NT01 285/315 wheel speed differential data
34 replies to this topic
changster
changster
  • 2,302 posts
  • Joined 26-January 13
  • LocationBay Area + Taipei
I just wanted to create a new thread so it's easily searchable in the future.
I put on a new set of 285/35/20 315/30/20 NT01's. I bought these because R888R's weren't available to me locally yet and I had to get a set of tires immediately.
I see a wheel speed differential of up to 4% faster in the rears at around 240kph. I don't think I'm losing traction at that speed so I'm assuming the differential is only due to the difference in tire size. No lights on the dash for wheel spin either.
Is 4% a lot?
  • 1,823 posts
Yikes!! Can you turn on the gauge for F/R torque distribution and try this again? Just hold a steady speed and the F torque should be near 0%. If it's trying to send power to the front when you are just cruising then I think your ETS unit will start wearing out quickly...
changster
changster
  • 2,302 posts
Cruising, it's trying to send 6-8% to the front. Take a look.
  • 436 posts
If you aren't losing traction, why would wheel speed differential decrease once you stopped accelerating?
  • 1,823 posts
Hmmm, my understanding is that should be 0 unless you are accelerating. Maybe some others can chime in...
  • 1,511 posts
Yes it should not be trying to put 6-8% power to front unless acccelerating hard or wheel spin
  • 4,949 posts
I am a big proponent of square setups.  For this reason.
  • Tim, elf_cruiser and socalaviator like this
  • 1,823 posts
What wheels are you running Changster? What dimensions?
I've heard that the only reason the 285/315 R888 setup works is because the factory rear wheel is a bit too narrow for a 315 and it pinches the tire and increases the radius enough to match the fronts...
  • 8,933 posts
Subscribed
  • 7,377 posts
Anyone with a square setup that can run the same test and post the logs??
  • 7,377 posts
Or one who's diameter might be closer???
Chris3g
Chris3g
  • 71 posts
  • Joined 02-April 14
  • LocationNorthern NJ
i run NT05 275 instead of the 285 NT01 in the front with NT01 315 in the rear for this reason, they are about as close as possible to being the same size in a staggered setup.
  • Tim, changster, 7racer and 1 other like this
2015 Premium Jet Black
WGP built / HKS GT1000 / ShepTrans / EcuTek
  • 4,017 posts
How are you guys logging all this?
  • 7,377 posts
that's pretty dramatic difference.
  • 1,677 posts
I've got a set of 285s square NT01 in my garage that I'm waiting to swap once my 285 square PSS' get worn out some more. I can run tests back to back. These would be on 20x10 front, 20x11 rear wheels.
I did run 285/315 NT01 briefly and I'm convinced it led to the demise of my front diff or at least contributed to premature wear.
  • 7,377 posts
yep I run square now...my front diff was making some noise and binding before the first rebuild when I was staggered
changster
changster
  • 2,302 posts
20x10 20x12.
changster
changster
  • 2,302 posts
Maybe because when I'm accelerating, the weight shifts toward the rear and presses down on the rear tire which makes the rear tire smaller?
5ive
5ive
  • 20 posts
  • Joined 29-March 16
  • LocationGermany Hannover
I had Square Setup on Street 285/35R20 often some Wheelspin then the rear tires has worn faster and i had 2 % Difference. In germany people like 295 rear and 285 front setups for saving awd clutches.
greetings,
Robert
  • changster and thehelix112 like this
doctorspeed1
doctorspeed1
  • 49 posts
I'm running 20" 285/315 NT01 on stock BE rims (9.5"/10.5") at 30/29 psi. Wheel slip is under 1 percent, torque split ~3-4 cruising at 100 kph logging with EcuTek.
Edited by doctorspeed1, 13 February 2017 - 05:47 AM.
  • changster likes this
