 August 2017 - 11:12 AM.
JasperGTR
JasperGTR
  • 370 posts
Yup.  Circlip holds in insert.  They went in pretty easily.  It seems as though the wires are pretty tight as they sit further away from the DPs (because of the additional spacer).
  • Ian201 likes this
  • 346 posts
Normally I remap should get rid of the codes.
Supvr4
Supvr4
  • 4 posts
  • Joined 04-March 13
Sorry to bring this thread back up. A car has an HKS catless downpipe with Cobb. There are no codes. The car was not driven for a long time. It was recently bought. At state inspection, with a handheld device, the car was not ready to be tested. Several attempts with handheld were done, each time converter not ready. There has been over 1000 miles now , and still not ready. Will this help ? Should the angled one be ordered to make installation easier without taking down the downpipe ?
Jared@SFS
Jared@SFS
  • 383 posts
  • LocationAlpharetta Georgia
Your tune will have the secondary catalytic converter codes turned off, you'll need a map that has them turned on. I also can't advise you in good faith to search for "Big Daddy's CEL Fix" or advise you to buy two of them and install them between your secondary O2 sensors and the down pipes.
