R888R
61 replies to this topic
  • 1,597 posts
Wanted to see if anyone is running these, how they compare to regular R888 and what the measured rollout or circumference is front to back
pgordon888
pgordon888
  • 50 posts
  • Joined 05-March 16
  • LocationPhilly
Seems to be a pretty regular question since these came out. I run the 20 inch 285/315 stagger on 20x10 and 20x12 rims. Will check my logs later this week to compare front v rear rpms, which is the real data point you need if you are worried about ets strain.
Edited by pgordon888, 10 April 2017 - 08:22 AM.
  • Tim, 7racer, choerizo and 1 other like this
2014 Blue Pearl GT-R Premium Procom Built and Tuned (Borg Warner 6758 EFR - Linney EFR on Built 10.1 CR 3.8L + Shep 1K)
Linney Stock Manifold EFR (BW 6758) + PTP Turbo Blankets; Drummond Race Stage 1.5 3.8L (10.1 CR AMS/Manley Extreme Duty Pistons, Manley Rods, Kelford 266 Cams + Valvetrain, ARP Main and Head Studs, Ported OEM Manifold); Shep 1K + Drag Pack + DSS Pro Axles + Jack's ETS and Albins FWD Output Shaft and Dodson Heavy Duty FWD shaft; AMS fuel rail kit; Procom Bumper Beam Catch Can; BR FMIC; AMS Omega dual brushless fuel system; Full Expel Ultimate wrap; Stillen skid plate; 2015+ LB headlights; JDM clear side markers; Morr VS51 Comp 20x10, 20x12 with MPS4S 285/345 and Rays lugs; Litchfield Suspension Kit + Litchfield handling kit; Goodridge G Stop SS Brake Lines; Procom Ecutek SD flexfuel and TCM tune + BT Module; AMS coolant tank; GB 3 inch intakes, SD kit, and fuel pressure fail safe kit; ID 1700cc injectors; Tial BOVs; Linney 90mm downpipes (Gen 2); Linney Titan ti exhaust (Gen 2 Street version)
14411988413 fe0fb62d7d B
  • 9,157 posts
In for this answer myself
KNA
KNA
  • 93 posts
  • Joined 11-February 13
installing these next Thursday,
Looking forward to see how they do for the track season.
Toyo's website actually recommends the tire when you put make and model of the vehicle.
I'm also running 285/315
i definitely  think the tread patterns looks sweet.
https://www.toyotire...re-finder/89071
Edited by KNA, 10 April 2017 - 10:15 AM.
Ramen
Ramen
  • 24 posts
  • Joined 06-March 17
  • LocationDallas Texas
Wonder if they'll be better than NT01's  switched from R888 to NT01 cause the NT01 out gripped the R888.
KNA tell us what you think about them once you get them.   Interested in if Toyo will take the crown from their sister company.
  • KNA and 7racer like this
Mines the slow one
Nosferatu
Nosferatu
  • 171 posts
  • Joined 13-March 16
  • LocationAhead of You :)
curious to hear other's opinions as well...my three biggest cons of the previous R888
1.) Noise
2.) Wet weather application
3.) Speedometer read off
I know one can be fixable, two unlikely, and three well depends on the tire diameter.
2014 Nissan GT-R :D
Mods: FBO + Litchfield Suspension + Greddy Tranmission Cooler + AMS Race Intercooler + ETS 4" Titanium Exhaust + AP Racing Jhook rotors + Flex fuel kit + FORE Innovative + ECUTek Phase 5 + HRE 3 piece forged wheels with Titanium hardware
Best 60': 1.534 (R888 32psi)
Best ET: 10.247 Best MPH: 135.13
Other Rides:
2017 Audi R8 V10 Plus (Ara Blue Crystal)
  • 5,049 posts
The nt01's I ran today will be pretty damn hard to beat.
  • KNA, 7racer, thehelix112 and 1 other like this
Ramen
Ramen
  • 24 posts
Nosferatu, one is easily fixable,  just make the car louder to match :P
And I'm interested,  I know I'm not alone in my admiration of what Nitto has done with the NT01's,  so if Toyo has improved apon the Nittos I'd be ecstatic, but I'll just wait and see it for myself.
Mines the slow one
  • 9,157 posts
I talked to Shep about them and he told me its not a combo he recommends . Your a highly knowledgeable dude no doubt  all l the numbers made sense to your comfortable to run them ?
  • 889 posts
NT01's are fantastic on track. I've been running them for 8 years now. Curious to know if the R888R's are better.
  • 7,556 posts
or take heat cycling better.  I could almost say the original R888s were as good the first couple laps around a track but after that they fell off pretty quick
  • 9,157 posts
Never mind forgot you run square
  • shawnhayes and elf_cruiser like this
  • 5,049 posts
Yep. The only way to be sure of perfect all around diameter - no pun intended.
  • Tim and mikelmarion like this
5ive
5ive
  • 31 posts
  • Joined 29-March 16
  • LocationGermany Hannover
I drive the Toyo R888R they are insane loud much louder than toyo r888 i really regret buying them. Grip is great. Will try Michelin Sport Cup 2 Tires after them.
greetings,
Robert
  • Tim, 7racer and awdtt like this
Arkmae
Arkmae
  • 645 posts
  • Joined 16-July 14
  • LocationSydney, Australia
i find the noise less than R888 but still loud.
i run 285/35 square setup so i have no issues with rolling diameter.
in the wet, i take it easy on these, have felt the car 4 wheel crab walk when accelerating in the wet. wet weather performance is slightly better than the R888 but still sketchy.
Grip levels are very good for dry street.
for me MPSS was still a better street tyre overall.
  • 7racer and Nosferatu like this
ADM MY12 Nissan GT-R Ivory Pearl
Precision Automotive Racing PR12 3.8L -  TSM Elite Plus - Shep 1K - Motec - Boostlogic Manfold + Extra Rail - ID1050x / ID1700 12 Injector Setup - Fore Triple Pump
"I come from a land Down-Under"
 Instagram: @arkmae
Nosferatu
Nosferatu
  • 171 posts
I didn't realize how loud they were until I got rid of the R888.  Bought my GT-R with them on the car but when I switched to MPSS I was shocked going wow...those tires really were loud.   :lol:
2014 Nissan GT-R :D
Other Rides:
Ramen
Ramen
  • 24 posts
I do agree they were dumb loud.   But the sacrifice of grip at the track between MPSS and a good R compound was not worth it.   Guess it depends on what you want out of your car.
Suppose I wont be running MPSS any more.  Hopefully the R888R's are quiet and grip like a proper r compound.
Edited by Ramen, 11 April 2017 - 01:03 PM.
Mines the slow one
Wankeldude
Wankeldude
  • 167 posts
NT555G2 275/35/20 front
NT01 315/30/20 rear
Best combo yet of all the tires I've tried. May not be good for tracking as the 555G2 is not as grippy as the 01 but it's a fantastic combo for rain, high hp traction, and near perfect front to rear rolling diameter
  • Tim, changster, 7racer and 1 other like this
  • 9,157 posts
NT01 315/30/20 rear
Thanks Wankle
Nosferatu
Nosferatu
  • 171 posts
Whereas I'm on the opposite end of the spectrum.  I loved the grip they had but given I daily drive the car and the GT-R sees the track only a few times a year I'll take the MPSS for daily use.  Better life, better wet weather conditions, and I lose about 0.25 seconds on the drag strip being FBO.  It wasn't worth it for me to go back to R888 given on my setup the MPSS dead hook at anything on the street minus an absolute dig.
The aftermarket turbo guys I feel it's R888 or bust.
2014 Nissan GT-R :D
Other Rides:
