New personal best on slicks 9.91@136.7 FBO on 93oct and Water-Meth injection
29 replies to this topic
someone
someone
  • 215 posts
  • Joined 06-September 15
UPDATED RESULTS HERE: http://www.gtrherita...ction/?p=119378
Yesterday I went to the drag strip for the first time with slicks on my FBO GTR running 93oct and water-meth injection. My best on drag radias was 10.35@135mph with 1.61s on the 60'. I was ready to run faster times on slicks.
First 2 passes sucked. Worst than my previous passes on DR even while I was cutting faster 60'.
Third pass I improved to 10.29@136. Not bad, but still slow considering I did 1.46s on the 60'. I was a bit disappointed.
I self-tune my car, but I lack "track experience", so I got in contact with one of the top tuners in my area and he gave me some hints that made a huge difference!
After dialing in his suggestion, next pass i ran 10.14@136 with 1.40 60' . I was extremely happy with those times, considering I was running a cheap e85 equivalent setup (93oct and water-meth).
We decided to do another run with lower pressures in the slicks, and a higher launch rpm.
With those small changes, i was able to pull my personal best by cutting a 1.37s 60' and running 10.09@134.5.
Things I learned yesterday:
1. Just throwing in slicks will not make you faster. You need to make adjustments to make use of the added traction. I was under the impression it was going to be a plug and play thing.
2. Knowing how to tune your car to make HP does not means you will be faster than people that do this for a living. If it wasn't for the help I got from a real tuner, it would had taken me several visits to the track to figure it all out. A waste of time and tires :)
3. Driving with stock front wheels and radial tires (Hankook RS3 in my case) gets a bit scary close to the 1/4 mile. With front tires pressures at 22psi is less scary, but you can still fill the back "waving" as you get close to the finish line. Its manageable, but scary.
Edited by someone, 26 January 2017 - 11:40 AM.
  • Tim, ian.r, 7racer and 3 others like this
  • 8,933 posts
Nice man glad you were able to overcome your problems because there is nothing wrong with that slip
  • 1,677 posts
Excellent times
boosted-m
boosted-m
  • 147 posts
  • LocationNY NJ PA
Nice work!
Do you have some info and pics of the meth injection kit you have setup?
  • VR_power likes this
'12 GTR built
1050whp & 800tq on E85 -
Engine/Trans: WGP built 10:1 CR block | Headgames pocket port heads with Tomei 272/272
| ETS GTX3076R turbo kit | Driven Innov Race FMIC, 3" IC piping & CAI's | Shep ONE-k trans | Fore Innov Walbro Triple Pump Hanger, Rails, FPR | ID1700cc | 60mm WG welded to 90mm midpipe | EcuTek w/ GotBoost Flex Fuel Cable, DIY FPR sensor | and more!!
Suspension: KW Sleeve Kit
| SPL Front Upper Control Arms & Rear Camber Links |
Steve Theodore
Steve Theodore
  • 442 posts
  • Joined 23-November 14
  • LocationNorth Bend, WA
Fantastic job...that is moving for FBO!  B)
Steve Theodore
2014 Nissan GT-R
- Kline Inconel grade 625 full exhaust, ForgeLine GA1R Open-Lug Cap wheels
2010 Porsche 911 GT3 RS
- SharkWerks exhaust bypass, lots of OEM goodness
1993.5 Toyota Supra TT hardtop
- TwinsTurbo build, BW EFR 7163 twins, 1175 whp
someone
someone
  • 215 posts
Im using a Cooling Mist kit with some improvements like braided lines and aem filter. The only complain I have with cooling mist is their jets. I had a hard time getting two of the same jets to deliver similar cc/min (had to return them several occasions until i got two that were close enough) . Ill share some pics later.
Nosferatu
Nosferatu
  • 165 posts
  • Joined 13-March 16
  • LocationAhead of You :)
Meth injection is fun I used it on my boosted Corvette.  Only issue was once it's out you're out.  At least on E85 it's 24/7 until you run out of gas.  Seems to give similar gains to what an E85 setup does at FBO.  Kudos for giving it a whril.  The LSx guys typically run 100% methanol without water...maybe give that a try?
2014 Nissan GT-R :D
Mods: FBO + Litchfield Suspension + Greddy Tranmission Cooler + AMS Race Intercooler + ETS 4" Titanium Exhaust + AP Racing Jhook rotors + Flex fuel kit + FORE Innovative + ECUTek Phase 5 + HRE 3 piece forged wheels with Titanium hardware
Best 60': 1.534 (R888 32psi)
Best ET: 10.247 Best MPH: 135.13
Other Rides:
2017 Audi R8 V10 Plus (Ara Blue Crystal)
  • 1,038 posts
+1 used it in my blown vette too. Much prefer E85 personally.
someone
someone
  • 215 posts
e85 would be a better and safer option for sure. But I don't have access to e85 at the pump. I can get it from speedshops (sunoco or vp) @ $14/galon.
Since meth is risky to run, I always keep an eye on datalogs to make sure of three things:
1. fuel duty cycle remains close to expected values (i use old datalogs to compare). An increase in fuel duty cycle could indicate that the meth pump is going out or that jets are clogged.
2. Compare fuel ratios between banks. Differences could indicate that a jet is clogged.
3. From time to time, i check the the jets are providing the expected cc/min and that they don't differ much one from the other
A pain in the butt for sure when and definitely not for people that want the "maintenance free" performance e85 provides.
Here are some pics. Don't mind the ugly shipping paper, I use it to spot leaks if they ever happen. So far, the setup has been leak free for years:
Edited by someone, 06 December 2016 - 05:17 AM.
Nosferatu
Nosferatu
  • 165 posts
I had my tuner back on the LSx platform set up a bunch of fail safe situations that if the meth pump failed or wasn't delivering a certain amount it would put the tune into a limp mode.  You could floor it but the car wouldn't go very fast.  I know for certain the GT-R's ECU is much more complex than the LS stock ECU so I'm sure certain parameters could be set as automatic fail-safes.  I'm no tuner but I'm certain it's "do-able."
2014 Nissan GT-R :D
Other Rides:
2xqzit4-zn
2xqzit4-zn
  • 76 posts
  • Joined 18-March 15
Well done..
Awesome time..just a quick one to consider..I also ran water/meth injection...used 50/50 water and meth mix..and I was on full ethanol..my purpose for the watermeth kit was solely for cooling as I did not have a cooler fitted..I see the pics you posted..my jets were much further from the sensor..don't you feel yours is a bit too close to the sensor and throttle...
someone
someone
  • 215 posts
All the reference I found mentioned that the jets needed to be about 6in from the TB. Which makes it be close to the map sensor.
Probably father down would be the best to get get better atomization and to get more accurate temp readings in a SpeedDensity setup.
VR_power
VR_power
  • 967 posts
  • Joined 05-January 15
Definitely don't do this. It would absolutely provide great performance but 100% meth is way to much a safety hazard to take that risk.
Nosferatu
Nosferatu
  • 165 posts
As long as you're safe with it and it's behind a firewall it's a non-issue.
2014 Nissan GT-R :D
Other Rides:
FlyBriR35
FlyBriR35
  • 80 posts
  • Joined 24-December 15
  • LocationAlbany NY
Nice work! so close to 9s!
  • khaleesi likes this
2015 dbp Alpha 7
620whp, 611lb torque on 93 pump gas
ETS 102 mm titanium exhaust
T1 race development catch can
someone
someone
  • 215 posts
I really doubt I can run 9s without some weight reduction. I was looking at the 1/4mile rankings, and it looks like getting faster 60' feet will be very very hard to achieve. Best 60' i saw in my category (stock turbos) was 1.38 in a 9.5sec car.
It would be awesome to run 9.9s with 93oct and meth
Let's see if I can make it next year
alilodhi
alilodhi
  • 22 posts
  • Joined 13-December 16
im looking into getting a drag tire/wheel set up to improve my 60' ft and 1/4 time..
2015 BE GTR- Agency Catless Downpipes, BL midpipe, Custom Catback, Gotboost Intakes, Flex Fuel Kit, ID1700s, Tuned by Ben LInney, SPD Street Intercooler, Tial BOVs, Upper and Lower Piping. SiR Stage 1 Turbos, Forge Motorsport Actuators, Vorsteiner V-FF 103s with MPSS285/335, Stillen Front lip, Stillen Side Skirts, LED side markers,
2015 Z06 - Tune/ INtake
2014 BMW M5
2015 Bentley flying spur
2015 ML63
Past
2015 Hellcat Challenger
2015 911 turbo S
2013 Mercedes SLS- Akrapovic
2013 Premium-Megan Racing catback, cobb tune, intakes
2012 Porsche Panamera Turbo
2010 R8- Black and Gold
2009 Z06- Supercharged 682 RWHP
2009 CTS-V- 623 RWHP
2008 M6
someone
someone
  • 215 posts
I believe MH has a new 18in slick. Those on 18in Enkei wheels would definitely help you
someone
someone
  • 215 posts
PM David Buschur. He might have some in stock. Here is the thread for reference
New drag slicks from M&H in 17" and 18"
http://www.gtrherita...-wheel-sizes!!!
Edited by someone, 20 December 2016 - 07:09 PM.
alilodhi
alilodhi
  • 22 posts
Aren't 17 to small for the brakes
2014 BMW M5
2015 ML63
Past
2015 911 turbo S
2008 M6
