Quieter Options Than Linney Titan
33 replies to this topic
Thomrs
Thomrs
  • 4 posts
Yes Colin, I do confirm having strong droning with my setup.
L.L., thank you for your last post.
I think I will soon move to the Lithfield system. I'll keep you inform here about my feeling when installed.
Once again thanks everybody for advises,
Thom
  • L.L. and Colin8989 like this
SwissMTNAlien
SwissMTNAlien
  • 44 posts
  • Joined 16-August 13
Adding a single Borla muffler to my midpipe on a completely cat-free system got rid of 100% of the raspy (i.e. crappy pickup truck) sounds and killed any cruising drone.  Still sounds great at WOT though.  I'm guessing you might have some difficulty finding a fabricator that is able to modify a Ti system, but if you can it could be cheaper/easier than completely replacing the whole system.
I did this on my previous GT-R and agree 100%. Made a huge difference!
  • mikelmarion likes this
2015 Pearl White GT-R Premium
AAM Non-Resonated Midpipe, APR Carbon Fiber Front Lip, Zele Carbon Fiber Side Skirts, Vorsteiner VFF-103 Wheels, DCTMS Steering Wheel
Colin8989
Colin8989
  • 76 posts
  • Joined 04-October 16
Thom
Looking forward to seeing results also.
jdmrb1
jdmrb1
  • 301 posts
  • Joined 22-February 15
  • LocationYokohama Japan
Go back to stock
  • celsius and thehelix112 like this
L.L.
L.L.
  • 39 posts
  • Joined 02-September 16
  • LocationSan Diego
I debated whether to start a new thread but since the dyno session was for the sole purpose of comparing the numbers of the Litchfield system vs the OEM catback, I'll just post here so others will know what to expect in the future.
Copy and pasted from the thread on the other forum:
The dyno session at ACG Automotive was yesterday afternoon and Chris Black was able to clean things up with three pulls. We confirmed what usually happens going to a larger exhaust without a revised tune during the initial baseline run. The car gained 32HP up top and lost some low end torque. Looking at our street logs from last week, we knew that was going to occur due to increased boost on the top end under heavier loads in 3rd to 4th gear. The HP gain might not be considered a direct result of the exhaust; more so the boost increase due to a freer flowing exhaust. Would be interested to hear thoughts on this.
Because the car is still running a stock transmission, we elected to keep things conservative as the clutch was starting to slip with the bump in power. Chris kept me at +10HP over my original tune numbers with a similar torque number (648/555 on a Mustang dyno). We also added the Cobb TCM add-on to adjust clutch capacity and added two more maps (low and medium in addition to kill).
I'm pretty happy with the numbers and the car runs great so, unless something unforeseen occurs (knock on wood), the car will remain in its current state for a little while until I'm ready for a Shep transmission. Thanks to James and Scott at ACG along with Chris Black for the continued support in getting the car running perfectly!
Here's the video and some photos from yesterday:
2015 Nissan GT-R Premium
AMS Alpha 9+ Turbochargers | AMS Alpha Induction Kit | AMS Alpha Front Mount Intercooler
AMS Alpha 3" Intakes | AMS Alpha 90mm Downpipes | Litchfield 102mm Triple Silenced Exhaust
AMS 4.0 BAR Map Sensor | AMS Alpha Coolant Expansion Tank | AMS Alpha Splash Shield
Speed Density on Cobb AP3 | ID1300 Injectors | Tial Q BOV | DW300C Fuel Pumps | GotBoost Flexfuel Kit | GotBoost Fuel Pressure Monitoring Kit
Thomrs
Thomrs
  • 4 posts
Thank you L.L., that's interesting.
The sound level during this dyno session seems really decent, and very nice at full throttle.
I received my exhaust but won't be able to put it into the car until next week...can't wait to do it but too much work!!!
Thom
  • L.L. likes this
Gtrpdx
Gtrpdx
  • 20 posts
  • Joined 07-January 17
I am having fabworx make me a 4" resonated ypipe fit Titan street 4", will go on the car in a few weeks will report then. Also catless downpipes
does what's his name still work for fabworx? if so buyer beware
  • 736 posts
Pretty sure he doesn't anymore.
Gtrpdx
Gtrpdx
  • 20 posts
I am working with Keith directly, I will post some pics once I get it
Gtrpdx
Gtrpdx
  • 20 posts
My goal is 1200whp street car that's smooth and civilized. Not cheap to do, but its worth it to me, we just spent 3 weeks on redoing entire interior with sound deadener and alcantara. Titan street and rsonated ypipe should be very good.
L.L.
L.L.
  • 39 posts
  • LocationSan Diego
I also did the sound deadening a few months ago. It was a ton of work but worth it in end. 3-4db reduction in road noise at highway speeds. Please share your thoughts on what you think of the car after the new midpipe and sound deadener. Would also be interested in hearing the exhaust with new ypipe.
Gtrpdx
Gtrpdx
  • 20 posts
Alright guys, i got my new exhaust installed and drove the car around for 10 miles, cant go WOT yet as my car isnt tuned.  This is a bad ass 4" exhaust setup if you want almost 0 drone and close to stock sound.  The resonated pipe from Keith at fabworx cuts the drone down.  I am super picky about exhausts and i think that 90% of GTRs are too loud and drone too much.  I like to cruise on the highway with the windows down at part throttle and not hear any raspy drone.
Call keith and he can make you a bad ass 4" ypipe if your running a linney titan, you can sell your titan ypipe to get some $ back.
  • changster and Colin8989 like this
Thomrs
Thomrs
  • 4 posts
Hi guys,
Sorry for the delay, but I installed my Litchfield exhaust yesterday, with great help of a friend. Not that this installation is difficult (the exhaust fit perfectly), but it's easier for two persons, especially if one has access to an hydraulic ramp :)
That said, the exhaust is really really quiet. I can't say there's zero drone, but it's night and day compared to my previous setting. The droning zone is between 2000 and 2500 rpm. But it's light.
Maybe the setup will be too quiet for some users...Personally I'm very happy with this exhaust. I feel the power is still here but the noise is much more "livable".
Regards,
Thom
