Passenger occupancy sensor
110 replies to this topic
#41
Colin8989
Colin8989
  • 94 posts
  • Joined 04-October 16
Just need two. The resistor and POS for the passenger side. One resistor for the drivers.
Ok I'll give these a go so. It will probably be a few weeks but I will report back.
Edited by Colin8989, 09 December 2016 - 08:32 PM.
  • Dan_585 likes this
#42
Yinger
Yinger
  • 212 posts
  • Joined 29-October 14
Looking forward to seeing the results
#43
Dv8
Dv8
  • 131 posts
  • Joined 14-March 13
The airbag 360 occupancy sensor defeater works, just tested. I also opened it and its a small circuit board. I feel they earned their money. Per usual u will need the resistors to fool the airbags on each seat your replace and one occupancy sensor, then preform the reset procedure for your airbags if the system has 'seen' no bags connected, even if only once.
~Dv8
  • 7racer, Yinger and Dan_585 like this
  8.6 @166MPH
 NHRA Licenced GTR 8.5
#44
  • 7,822 posts
~Dv8
woohoo!!!
  • Dv8, Yinger and Dan_585 like this
#45
bdl99
bdl99
  • 137 posts
  • Joined 30-December 12
~Dv8
Thanks for reporting back, if it is an active rather than passive circuit then they have certainly earned their money. Glad there is something available that works.
  • Dv8 and Yinger like this
#46
Dv8
Dv8
  • 131 posts
Tell me.
  8.6 @166MPH
#47
Yinger
Yinger
  • 212 posts
~Dv8
Awesome! Thanks for testing! Did you get the g37 one as well?
Edited by Yinger, 21 December 2016 - 02:29 AM.
#48
bdl99
bdl99
  • 137 posts
Tell me.
Well it is definitely active. The resistors on the other connectors are passive, but as you can see in the picture this has a small processor which will be running a small amount of code. The board and components would cost very little, but they would have had to reverse engineer and create the code. Having said that I expect is was relatively easy to achieve. Get someone to sit in the seat, hook up the wires to a scope, take note of the signal and then create a simple program to reproduce.
Thanks for posting the picture.
  • 7racer and bpauto like this
#49
Dv8
Dv8
  • 131 posts
I did order the G37 one, but the nissan ones are all the same.
If anyone would appriciate the picture, i knew it would be you Brian.
~Dv8
  • 7racer and choerizo like this
  8.6 @166MPH
#50
Yinger
Yinger
  • 212 posts
Figured they would be, but rather stick with what worked haha. Thanks again!
#51
  • 7,822 posts
wow...what a great outcome.
glad we got this and no one has to go junkyard diving for anymore old seats!!
  • Yinger and Dan_585 like this
#52
Yinger
Yinger
  • 212 posts
Just installed mine. Worked like a charm! Thanks again 7racer for bringing it to our attention!
  • 7racer and Dan_585 like this
#53
Dv8
Dv8
  • 131 posts
So attempting to do a SRS reset procedure; if my airbag light symbol never blinks off to continue doing the reset, whats that mean?
  8.6 @166MPH
#54
bpauto
bpauto
  • 570 posts
Did you properly get it into test mode? It should blink very slowly.
#55
Dv8
Dv8
  • 131 posts
ign on, the airbag light never turns off to even start the process. it always stays lit. I wonder what that means.
  8.6 @166MPH
#56
Yinger
Yinger
  • 212 posts
Weird, it should blink after maybe 5 seconds. Have you tried disconnecting the battery?
#57
Dv8
Dv8
  • 131 posts
yeah.
i read that my srs controller or impact sensors may be bricked. i ordered a srs scanner to see if it will tell me anything.
  8.6 @166MPH
#58
bpauto
bpauto
  • 570 posts
EDIT: Brain fart.
Edited by bpauto, 29 December 2016 - 11:36 AM.
#59
Yinger
Yinger
  • 212 posts
Did you try to put it into diagnostic mode via AP, Ecutek or manually via the airbag connector?
Is it possible to put it into Diagnostic mode with ecutek?
#60
bpauto
bpauto
  • 570 posts
Damnit, sorry, brain fart. TPMS functionality through Cobb and AP, not air bag.
You can still do the Airbag diagnostic procedure manually via the on/off trick. If you get the car into the diagnostic mode, it'll tell you via the number of blinks exactly what the issue is.
