Passenger occupancy sensor
98 replies to this topic
#81
  • 6,565 posts
Oh one last note in my case where I only put in the airbag360 unit to turn off the lights because of a fault you have to plug in the passenger seat belt to keep the light off whether someone is in the seat or not a minor inconvenience but still necessary.
For David and Colin,
I use these for the passenger and drivers when I am at the track and in my harnesses.
They can also pop open a cold bottle of beer after a track day! If you search on ebay you can find GT-R logos ones....at least there were when I bought these back in 2014
http://www.ebay.com/...ONYONpk&vxp=mtr
  • Colin8989 likes this
#82
David Buschur
David Buschur
  • 2,232 posts
  • LocationWakeman, Ohio
Do you need some airbags Dave? I have the side curtain airbags and the airbag controller brain out of my car if you need them. Free if you are developing a product for the community!
No I don't but thank you!
Agreed! Thanks 7 racer!
Also, dave, are you planning on making the resistor plug and play? I'm currently just using the 2.2 ohm resistors electrical taped in, but sometimes, it shakes loose.
The resistor didn't work in the 2014+ cars we've attempted to use them in.  The part I have is plug and play and works.
David Buschur
www.buschurracing.com
BR160 package, stock turbofolds, 8.33@168.68 mph.  Standing 1/2 mile 199.29 mph
BRTech, text line.  You can text us with BR specific tech questions @ 440-652-5695
BUSCHUR RACING on FACEBOOK
BR SHOOTOUT on FACEBOOK
#83
David Buschur
David Buschur
  • 2,232 posts
Took me a minute to figure out what the hell that was!  I have harnesses in my car on the drivers side but have left the factory belts and I wear that on top of the harness actually.  I figure if I actually crash, that air bag coming out isn't a bad thing.
David Buschur
#84
ntfsgtr
ntfsgtr
  • 3 posts
  • Joined 04-September 15
I have a 2015, what resistor did you use to make it work? I have the 2.2ohm resistors and the POS but my light is still flashing.
#85
Colin8989
Colin8989
  • 35 posts
  • Joined 04-October 16
lol nice idea I'll look them up.
#86
Dv8
Dv8
  • 81 posts
  • Joined 14-March 13
Take a paint stick break off only the length of the yellow connector and the resistor plugged in. Duct or Gaffer tape the stick to the bottom of the connector by wraping tape around. This creates a platform for the resistor. Now tape it around overlappting the previous tape. Done. Resistor wont come out.
~Dv8
  • Scuba_Steve likes this
 8/24/16 9.0 @159MPH | 12/19/13 994whp 895wtq Dynojet | 845whp 761wtq Mustang |186MPH 1/2 AAM900R
Black Obsidian GT-R Equilibrium Tuning Built, Manley Bottomend|AAM3582R|AAM RIC|Custom Midpipe|Stock Exhaust|Kelford B|SiR2k|Fore 3 Pump|
Jacks Trans Billet Drag950|EcuTek-Ronnie@RDE Tuned|RPM 8pt. cage| NHRA Licenced GTR 8.5
#87
joedr
joedr
  • 5 posts
  • Joined 03-November 14
Tell me.
Hi Dv8,
Is that the same NSN-1 listed on airbag360 for the 370z?  It seems that it is the same for most Nissans.
BTW.... Mine is a 2009.
Thanks in advance!
#88
Dv8
Dv8
  • 81 posts
Hi Dv8,
Thanks in advance!
From the looks of it, Nissan/Infiniti all use the same unit.
~Dv8
#89
Tay
Tay
  • 17 posts
  • Joined 17-March 13
+1
I have a 2014 and the Works Bell U-Turn harness and the Airbag 360 is not getting rid of the flashing light. I also tried the diagnostic mode steps and no luck.
Any ideas?
#90
  • 6,565 posts
Not sure, I remember when I was looking into this there was a gap when they changed the electronics of the POS. That's why you had to get it out of a similar car. Might have to do the same until Airbag 360 comes out with another one. You might want to email Airbag 360 to see if they know of a change and have a new one in the works
#91
Tay
Tay
  • 17 posts
OK. Sounds good. Thanks Bob.
#92
Dv8
Dv8
  • 81 posts
+1
Any ideas?
both factory seats out?
You have two bell harnesses and 1 airbag 360 module?
Tool I use to clear SRS/Airbag lights.
https://www.amazon.c...e?ie=UTF8&psc=1
~Dv8
#93
Tay
Tay
  • 17 posts
~Dv8
Yes. Both factory seats are out and I installed two 2.2 ohm Works Bell in both sides and the Airbag 360 module.
In this thread, member jima mentions using a 4.7 ohm resistor: http://www.gtrherita...ermarket-seats/
I also found this: http://www.ebay.com/...s&ul_noapp=true
And this: https://www.nengun.c...cpPgaAhVM8P8HAQ
Does that tool you posted usually do the trick?
Thanks Dv8.
#94
Dv8
Dv8
  • 81 posts
Thanks Dv8.
i also use a 2.2 resistor off ebay. I have that scan tool to read/clear ecm/tcm/srs fault codes, not needed but makes diag easy for many different vehicles. if one of of the works or AB360 is bad then your going to get that light. can you do the process in which the system tells you where the fault is being reported from?
The gtr ever deployed its airbags, steering wheel, dash, seat side bag or curtain?
#95
Tay
Tay
  • 17 posts
No airbags have ever deployed.
The process you are referring to, does that require a tool or is it something else? I can have a friends stop by with his scanning tool to see if we can figure it out.
#96
Scuba_Steve
Scuba_Steve
  • 105 posts
  • Joined 21-March 13
  • LocationFountain, CO
I'm also having a problem getting rid of my gauge cluster airbag light. I have an 09 with 2 race seats. The airbag 360 got rid of the light near the cd slot. I also added these 2 resistors to the plugs under driver and passenger seat, http://m.ebay.co.uk/...113?_mwBanner=1
We did the airbag reset using the ignition on off on technique. It goes off but comes back on after driving a few minutes.
Any suggestions to get it to stay off?
#97
  • 6,565 posts
steve, i have an 09 and those same connectors.  I would say to make sure the resisters have good contact.  I know when I spin out on the track the light tends to go back on (always assumed it was from the POS).
also, when you say it goes off.  Does it stay off completely until you drive it...after what distance does it go back on?  Does it seem like it when you hit/bump something?
  • bpauto likes this
#98
bpauto
bpauto
  • 532 posts
Seems like you followed all the correct steps, but there are two things you can double check:
1. Verify that the leads of the resistor are making proper contact with the contacts in the insides of the connectors.
2. If you confirm that #1 is true, check to make sure the resistors aren't damaged in any way.
3. If #1 and #2 are verified, then check to make sure that you are correctly entering the airbag diagnostic mode. It can be confusing if you've never done it before due to the blink rate being ambiguous.
#99
Dv8
Dv8
  • 81 posts
If the light doesnt go off(blinks) or goes off then back on, you need to:
#A manually enter diag and figure out what its reporting
#B have it scanned by a tool thats able to scan SRS/Airbag systems < most scanners dont do this. One I posted does.
If an airbag light is on and not flashing, that means theres a hard fault in the SRS computer. Needs to be sent off and cleared.
~Dv8
