Lexan windows, what are downsides?
22 replies to this topic
changster
changster
  • 2,305 posts
  • Joined 26-January 13
  • LocationBay Area + Taipei
Anyone have experience driving around with Lexan windows?
If you assume you can still have power windows and the fitment is good, does it still suck to have Lexan windows? I know it's easier to scratch.
http://www.plastics4...window-kit.html
  • 4,250 posts
I highly doubt you can lexan the door windows without a lot of work. Lexan is flimsy as fuck. Think that's why ams built a custom upper channel for their door ones to locate and give it strength.
B pillar and rear windscreen would be simpler to do.
Edited by thehelix112, 14 January 2017 - 10:43 PM.
  • changster likes this
  • 4,250 posts
You can see the support brackets here http://blog.amsperfo...ord_exhaust.jpg
  • Tim and changster like this
Tony1
Tony1
  • 942 posts
  • Joined 28-December 12
Yeah, you don't want to do lexan in a street car.
  • Tim, changster and elf_cruiser like this
T1racedevelopment.com
Injectordynamics.com
214-607-9022
changster
changster
  • 2,305 posts
Because it'll be bending and flapping everywhere under the wind?
Dan_585
Dan_585
  • 1,633 posts
  • Joined 30-August 15
I don't think lexan windows are street legal either. But then again neither is most of the stuff on our cars lol
Tony1
Tony1
  • 942 posts
Yeah, lexan door windows need a frame.  Since the GTR doesn't have an upper frame around the window like some cars, if you put a flexible window in there it'll pull out on top at high speed unless you build a frame for it.   At that point, power windows are out the door, but you can save a lot more weight since you're ditching everything inside the door.   Not worth it in a street car though, cons far outweigh the pros.
  • HiBoost likes this
214-607-9022
  • 1,982 posts
I wpuld also argue that lexan isn't much lighter than glass by volume. So the real weight savings from lexan has to come from the thickness. You would need to do like .120 or .095 thick windows, which would be very flimsy and would only save a few lbs. my glass windows are out of the car and they don't weigh more than 7-8 lbs each.
  • 1,982 posts
The rear glass would be the best place to try for weight savings...
  • 5,083 posts
Roger that.,
And the front, but then you have to add the support frames as well, and won't be street legal and totally obvious to the cops and everyone else.
bpauto
bpauto
  • 570 posts
Hey Changster,
We run Lexan windows in our Overtake carbon GT-R (front, door, rears)
If your trying to save weight by replacing the OEM glass this is a great option, however they are certain things which we've learned from running Lexan windows that I want to
bring to your attention.
You won't be able to run the windshield wipers as they will scratch the windshield, so driving in the rain is...interesting
Secondly, you'll have issues attaching the rear view mirror to the window (ours fell off a few times) we had to use an industrial strength adhesive
We also found it unnecessary to reinforce the driver and passenger doors, the Lexan replacements we used fit almost perfectly.
To answer your question if it sucks: No, Not really, but i wouldn't recommend it for street use, ever.
The main reason race cars use Lexan is that it doesn't shatter similar to how glass would on impact.
Hope this helps!
-Jon
  • changster and 7racer like this
Tony1
Tony1
  • 942 posts
How fast have you been in this car since doing the lexan?
214-607-9022
bpauto
bpauto
  • 570 posts
>100mph many times, but as far as exact speed, don't remember exactly.
Tony1
Tony1
  • 942 posts
Interesting. Is it thicker than .125"?
The lexan that's on my car and Gidi's car are perfect fit, it's an exact replica of the stock glass, but without a frame they will pull away from the roof line at high speed.
In the street world, 100mph is fast, on a race car, it's nothing. Maybe this is happening over 150mph, something MOST street cars would rarely see but something a car like mine sees much more than.
I would be absolutely blown away if an 1/8" lexan window on a GTR, in a factory fitment configuration, would hold up anywhere near the top speed of a stock GTR.
  • changster and socalaviator like this
214-607-9022
changster
changster
  • 2,305 posts
Thanks for the color guys.
I was only looking at this because it looks like it can save up to 80lbs from my little Miss Piggy (4050lbs!).
Onto the next...
bpauto
bpauto
  • 570 posts
Yeah, the door glass definitely starts to hover just a tiny bit at speeds over 100mph, but not enough where a dramatic amount of air is getting behind.
Tony1
Tony1
  • 942 posts
Not too far past the window starting to pull out a bit is the window flying off the car! lol
214-607-9022
mikelmarion
mikelmarion
  • 240 posts
  • Joined 31-March 17
old thread update.  Have any of you guys tried optic Armour? Supposed to be superior to lexan in clarity and a few other details.  They offer pre cut drop ins that look exactly like oem.  Even tinted versions
  • changster, 7racer and elf_cruiser like this
  • 1,982 posts
I'll check that out. I've got to make some lexan windows in the next few weeks anyways...
  • 7racer, thehelix112 and mikelmarion like this
  • 1,982 posts
Combed through their web site - http://www.opticarmo...com/default.asp
Nothing for the R35 :(
It sounds like they do custom windows but I'm sure it's expensive...
  • thehelix112 and mikelmarion like this
