Billet heads
Posted 25 May 2017 - 11:08 PM
I was wondering how would these benefit the Gtr? Less weight? Able to run direct and port injection? Bigger intake and exuast valves?
How would these be better than a typical stage 3ish head?
- Mattson and RobChoky like this
Posted 26 May 2017 - 01:13 AM
I don't get why we need direct injection.
- shawnhayes likes this
Posted 26 May 2017 - 01:39 AM
Not saying that it's needed, but it seems to produce more power and allow for higher cp ratios on pump gas.
My point is how would billet heads benefit the Gtr? I can't see how they would make more power than everyone's ported heads. Direct and port injection combined is the only way I can think of
Posted 26 May 2017 - 10:56 AM
We don't. DI is about efficiency. If you don't care about MPG or the tricks needed to produce more power on pump gas then screw it. DI is so that a 2.0 liter four cylinder with a turbocharger and a supercharger can make 345 horsepower and get 26MPG (Volvo).
Posted 26 May 2017 - 11:24 AM
I did read somewhere (don't quote me) that the DI systems had a lower knock propensity vs standard injection systems. So, thats one good thing that would help.
I popped my motor after 4yrs and 8k miles which all of them were hard miles like a dude fucking his first piece of pussy after doing 5yrs in the joint. -Tim S.
GTR heritage - come get some!
Posted 26 May 2017 - 11:32 AM
- Cobb Protuner / EcuTek Tuner / MoTec Calibrator
East Coast Location 21B Ozick Dr, Durham, CT West Coast Location 16726 146th St SE, Monroe, WA
Posted 26 May 2017 - 01:19 PM
The driving factor for billet heads is going to be deck stability at extreme high cylinder pressures...
Posted 26 May 2017 - 01:50 PM
You are exactly right, but that feeds from exactly what I was talking about. Knock is from lean condition, and DI is much better at avoiding that. But you can get it right with port.
Posted 26 May 2017 - 02:29 PM
Posted 26 May 2017 - 02:47 PM
hopefully, Martin can chime in since he is the one making them
Pretty sure WillAll are making Billet heads for the TT Lambo crowd, not the GTR as of yet the stock heads seem to be holding well.
- mikelmarion likes this
I would think the purpose of a billet head would be to allow better porting without sacrificing the strength of the cooling passages and exhaust divider walls, which can crack if you overdo it currently.
You're very likely correct Doug.
My only reason for even being in this thread (me all stock block and turbo's and all) is about the direct injection. It's a great whizzbang for small engines to get much higher horsepower without knock, but unnecessary in this application. Not BAD, per se, just unnecessary.
Posted 26 May 2017 - 03:45 PM
I was just curious as to how billet heads would be of any upgrade over the stock heads. Only way i could think of was adding direct injection with port. Otherwise, not sure how they would make more power. Or their purpose. Has anyone blown apart stock heads?
Posted 26 May 2017 - 04:03 PM
Posted 26 May 2017 - 04:55 PM
As far as billet heads for the GTR justin said it. As long as they can stay clamped down and not crack or warp oem heads will be fine, when and if that happens then billet would be better. As far as flow goes and better porting i doubt it would justify the cost of billet heads for that reason alone. Stock heads flow very well.
Posted 26 May 2017 - 06:21 PM
Most of the DI crowd that want big power need to get rid of it because there arent good solutions for a high pressure fuel pump that flows what you need for big power or ethanol. But DI is better in every way if you could sufficiently fuel it. Its not just better mpg its much better knock control and fueling as the pressure leads to better atomization as well as being able to spray fuel during the compression stroke which is huge for knock prevention. Thats why you see new bmws running big boost and high conpression (10.5:1) and doing well with 91 octane.
Agreed. The problem with DI is not just hard to find high flow pumps that push the psi needed, but that run cool and can keep up. The other problem is valve deposits. Fuel helps keep valves clean. DI engines are having a shitton of problems with deposits unless they have stock air:oil separators. Especially the turbo ones with oil vapor coming into the intake tract under compression.
I'm not dogging DI in general, it's just another first world problem to solve. Port injection is cheaper and easier to make big power on - now. Just like carborated cars used to be easier to make big power on versus fuel injected. It took the market and science years to catch up, but now we have.
DI problems will get solved later, and it is inherently more controllable, but as I said before - for the GT-R, there is no need to add it - for now. That will also be very hard, not to mention expensive.
- BAZ007 and mikelmarion like this
Posted 26 May 2017 - 08:22 PM
Posted 26 May 2017 - 08:37 PM
Many more recent cars have port AND DI injectors. The Huracan for instance. You end up with great knock control and limitation of valve deposits of port injection.
The best of both worlds.
Downside: complex fueling tables. Harder to tune.
Upside: redundant fuel system, if done properly. Failure may not be catastrophic.
Posted 28 May 2017 - 11:23 AM
It is really sux plus the extra injector will be stupid expensive
Posted 28 May 2017 - 06:31 PM
DI huge issue on Porsche 997.2tt/991.1tt cars
What does "huge issue" mean?
What really sucks?
Why are extra injectors stupid expensive? ID's are cheap.
Posted 28 May 2017 - 07:43 PM
