NT01 285/315 wheel speed differential data
34 replies to this topic
  • 1,393 posts
20x10 20x12.
I think if you had 10" wide wheels in the rear then you would be golden.
  • 4,280 posts
Let me tell you guys what I got from Shep.
The ONLY way to know if wheels/tires are going to work is to fit, mount, and do a manual rollout of the car (preferably with marked tires).
He was REAL clear about this.
I just have faith that my square setups are CLOSE.  Even on the stock rims, but even then they're not perfect.
  • changster and elf_cruiser like this
J5isalive
J5isalive
  • 251 posts
Question on related subject... would an all wheel drive controller not help this a bit?    Dont the new AWD Units better control when and how the front tires begin to receive power?
changster
changster
  • 1,995 posts
  • Joined 26-January 13
  • LocationSilicon Valley & Taipei
Basically we need to mount it and have weight on the tires, then measure the roll out correct?
- 4.4 liter Alpha 12 GTR built by TSM
- 4.1 liter something bigger coming
changster
changster
  • 1,995 posts
Are you on Motec? I forget.
  • J5isalive likes this
  • 4,280 posts
Basically what he said. Unable to tell from manufacturers data if the outer diameters will work. Mounted on different sized rims, even a square setup has some risk of having different diameters. It's unlikely, but still possible. Different tires and different rims are a potshot.
A pain in the ass, that's for sure.
J5isalive
J5isalive
  • 251 posts
No. Cobb tuned, Ecutek TCM, KAPS Awd Controller.
  • changster and 7racer like this
  • 3,305 posts
How's the kaps?! Im super keen to try one for circuit work. What are you using it to do?
J5isalive
J5isalive
  • 251 posts
Got to be honest I haven't pushed the car in a circuit environment to be able to give you a good answer. The real benefit I have seen with it is being able to switch to RWD and warm up the rear tires before a 1/2 mile pass. Taking the car to Tx2k so it will be helpful in drag racing.
I know a fair number of large shops seem to like the KAPS unit and it's pretty highly reccomended.
Sorry not a real good review of it... just don't have the before and after back to back experience to give a great review.
  • 6,472 posts
and from what I read KAPS is the maker correct?  Visconti, Linney rebrand it?  Anyone support it better than the other?
Linney have more custom maps?
  • 6,472 posts
I might switch to this from my Doluck. Was going to test the Doluck again with my new build then decide
  • 3,305 posts
Yeah I have a pretty specific use case I want help with. Exiting a low speed hairpin in 2nd I want the car to go to awd mode preemptively, I know it is going to slip, I want it to be all 4 and then transition back to awd as it gets quicker. I struggle to get the power down there as I lift to counter the oversteer before the system can send power to the front.
I just want it to already be sending power to the front and just pull me out of the corner.
Does the do luck have speed/gear based bias tuning?
  • 1,393 posts
I hear you on that, Dave - I have the same experience in my car. Staggered tires help a LOT, however the steady state balance is shifted towards understeer. Sending more power up front sooner might help, but also might break parts...
  • 6,472 posts
Nope, it basically uses the GT-Rs algorithm and tricks it.
So for left or right cornering I can set a certain % more that it sends the signal to the AWD system. Same for accel decel.
Does that make sense?
I like it as you don't have to fiddle with it and you just pick a preset. Though 2 slots are customizable.
Edited by 7racer, 15 February 2017 - 06:13 AM.
  • 3,305 posts
Thanks 7. Makes sense I think.
