New SiR Garrett Gen 2 Turbo Options
54 replies to this topic
#41
Bill@SiR
Bill@SiR
  • 471 posts
  • LocationMiami FL
And....?!
They make more power, but not as much as the advertised gain due to housing restrictions.  I have not done an A/B test since they are pretty new.  But a Stage 3 to a Gen 2 GTX3071r is a 150hp upgrade.
If "they make more power with the same spool" isn't good enough I can share some dyno results.  But I dont know the OP, and as a first post im not going to just pour out data, Lately everyone seems to like to steal my IP for their own gain.
If more data would make you change your buying decision, then great, I can provide data that your looking for.  But since its new I spent a good deal of time and money in it for someone to claim it as their own.
  • Tim, changster, thehelix112 and 2 others like this
#42
  • 834 posts
Well can you post your dynograph with big SIR logo watermarked on the background so that if anyone is to post any of your findings the SIR is always going to hit them in the face first, having to acknowledge it.
#43
JustinOlson
JustinOlson
  • 58 posts
  • Joined 16-February 16
Awe baby boy Chris Riggs unfriended me and deleted me from his SBD group for notifying the thread of his offer. Haha taught me a lesson. LMFAO
Edited by JustinOlson, 22 December 2016 - 01:55 PM.
  • Tim, Bill@SiR, Dv8 and 3 others like this
#44
Steven
Steven
  • 10 posts
  • Joined 18-April 15
I was just trying to figure out where they stand because your website says the gen 2 3071 makes 1200 crank horsepower, and your current stage 3 make over 1100whp. I just got a car off my lift and am thinking about starting my build. The guy that does my tuning (Tom at tscompusa) just picked up a stage 3 plus from you. It's not easy to make these decisions! If you prefer that I call or pm you I can do that.
#45
Bill@SiR
Bill@SiR
  • 471 posts
  • LocationMiami FL
You have a Gen 1 GTX3071R, it can make 1100whp in a max effort situation.  The best current ET with those turbos is an 8.77@158mph
A Gen 2 is a 50hp upgrade due to other restrictions Its rated at 1200 crank.  Most Dynojet's read very about 50hp less than crank hp in a GTR.  I would expect 160mph (depending on the weight and supporting modifications, and weather conditions) trap speeds based on dyno data of that 50hp delta.
#46
colo_evo
colo_evo
  • 111 posts
  • Joined 20-September 16
You can make a dyno graph with a flat 600tq to say 7000rpm (thats 799hp).  However to do that you are going to need boost in the 22-24psi range.  Now the next problem is for the dyno this is "Safe"  However to achieve that boost, the turbo speed will increase as the RPMS go up.  On a shift in the real world what you get is a torque spike, ESPECIALLY you rev it higher than 7000.
I've always wondered what happens to all these stock block cars pushing high wgdc after a shift. Is there some sort of anticipation logic that can decrease wgdc/timing/torque post shift to avoid spikes?
#47
Bill@SiR
Bill@SiR
  • 471 posts
  • LocationMiami FL
EcuTek does have an upshift wastegate map, so that you can drop the wastegate during the shift.  But this looses a decent amount of turbo speed.  So by doing so keeps the boost fairly flat if calibrated properly, however it does slow the car down.
Again you cant cheat physics.  You can do what you can, and that upshift boost spike prevention is one of them.
#48
KrieGTR
KrieGTR
  • 126 posts
  • LocationSLC, UT
Well with new technology, comes new turbo options.
Basically the difference here is better response for a given power level, or more power with the same response, I was very impressed from the set we did.
Im offering 3 of the Gen 2 Garrett GTX sizes for the OEM Manifold
GTX 2860 A 46mm sized unit for ultra fast response (keep in mind stock is 43 journal bearing, these are ball bearing), I have not made one but it would HAVE to spool faster than stock, Capable of an estimated 850whp
GTX 2867 A 50mm sized unit still keeping very quick response, these are the first set we did, and they made 938whp at 27psi of boost.  Really amazing out of a GT28 and the OEM compressor housing.
Keep in mind dyno is in 2wd for load, however the power is about 100hp more than a typical Gen 1 setup
And GTX3071R 54mm sized unit, In the OEM manifold it is still a very quick responding setup, I have only used the Gen 1 those typically make 1050whp, and again i would anticipate 1150whp or so, with ultra quick response from the OEM exhaust housing paired with a relatively small turbo
All the turbos are priced with Actuators and lines
Link for GTX Gen 2 OEM Manifold upgrades
Hey Bill,
When you refer to the 2wd dyno for load. What does that change? Does that mean that on either a 4wd dyno or on the street, the spool would be even better than the graph you are showing?
09' SS GTR BPU
#49
haseeb
haseeb
  • 3 posts
  • Joined 11-April 17
I would offer an upgrade, would just be an aero upgrade on the compressor side, I would keep the same profile so it would be a drop in for existing customers, just should make a bit more power, but only way to find out is to do it.
Hi bill do you still offer this upgrade?
#50
colo_evo
colo_evo
  • 111 posts
Did you ever get feedback?
#51
Bill@SiR
Bill@SiR
  • 471 posts
  • LocationMiami FL
He emailed me a few times about a USM Gen 2.
Both are straightforward, but unfortunately both require machining of the compressor cover to accommodate the change in wheel profile.
The Gen 2 aero is best when you are maxing the turbos out at high pressure ratios and high shaft speeds.
#52
colo_evo
colo_evo
  • 111 posts
Gotcha! So gen 2 along with ball bearing cartridge type are more suited towards running at or near full tilt most the time.
This may not be the right thread but could you list your turbos in order of peak power. The way I understand it is:
Turbo- cartridge type - max dynojet power assuming stock head/cam engine
Sir stage 4 - ball bearing - 1250
Gen 2 gtx3071r - ball bearing - 1150
Sir stage 3 - ball bearing - 1100
Gen 2 usm - journal bearing - 1050
Gen 2 gtx2867 ball bearing - 940
Gen 2 gtx2860 ball bearing - 850
Sir stage 1 - journal bearing - 750+
Could you edit this so I have accurate information. Also, this thread was created nearly two years ago so hopefully you have a feel for how the turbos are performing out in the wild.
#53
Bill@SiR
Bill@SiR
  • 471 posts
  • LocationMiami FL
Sir stage 4 - ball bearing - 1300
Sir stage 3 - ball bearing - 1050
Gen 2 gtx2867 ball bearing - 950
I also have done a Stage 5 in the 1425whp range.
  • celsius and colo_evo like this
#54
Formidable
Formidable
  • 460 posts
  • Joined 24-December 15
Stock manifold? Impressive. How’s the transient response? Any dyno?
#55
Dv8
Dv8
  • 123 posts
  • Joined 14-March 13
Bill, which is the best suited for stock bottomend?
~Dv8
Edited by Dv8, 06 September 2018 - 09:50 AM.
 4/28/18 8.81 @163MPH
Changes Coming| NHRA Licenced GTR 8.5
