Passenger occupancy sensor
Posted 24 November 2016 - 07:17 AM
Posted 24 November 2016 - 09:14 AM
Posted 24 November 2016 - 09:19 AM
+1 There's a U-Turn harness by Works Bell but I'm not sure if it's a plug n' play solution vs. the OEM sensor.
That is for the seat airbag, the POS is for the passenger airbags in dash, side curtain, etc
- Dan_585 likes this
Posted 24 November 2016 - 12:13 PM
The U-turn is to get the sensor to think there is someone in the seat...the sensor is needed to tell the car that the sensor is there.
That's the annoying thing. If you goto ebay there are "electronic boxes" that mimic the sensor, but the last time I looked there wasn't anything for out year of cars.
I would look again...maybe in between naps from the turkey meal
Posted 24 November 2016 - 12:20 PM
Posted 24 November 2016 - 12:21 PM
Posted 24 November 2016 - 12:22 PM
Posted 24 November 2016 - 12:23 PM
http://airbag360.com...lator-463-p.asp
I have to look what years on the altima that they said would work
- bpauto likes this
Posted 24 November 2016 - 12:31 PM
I found a 370z POS on Ebay for 50 bucks that was already removed out of a seat,the connection pins are the same for the GT-R.
I just laid it under the passenger Sparco seat cushion.
It and the Bells U turn harness works great.
The only problem I have with my Sparco seats is that the passenger seat sits about 3/4 of an inch higher than the drivers side.
I'm gonna have to see if the Sparco base can be cut and fabricated to get the seat a little lower.
Posted 24 November 2016 - 12:49 PM
Posted 24 November 2016 - 01:01 PM
Posted 24 November 2016 - 11:20 PM
Posted 27 November 2016 - 01:59 AM
Hmm I might try this
http://airbag360.com...lator-474-p.asp
Curious about this too. Putting in a race seat into my passenger side... can always buy a used weight sensor, but this seems like a more simple option
Posted 06 December 2016 - 11:23 PM
Posted 06 December 2016 - 11:36 PM
Has anyone tried the airbag360 yet? I emailed them but no response
I just got it in the mail but the car is still down so no easy way to test it at the moment.
Posted 07 December 2016 - 12:32 AM
Which one did you get?
Posted 07 December 2016 - 05:17 AM
Could put it in my car while seats are out
Posted 07 December 2016 - 08:29 AM
Yes but we would have to also pull my other resistor out too. Unless you bought that!?
Posted 07 December 2016 - 08:31 AM
The one for the G37. They are all the same I think. On some old threads they mentioned
That the passenger sensor from a G37 worked so I thought that would be a good one to pick from the website. I'll take a pic of it when I get home.
- Yinger likes this
Posted 07 December 2016 - 10:15 AM
Sounds good, I believe you're right about the plugs being the same since the weigh sensor are identical. I'll probably order one as well.
Did you also get two bell u turn harnesses? I tried using the 2 ohm resistors, but it kept getting loose.
