Nice bulge or are you just happy to see me
59 replies to this topic
#41
  • 7,206 posts
Thanks dude!! I had a little luck come my way but I will take it. It was an epic weekend and it was good to see you again buddy! Thanks for the help unloading my car and gear!
Fwiw, I was running low 2:30's during the race, nursing some heat issues and dealing with traffic. But just to give you an idea of the race pace for my class...
I didn't get into the 20's all weekend but also didn't have clean track or a perfect car.
Also FYI I'm running 315 front and 335 rear ;)
I may try bse's setup of 295/40 and 315/40 - he says they handle the heat better (more air volume so that makes sense) and I was noticing my tires fall off just slightly after a few laps, maybe overheating.
in your post, it sounded like you were having engine heat issues?  Or was it tire heat?  I just remember reading ur FB update that you backed off on the pace one you were in front.
#42
  • 1,751 posts
Yes to both. Water temp was turning red after a few laps so I had to run the straights at part throttle to keep it happy. Tires would overheat after a few laps but backing off a little kept them happy.
All in all I was probably only getting 80-90% from the car but that's racing!
#43
  • 7,206 posts
man, your the first to really say something about water temp...usually thats pretty solid.  Did you have it when you were doing TT?
Was it because of traffic and lack of airflow?
What are you going to do fix it? Bumper cut outs? Bigger radiator?
#44
  • 3,877 posts
My 100% stock OEM '14 has has water temp issues on a short track here in CA (http://www.gtrherita...-build/?p=76449)
114 deg C (red) on the back straight at Streets of Willow with 0 traffic.
Hasn't come back since then, but kinda weary of it now.
#45
  • 1,751 posts
Yeah forty-two was telling me that his highest water temp has been 207 at COTA and he has more laps around there than anyone. Yes the water temps were an issue before, but TT is usually only 15 minute sessions so it wasn't a big deal. Sprint races are 30 minutes so it's kind of a problem now.
BSE thinks it is because of my Dodson low temp thermostat (which is supposed to help cooling, duh) passing water too auickly through the radiator and not allowing it to cool off. He's going to install a stock thermostat soon and hopefully that will help.
I do plan to get a Top Racing front bumper and some wide fenders (undecided on fenders yet) and that should help as well.
#46
  • 1,651 posts
maybe the specV coolant tank might help too? (slightly larger). fwiw i've not seen water issues either though haven't had near as much track time as either of you guys. maybe you just need his bumper cutouts :)
  • forty-two, 7racer and elf_cruiser like this
#47
  • 4,768 posts
SpecV tank doesn't help with temps. It only helps with boil over.
I wish it helped more.
Paradoxically, CBA's have a little less water temp problems than DBA's for the most part. The trans cooling and oil cooling is less effective, keeping the water temps lower. Most of us would trade better trans and oil cooling compared to water temps. DBA keeps the average temp lower.
Edited by shawnhayes, 01 June 2017 - 05:21 PM.
#48
  • 7,206 posts
I thought the Nismo coolant helped with a bit extra capacity?
I hope the upgraded radiator and other crazy cooling stuff will work with my new build  :huh:
#49
  • 4,768 posts
One would hope, but it doesn't seem to really.  If one is increasing the FLOW rate, or the surface area of the cooling surfaces.  That would do it.  But, just increasing the dead space outside the tank doesn't do much of either - the Spec V would overflow the tank when it came off track.  Nissan increased the size of the tank to prevent that.  But, it's not REALLY supposed to help anything.
On the other hand, the upgraded cap DOES decrease the coolant temp.  No doubt.  At all.  Increasing the pressure increases the density (slight) with a corresponding increase in flow rate.  Maybe it's just changing the amount that ends up outside the tank, but it for sure improves the cooling a little bit.
#50
dinny
dinny
  • 24 posts
  • Joined 08-November 15
There not the figures of a worker
#51
  • 4,768 posts
This doesn't make any sense.
#52
dinny
dinny
  • 24 posts
No offense ment just the nicely manicured finger nails holding the slip of paper.. Unlike mine lol
#53
  • 4,768 posts
None taken, but your initial quote said "figures" which doesn't make any sense.
But that's the silliest shit I've heard all day. I mean, my fingernails are all tattered up too, but that doesn't mean anything.
They make these things called "gloves" which help a lot.
#54
viccaerter
viccaerter
  • 125 posts
curious about those alignment pics...  why not positive toe to help with turn-in?
#55
  • 1,751 posts
Because the platform already has a decent amount on bumpsteer in the geometry. So when you are on the brakes you get a little toe-out ...
  • 7racer and viccaerter like this
#56
  • 1,651 posts
Saw this the other day but can’t find much info about it online. Should be an interesting option. Release date says Dec 2017.
  • ian.r, forty-two, 7racer and 2 others like this
#57
  • 1,751 posts
Wow 20” Hoosiers! New daily driver setup !! Full of win on the way to mall !!
#58
  • 3,877 posts
That's actually rad. Thanks for sharing.
  • mikelmarion likes this
#59
  • 7,206 posts
wow!  that is awesome!
hey choerizo, I'm still looking to run 19x13 square. What size R7s can I run?
#60
  • 3,877 posts
https://m.tirerack.c...ZR9R7&tab=Specs
