Is there a good mid-pipe upgrade that doesn't drone?
  • 876 posts
I have been running a Cobb mid-pipe with cats but no resonator along with Cobb intakes and a Cobb Accessport. However after a couple of years I have gotten tired of the drone from the mid-pipe and took it off and put it back to stock with the OEM mid-pipe when I had to take it all off to fix the turbo oil feed line. But I wouldn't mind unlocking some of the lost power with another mid-pipe that won't make my wife keep asking me why did I make my car so noisy! It was kind of annoying me too in city driving. Rest of exhaust is still stock and I want to leave it that way. Looking for more power with minimal noise increase over stock.
Suggestions welcome.
L.L.
L.L.
  • 39 posts
  • Joined 02-September 16
  • LocationSan Diego
Are you also running catless downpipes?
2015 Nissan GT-R Premium
AMS Alpha 9+ Turbochargers | AMS Alpha Induction Kit | AMS Alpha Front Mount Intercooler
AMS Alpha 3" Intakes | AMS Alpha 90mm Downpipes | Litchfield 102mm Triple Silenced Exhaust
AMS 4.0 BAR Map Sensor | AMS Alpha Coolant Expansion Tank | AMS Alpha Splash Shield
Speed Density on Cobb AP3 | ID1300 Injectors | Tial Q BOV | DW300C Fuel Pumps | GotBoost Flexfuel Kit | GotBoost Fuel Pressure Monitoring Kit
Should always be drone but you should in theory be able to change at what rpm the drone occurs in. Don't think there is a system that will eliminate it.
  • 1,675 posts
not sure if you saw this thread:
http://www.gtrherita...n-linney-titan/
  • 876 posts
No. Stock downpipes with the OEM cats.
  • 4,016 posts
I quite like the Mines Titan Straight Converter Type I (http://www.mines-wav...ALOG/R35_E.html) - http://www.mines-wav...Con_T1_1000.jpg I got from Bill_Malibu a while back.
It's close enough to OEM that my wife didn't notice the change just cruising around, but enough of a change that I now blast the fuck out of the car under every bridge, tunnel, underpass etc that I can find. :)
5ive
5ive
  • 20 posts
  • Joined 29-March 16
  • LocationGermany Hannover
maybe go for the nismo stuff http://www.nismo.co....ash/150018.html
greetings,
Robert
L.L.
L.L.
  • 39 posts
  • LocationSan Diego
That's great because cost-effective options to tone things down are available when working with stock downpipes. Not many options available with catless downpipes.
In addition to the options already presented in the previous posts, here is another:
A member on the other forum added a Borla XR1 muffler to his Cobb catted midpipe to help address the drone. The Borla XR1  is used on the "resonated" version of the AMS midpipe and can be had for < $175. A local exhaust fabricator can help with the installation. Hopefully you're comfortable with the mod because it involves cutting the current midpipe and rewelding the XR1 muffler in place of the straight piped section. It should be a piece of cake for an experienced fabricator.
My personal experience with that modification -- I did the same modification on a AMS non-resonated midpipe prior to a long road trip in Nov. Previous to the addition, the SO pretty much said we were not taking the car on anymore road trips. The drone gave her a headache and was not conducive to comfortable road trips even after adding sound deadening throughout the cabin. The XR1 addressed the comfort issues and the exhaust note was much more refined on the outside while the cabin was nice and quiet. We took the car on a 3k mile interstate road trip shortly thereafter with zero complaints about drone. The only complaint was that it did not help much once catless downpipes were installed.
If I were to start over with a stock GTR, the first mod would be the AMS resonated midpipe or any midpipe with the addition of the Borla XR1 muffler. I felt that was the perfect balance of refined exhaust note and comfort.
cjmatt
cjmatt
  • 455 posts
  • Joined 29-January 14
  • LocationDetroit
The Boost Logic Quadzilla is the least droney Midpipe ive had. Ive had a Linney titan, COBB Catted, and Meistershaft also
jbl16
jbl16
  • 16 posts
  • Joined 12-September 16
Im using AMS resonated 90mm with stock catback and catless downpipes. With this setup its almost back to stock level drone. However the part throttle gtr tone is now muted, although itsounds roughly the same at full throttle as nonresonated. It also took away the raspy tone I had with the nonresonated mids.
gtrguyinaz
gtrguyinaz
  • 67 posts
  • Joined 26-April 17
SBD or HKS resonated mid pipe with no cats has no drone and flows perfect.
  • 876 posts
That is a good link to add a Borla muffler to my Cobb catted y-pipe. Probably the cheapest option. Otherwise I can sell my Cobb pipe and buy something else with resonators which take out the low frequency drone which is occurring on the highway at 60-75 mph in 6th gear, which is 2100 to 2700 RPM or so in 6th gear (per http://www.dragtimes...-speed-1.html).
But I might also like to know what Y-pipes people have tied that have low drone. I assume you need one with a resonator on the main pipe or one on each inlet pipe, but reviews seem very variable.
